Fourtitude.com - Oceanbird - Why the delivery of your next European or Asian import might be delayed slightly
    Results 1 to 19 of 19
    1. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      45,019
      10-16-2020 12:05 PM #1
      Sweden's new car carrier Oceanbird is the world's largest wind-powered vessel
      The Swedes are famous for good design - and we’re not just talking about IKEA.
      Oceanbird might look like a ship of the future, but it harks back to ancient maritime history because it’s powered by the wind.
      The transatlantic car carrier is being designed by Wallenius Marine, a Swedish shipbuilder, with support from the Swedish government and several research institutions.
      With capacity for 7,000 vehicles, the 198-metre long vessel is a similar size to conventional car carriers.
      But it will look radically different.
      The ship’s hull is topped by five telescopic “wing sails,” each about 80 metres tall.
      Capable of rotating 360 degrees without touching each other, the sails can be retracted to 18 metres in order to clear bridges or withstand rough weather.
      The sails, which will be made of steel and composite materials, need to be this size to generate enough propulsive power for the 35,000-tonne ship.
      Oceanbird might look like a ship of the future, but it harks back to ancient maritime history, because it’s powered by the wind. Credit: CNN
      Although “the general principles of solid wing sails is not new,” designing the Oceanbird’s sails has been a challenge, says Mikael Razola, a naval architect and research project manager for Oceanbird at Wallenius Marine.
      That’s because these are the tallest ship sails that have ever been constructed.
      “This ship, at the top of the mast, will be more than 100 metres above the water surface,” says Razola.
      “When you move up into the sky that much, wind direction and velocity change quite a lot.”
      To better understand the atmospheric conditions at this height, Wallenius mounted sensors on top of its existing vessels while they were crossing the Atlantic.
      They gathered data on wind velocity and veer (a clockwise change in wind direction), up to 200 metres above sea level.
      “All of this information has helped us design an efficient wing and hull system, that can make the most of the power available in the wind,” says Razola.
      The telescopic 'wing sails' of Oceanbird will be the tallest ever built. Credit: CNN
      Reducing emissions
      The shipping industry is under pressure to reduce emissions of CO2 and other greenhouse gases.
      Shipping accounted for 2.89 per cent of global manmade greenhouse gas emissions in 2018, according to the International Maritime Organisation (IMO), the UN body that regulates global shipping.
      In the same year, the IMO introduced a mandatory 50 per cent reduction of total annual greenhouse gas emissions by 2050, with the ambition to reach zero emissions “as soon as possible in this century.”
      Oceanbird is designed to exceed these targets.
      Wallenius says the ship will emit 90 per cent less CO2 than conventional car carriers.
      It won’t be completely emission-free, however, because it will still rely on engines for manoeuvring in and out of ports and for emergencies.
      Slow sailing
      With a projected top speed of about 10 knots, Oceanbird will be slower than standard car carriers, which can travel at 17 knots.
      It will take around 12 days, instead of the standard seven, to cross the Atlantic.
      This long journey will require some scheduling changes, says Razola, as well as acceptance from carmakers.
      “Of course, there will be challenges and we won’t be able to do things exactly as we’re doing them today, but the response so far from manufacturers has been very positive,” he says.
      Jakob Kuttenkeuler, a professor at Stockholm’s Royal Institute of Technology - one of the project’s collaborators - is also optimistic.
      A comparison between the wind-powered Oceanbird and a diesel-powered carrier. Credit: CNN
      “People are environmentally informed enough now that we think there will be customers willing to put their cars on a ship that goes roughly half as fast as today’s ship, if we can make it carbon neutral,” he says.
      Kuttenkeuler and his team are working with Wallenius on performance and aerodynamics calculations, using weather data to simulate realistic sailing conditions.
      They have built a seven-metre model of Oceanbird which will sail in Stockholm’s archipelago later this year, to gather data that will help finalise the ship’s design.
      Razola says it will take around three years, after that, to launch the full-size version.
      “Our ambition is to see Oceanbird sailing in 2024,” he says.
      Americans hate EVs because they grew up with Power Wheels that were glacially slow, ran out of power in 20 minutes and took an entire day to recharge.
