Fourtitude.com - Another trailer mishap.
    Page 3 of 3 FirstFirst 123
    Results 51 to 68 of 68
    1. Member barry2952's Avatar
      Jun 13th, 2007
      Farmington Hills, MI
      18,602
      10-17-2020 09:25 PM #51
      Stainless steel brace, or no brace, I couldn't leave this like this. I was telling Gary that I write about my projects, partially for the entertainment of others, but mostly because it is a big part of my thought process. With no inner voice and no mind's eye I use the photos I take to help me understand the subtleties of what I need to do next. I use feedback to catch glaring mistakes, and I do take every suggestion into consideration, but I let the work take me where I need to go.
      This told me I didn't want my name associated with trying to save this due to being scared to death to bring a TIG welder anywhere all this styrofoam. I started thinking about the cars I've built or restored and got to thinking about aircraft construction. It's all about the bracing and proper fasteners.
      It had to go. I checked how far back I had to cut to get to square stock. I used the new Dremel saw to make some incredibly fast and straight cuts.
      There was nothing I could do about this. The bent rafter transferred some of the energy to the rectangular stock side railand turned it into a trapezoid. I didn't see it before, by the weld was broken, too. Glad I took it out.
      They used the same material for the rafter as the side rail. It's lightweight 1" x 3" aluminum with a 1/16" wall. What seems to be available is 1/8" wall. I've made a request of the manufacturer for an exact replacement. I can use the heavier stock, If I need to. I found the replacement ladder, too.
      I used my 100-tooth carbide blade to make a new section of the side rail out of a straight section salvaged from the bent rafter.
      I made two internal sleeve supports cut out of one piece of tubing precisely cutting them so that they would jamb each other in place as they were inserted into the trailer side rail. One didn't go in as far as the other, but there's a good 6" of overlapping sleeve on either side of the joint.
      I repaired the curved section in a similar fashion.
      Demolition is now complete. I believe commercial grade pop rivets through the stainless cap and two layers of aluminum will be a substantial splice without any welding.
      I duplicated the good rear curve spacer. The inner radius clamps down the inner closet ceiling curve and the outer curved material screws down to the larger radius.
    3. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-22-2020 11:05 PM #52
      Getting proper material out of the manufacturer has been like pulling teeth. However, their record-keeping has proven invaluable in getting matching paneling. It has a layer of vinyl that allows it to bend without cracking. It was $28 a sheet, so I got 2 because the transportation to Elkhart and back is $250.00 for me to send someone to get it. Not worthe the risk of having to need a second. The manufacturer usually ships direct to its dealers freight-allowed, but my order for aluminum trim that's 16-feet long and very hard to find 2.5" x 1" x .055 wall, is unavailable through normal supply channels. Apparently, they use so much of it it's milled to their specs.
      I did get $111.00 worth of high quality aluminum rivets in various lengths. Unlike big-range pull-type pop rivets these rivets are to be used within a very narrow range. Many of the joined brackets have interior and exterior bracing that I will have to gauge. I sent Gary after some clear white pine to use in reassembling the trailer and I schooled him on the grade I was looking for. He was astounded at what passes for lumber in the lower grades. I had him pick up some foam board so I can rebuild the smashed wall. It will be part of recreating the original construction method. The foam board gets bonded to the outer skin and to the inner paneling with contact cement.
      One of the things they wanted me to do was to critter-proof the underside of the trailer. They use a pretty sturdy extruded PVC underbelly skin, but they missed many spots a mouse could easily get into. The way their rib cages collapse they can get through any gap they can get their head through. The also build nests in the hollow exposed tubing of the part of the frame that carries the torque-flex suspension. Many a car has been destroyed by mice setting up their home in a boxed car frame. They constantly add to they nest because they urinate on it and that acid and moisture eats the metal from the inside. The grey water discharge pipe had been duct-taped, but that was just flaking off. Pretty useless stuff.
      I use strips of DynaMat I cut on a paper cutter into large bandaid-size pieces that easily bridge the gap, making to impossible for a mouse to chew through the metal and tar-based pad.
      Just after Gary left one day I guess I became dehydrated and stumbled and fell. My arm took the brunt of the blow and got pretty ugly before it got better. I was supposed to get a Botox shot to control the PD shake, but the doc said, "Nope!" I believe I've astounded Gary several times that I can go from shaking like a leaf to surgeon-steady the moment I touch any tool.
      The splice Lyndon made me is a perfect fit. It will unify the wall/roof connection. This will be held in place with rivets.
      Now you can see the gentle curve of the roof. I gouged out enough space in the styrofoam to slide in a 1x3 to splice the roof skin. Another will be installed across the splice between the closet wall and the new ceiling panel, doubling as an anchor point for the sliding closet doors. Once the inner panels are in place and the aluminum rafter is in place my intent is to install expanding foam as insulation and fill the void to structurally stabilize the roof section.
      This gives me the opportunity to tell my expanding foam story. When I was young and foolish I wanted to build a wood hydroplane. Every day I passed a boat supply place on my ride to school on the bus. They had a skeletal build of a kit in their front window. When I got kicked out of the house for beating my brother for stealing my coin collection to buy "candy". I moved in with a HS class-mate that was a year older. He had a 1,200 square foot apartment in a nice part of Detroit in 1970. I took the smaller bedroom. His girlfriend moved in, all hell broke loose and I came home to a mostly empty apartment with a bunch of broken dishes and a plaster "Love" statue of an intertwined couple, smashed to bits. I never heard from either one again, so I inherited his apartment and his cat. I moved into the master bedroom and decided that the 10 x 12 bedroom on the second floor would be the perfect place to build a 9-foot by 5-foot hydroplane. It wasn't a bad place to work, but the deep green shag carpet took a beating.
      The boat was built. I did a pretty nice job for an 18 year-old and I didn't want it to sink so I decided to fill every cavity with expanding foam. I bought a one gallon kit. I bought a half gallon Pyrex measuring cup. It weighed a ton. My plan was to mix a half-gallon of foam and evenly distribute it. I had no idea what I was about to do. I measured out a quart of the resin and cleared a path so I could walk around the boat. I never got the second quart into the mixing cup and it started growing exponentially. I literally ran around the boat distributing the growing foam as best I could, but it spilled over the sides forming stalactites that firmly attached the boat to the deep green shag. My vision clouded and my breathing became strained as it started raining in the spare bedroom. It was the middle of the winter and the poorly insulated attic made the ceiling cold and all that moisture released by the foam condensed on the cold ceiling and fell in a regular light rain pattern. Gasping for air I rushed to window and cranked the casement window open and the negative air pressure of the building caused frigid air to rush into the room that turned the air to fog. I couldn't find the door. I fell to he floor, like in a fire, but that didn't help. I crawled to the door and stumbled into the living room, exhausted. It took me hours to cut off what attached to the floor and to carve the rest until the outer skin would fit. I mostly fished it, but bought a 190SL that had Fred Flintstone floorpans and an "O" shift pattern. My attention went elsewhere and the boat got flipped over in the yard. A family of possum carved out a condo in the foam and made our dogs crazy, for years. When I moved here 25 years ago I went to move the boat and the only thing holding it together was the fiberglass matting. Mother Nature recycled the rest. She probably did me a favor.
      One of the tasks they asked me to do was install a larger flat screen, a much larger tv. While most people would draw up plans, I just do. In the doing the refinement of a cardboard template to a working wood adapter took little time. I'm able to create a 3D object without seeing it it my head. I will turn this over to the metal fab guy and have him make it in 3/32" stainless.
      I tested the wood template and it held the weight just fine, but the adapter should be steel or aluminum.
      The entertainment center wasn't working properly. A harness connector had come loose, but I did find some aftermarket hackwork splice using wireuts instead of crimp compactors. Gobs of tape doesn't help.