      Trolls ignored: 9
    3. Senior Member chucchinchilla's Avatar
      Dec 25th, 2004
      Los Gatos, CA
      21,991
      2016 A6, 2014 X3, 1967 Bus, 1963 356
      10-16-2020 12:28 PM #2
      Humans have been sailing cargo ships for thousands of years so the theory is proven, although I'm concerned the motorized power is designed to only work around the port. This could be problematic when winds are low or they have to power through a strong storm.
      This forum is more and more of an embarrassment every day...
    4. Senior Member bzcat's Avatar
      Nov 26th, 2001
      Los Angeles
      24,902
      10-16-2020 12:42 PM #3
      Quote Originally Posted by chucchinchilla View Post
      I think the crew will survive a few days delay if winds are low This is not the 17th century and people don't die of scurvy while crossing the Atlantic anymore. I'm sure Oceanbird will have a salad bar or two in the crew quarters.
    5. Member Tommietank's Avatar
      Mar 6th, 2009
      Burlington, VT
      3,169
      2019 Model 3 Performance, 2019 Hyundai Ioniq EV, 2004 S2000
      10-16-2020 12:45 PM #4
      She will not fit under the Verazano Narrows bridge. I wonder how many more ports she's too tall for.
      Slow Car Fast
    6. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      45,019
      10-16-2020 01:05 PM #5
      Quote Originally Posted by Tommietank View Post
      Does the current Hero Class vessel fit under the bridge? From the basic outline drawing and story, it seems like the sails are telescopic and thus it may not be any taller than the current ships. It wouldn't be that smart to make them too tall to access major ports. They usually take that kind of stuff into account during design, don't they?
      EDIT: https://www.oceanbirdwallenius.com/the-vessel/#future
      Verazano Narrows bridge is 228 feet water to under deck. 45 meters is only 147 feet. No problem.
      The 200 metres long and 40 metres wide cargo vessel will be able to cross the Atlantic in 12 days. The wing sails are all of 80 metres tall, giving the ship a height above water line of appr. 105 metres, but thanks to a telescopic construction they can be lowered, resulting in a vessel height above water line of appr. 45 metres.
      This comes in handy when passing under bridges or if the surface area of the wingsails needs to be reduced due to strong winds. To be able to get in and out of harbours – and as a safety measure – the vessel will also be equipped with an auxiliary engine. Powered by clean energy, of course. The first vessel will be a cargo ship, but the concept can be applied to ships of all types, such as cruise ships.
      Trolls ignored: 9
    7. Member Chris_V's Avatar
      Jun 18th, 2009
      Pikesville, MD
      18,730
      '13 Volt, '20 Bolt, '02 Suburban 2500LT
      10-16-2020 01:12 PM #6
      "the sails can be retracted to 18 metres in order to clear bridges" it says. Maybe they thought of that?
      At any rate, reducing the emissions of typical bunker fuel ships is a GREAT thing. A couple of those older ships coming into port can cause more pollution in the air than tens of thousands of cars.
      "Like a fine Detroit wine, this vehicle has aged to budgetary perfection"
    8. 10-16-2020 01:14 PM #7
      Quote Originally Posted by spockcat View Post
      No doubt they do. I'm sure they'd never mix up metric with English units, either. That could never ever happen.
      Great concept, though... I hope they make it work and have it be economically viable...
    9. Member atomicalex's Avatar
      Feb 2nd, 2001
      Detroit and Düsseldorf
      18,083
      dark blue stick shift station wagon, shiny yellow motorbike, dirty green motorbike, bluBRZ
      10-16-2020 01:20 PM #8
      Quote Originally Posted by boogetyboogety View Post
      This.
      I'm kind of psyched to see this come to fruition. It's a long time coming.
      I AM DISCO DIVA!
      たくさんとうふ、よ Where did all these damn Toyotas come from?