      Dot had complained that draining the water heater for winer storage let water into the trailer. I discovered a poor sealant installation that let water run into the trailer. I'm thinking the Dynamat would do a great job making it water-tight. I showed Gary how to clean and lubricate the bump-outs gear and rack system. They are the sort of thing that should be operated every once in a while to keep things moving. The new switches he bought work great. No more self-operating lifts. That was spooky to be working under it and hearing the lift try and work. I think what was happening is the switch would stick and the unit circuit breaker, rated at 6 amps, would open when it overloaded and started again when the bi-metal breaker reset itself. I figured out why water was getting into a storage area, wiping the Honey Do list pretty clean. Everything works!
    4. Member BlackMiata's Avatar
      May 24th, 2018
      Texas
      651
      1992 Miata, 2001 VW GTI, 2018 A6, SQ5
      10-23-2020 01:48 AM #53
      Looking good.
      Curious how you do the expanding foam, my experiences using the expanding foam in a can, haven't always turned out as planned. Tried fixing an interior door that got a hole in it, figured the expanding foam would give it a bit more rigidity and hold the patch in place. End result was a door with a nice bulge, not too bad but definitely noticeable. So I'm' looking forward to seeing your technique, anticipating I'll be learning something new.
    5. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-23-2020 04:45 PM #54
      Quote Originally Posted by BlackMiata View Post
      Looking good.
      I had my driveway slab lifted with foam a few years ago. It's difficult to control. The company that did the work no longer does it. Highly profitable, but I'm betting they "bulged" more than a few driveways.
      No, I learned from my mistakes. I put very little material down at a time. The force seems to exponentially increase with volume. I'm going to use a commercial 12 board foot kit to start with. For you youngsters that never took shop class a board foot is a 12-inch wide, 12-inch long and 1-inch volume of anything, but is started as a lumber term to describe the yield of a tree. I will avoid gettin the material anywhere onward pressure is a problem. I'll lay down a 4" grid and let it fully harden before laying down a grid between the first pass. I'll build volume for better control. Once the thin wood skin is covered than an even coating over the rest should minimize any interior bulging.
      If I were to use foam for a hollow door I would shoot very little material, and add to it after it cured.
    6. Member renegadeofpunk03's Avatar
      Oct 15th, 2003
      Lost Angeles
      2,051
      Japanese Truck, Italian Motorcycle
      10-23-2020 05:37 PM #55
      This gives me the opportunity to tell my expanding foam story... I had no idea what I was about to do...
      That's a great story. Mine isn't nearly as funny, but here goes. At some point in college, we thought it was hilarious to do "destructive testing" aka just smashing crap (i.e. discarded bowling ball, broken CRT monitor, etc.) to see what would happen - I went to a college that was half engineers, and our unofficial slogan was "where the men are men...and so are the women" so we had little else to do. Someone had the bright idea that a can of Great Stuff would be hilarious to smash open. You know, expanding foam, propellant, metal can, sounded like a decent idea at first. Cut to me dropping a rock on it from a 6' high balcony...let's say we underestimated the volume contained in one can, and the effectiveness with which the propellant would have scattering it. Everywhere. I was picking bits of foam off of every surrounding surface for weeks.
      Back on topic, your work looks awesome so far!
      ಠ_ಠ
    7. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-23-2020 06:08 PM #56
      Quote Originally Posted by renegadeofpunk03 View Post
      Did you ever see the poor woman that mistook a can of foam for some kind of hair treatment?
    8. Member renegadeofpunk03's Avatar
      Oct 15th, 2003
      Lost Angeles
      2,051
      10-23-2020 06:27 PM #57
      Oh god, that would be truly awful. It's not fun to get off of porous things. Fortunately, I was clean shaven at the time and had short hair
      ಠ_ಠ
    9. Member Bibs's Avatar
      Sep 17th, 2001
      SW Ontario
      1,931
      All Mazdas: CX-9, 3, Miata
      10-23-2020 09:42 PM #58
      Great work, Barry...as always, thanks for the education.
      That fall looks nasty. I once had a spell of sleepless nights, long work days and travel...and probably dehydration...
      I was visiting my brother, got to the top of his stairs, blacked out and fell backwards.
      Ass over apple cart, but nothing broken....except my brothers drywall.
      Can’t believe I didn’t hurt myself.
      Sent from my iPad using Tapatalk
    10. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-23-2020 10:06 PM #59
      Quote Originally Posted by Bibs View Post
      Lucky, you were. I can't believe I didn't break anything. The bigger they are the harder they fall. I've had worse. I leaned a ladder against a brace in a factory and it was poorly secured. I came down with the ladder on my knees and elbows. I'm surprised, at 68, that anything works.
      Lyndon can make the most utilitarian corner braces look like works of art. Seems a shame to bury them in foam, but I couldn't a better way to attach the new rafter. I shudder at bringing a welder anywhere near this trailer. I'm thinking about epoxying these in place in addition to the rivets. Overkill?
    11. Member BlackMiata's Avatar
      May 24th, 2018
      Texas
      651
      10-23-2020 10:59 PM #60
      I concur, those braces do look good. In the woodworking realm, its is common to glue and screw, so I'd be inclined to glue and pop-rivet if I was doing the repair. Only reason I'd not glue is if I ever though there would be a need to drill the pop-rivets to remove the braces. In this application I think that is extremely unlikely.
      Given the amount of foam in the trailer, I concur with the hesitancy to attempt any welding. But I'm curious to know if the foam has any flame retardant properties. Given how much you've removed it would be an interesting experiment to take some outside where it is safe to do so and see how or if it ignites/burns.
    12. 10-23-2020 10:59 PM #61
      Overkill? Yes. Exactly why I would do it
    13. Member atomicalex's Avatar
      Feb 2nd, 2001
      Detroit and Düsseldorf
      18,054
      dark blue stick shift station wagon, shiny yellow motorbike, dirty green motorbike, bluBRZ
      10-24-2020 03:13 PM #62
      Epxoy or polyurethane. I like PU because it is quite waterproof and long-term flexible.
      I AM DISCO DIVA!
      たくさんとうふ、よ Where did all these damn Toyotas come from?
      Compared to a British roadster, all Volkswagens are reliable!
      nevAr Lose - DE Minister of Foreign Affairs and Deputy Bankruptcy Controller - IPROfftopikstan, kuhlBRZ
    14. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-24-2020 03:14 PM #63
      Can you recommend a poly product?
    15. Member atomicalex's Avatar
      Feb 2nd, 2001
      18,054
      10-24-2020 03:20 PM #64
      PL construction adhesive. I can't remember if it's still branded OSI or it's now Loctite.
      That or windshield adhesive. Any windshield adhesive will also be a good choice.
      I AM DISCO DIVA!
    16. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-24-2020 03:24 PM #65
      Oh boy, I get to use my Cleco's again. Best fab tool.
    17. Member Pnuu's Avatar
      Jul 27th, 2005
      WA
      6,134
      GX, Taco, Tiguan, bikes
      10-24-2020 04:38 PM #66
      Just got caught up on this thread.
      I'm pleasantly surprised at the quality of the trailer build, and the ability to use somewhat standard repair methods to get it back into shape. I'm always concerned about the potential for leaks on a trailer but it looks like you'll have that covered.
      And the expanding foam story.....
    18. Member barry2952's Avatar
      Jun 13th, 2007
      18,602
      10-24-2020 04:51 PM #67
      This is the picture I was thinking of. Turns out the poor woman may have been attacked. ****ty prank.
    19. Member renegadeofpunk03's Avatar
      Oct 15th, 2003
      Lost Angeles
      2,051
      Today 12:09 PM #68
      We use rivbonding at work for dynamic structures. Holds up really well to vibration. Toughened epoxy is actually relatively flexible, the rivets keep things from flexing too much anyway. We use ScotchWeld DP420 for mounting click bonds, which use no rivets. If you do the prep work right, the bonds are insanely strong - if you pry one off, generally its the base material that fails and stays with the bond itself.
      ಠ_ಠ