      Compared to a British roadster, all Volkswagens are reliable!
      nevAr Lose - DE Minister of Foreign Affairs and Deputy Bankruptcy Controller - IPROfftopikstan, kuhlBRZ
    10. Member r_fostoria's Avatar
      Sep 7th, 2009
      York, PA
      7,893
      2009 VW GTI, 2002 VW Golf
      10-16-2020 01:41 PM #9
      Sorry sir, it looks like you car will be delayed. It's currently stuck in the doldrums.
    11. Geriatric Member spockcat's Avatar
      Jun 4th, 2003
      45,019
      10-16-2020 03:19 PM #10
      It isn't like they are sending the cars to Mars. Wait. Anyone check on where SpaceX's Roadster is these days?
      Trolls ignored: 9
    12. Member NotFast's Avatar
      Mar 20th, 2002
      Chicago area, IL
      2,695
      10-16-2020 04:22 PM #11
      Did VWVortex close The Ship Lounge forum?
    13. Member Rob's Avatar
      Feb 19th, 1999
      16,142
      10-16-2020 04:37 PM #12
      Quote Originally Posted by Chris_V View Post
      Exactly. The stuff that gets burned is pretty nasty. It's basically a sludge that has to be heated up just to flow.
      Plus if shipping companies can reduce fuel costs by up to 90% that's a huge win economically for them as well.
      [SIZE=1]- - - Updated - - -[/SIZE]
      Yes I think it's "near" Mars right now actually.
    14. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      82,305
      2018 F150
      10-16-2020 04:40 PM #13
      "Why have I not got my new Iphone yet? I ordered it a month ago."
      "Sir, the trade winds have been uncharacteristically light this year."
      But seriously, this is cool.
      Vehicles owned (*=automatic):
      Chevy: 82 Cavalier Type 10, 94 Cavalier Coupe* | Chrysler: 96 Town & Country* | Ford: 73 F100, 88 F150, 18 F150* | Jeep: 78 CJ-5 | Mazdas: 83 GLC, 85 RX7 GS, 86 323, 90 323, 90 B2600i, 92 Miata, 97 Protege, 01 B2300, 01 B3000, 04 RX8 | Nissan: 90 240SX SE | Plymouth: 88 Caravan* | Pontiac: 84 Grand Prix* | Toyota: 84 Celica GTS, 02 Tundra*
    15. Member BlakeV's Avatar
      Oct 24th, 2015
      Original join 1999
      2,263
      2019 Audi S5 Sportback
      10-16-2020 04:59 PM #14
      Ships are probably the best platforms for developing alternate-energy. The wind idea was not exactly late in the game, but...
      Ten years ago, I read that the top 15 ships in the world were polluting as much as 750 000 000 cars. But true, cars anti-pollution in the western world became very efficient these days.
      https://www.dailymail.co.uk/sciencet...ars-world.html
    16. Member what's Avatar
      Jun 24th, 1999
      Los Angeles, CA
      14,331
      1974 MGB; 2017 Golf Sportwagen S 4-Motion DSG; 2020 Audi S4 in Smurf Blue
      10-16-2020 08:06 PM #15
      This is ****ing bull****. What about my freedom to have a car shipped knowing I've polluted the world more? **** you libtards. I want my country back!
      how come a transvestite donkey witch is next to you and why is it wearing a dress?
      Say 'what' again. Say 'what' again, I dare you, I double dare you mother****er, say what one more goddamn time!
    17. Member DrivinAW8's Avatar
      Jun 21st, 2004
      Pixburgh
      1,051
      1989 yuppie-mobile, 2011 ess4
      10-17-2020 09:23 AM #16
      If they're held up at port,
      you think they can give 'em the (ocean)bird?
    18. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      13,834
      10-17-2020 10:07 AM #17
      Quote Originally Posted by DrivinAW8 View Post
    19. Member what's Avatar
      Jun 24th, 1999
      Los Angeles, CA
      14,331
      10-17-2020 10:56 AM #18
      Quote Originally Posted by Unilateral Phase Detractor View Post
      x2. His post wins the thread
    20. Member Car Problems's Avatar
      Jan 22nd, 2014
      2,895
      Hopes and Dreams
      10-18-2020 12:27 PM #19
      Quote Originally Posted by bzcat View Post
      Ayyy me mateys
