Fourtitude.com - On FIRE at 150MPH with NO BRAKES!
    Page 5 of 5 FirstFirst 12345
    Results 101 to 125 of 125
    1. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The Orange Crush
      41,851
      '19 Alfa Romeo Stelvio, '18 Mazda CX-5
      09-10-2020 01:12 PM #101
      I would think that if something on the harness burned, even if only semi-related, that could easily be enough to lose the ability of a computer controlled transmission to operate. The same holds true of an on-off switch for the ignition.
      exactly. the car has so many computers that the minute a cable fries or something got damaged its lights off.
    3. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      15,205
      '19 MDX, '17 S3, '08 987.1 S, '86 535is 5MT
      09-10-2020 01:17 PM #102
      Quote Originally Posted by absoluteczech View Post
      What's there not to understand the fire probably killed the engine and it died. he was just coasting then.. try shifting a DSG car with the engine off. it doesnt work.
      Was the engine off? It seemed to me that it was running most of the time . . .
      I used to pack his chute all the time
    4. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The Orange Crush
      41,851
      09-10-2020 01:19 PM #103
      Quote Originally Posted by SchnellFowVay View Post
      5:30
      "can you turn the motor on? no, it's dead"
    5. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      15,205
      09-10-2020 01:58 PM #104
      5:30
      Good point
      Feb 12th, 2019
      280
      09-10-2020 02:08 PM #105
      Was any reason mentioned why he didn't use the chute?
      Why have it if you don't intend on using it or is it a street cred thing
      Boiler Up!
    7. Member elite.mafia's Avatar
      Mar 17th, 2010
      I95 Northbound
      3,984
      2005 Toyota Celica GT-S
      09-10-2020 02:12 PM #106
      Quote Originally Posted by Juiced6.3 View Post
      he had a kill switch on it so he didn't accidentally hit in traffic or something to that extent.
      2zz-ge 6mt trying to rev to mars
    8. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      17,704
      RS3, JKU
      09-10-2020 02:14 PM #107
      It's safety pinned, as it should be. The pin is removed before your run at the track. During a run the chute is only held in place by the cable, which is pulled by use of a handle in the car. The parachute then deploys. If the cable no longer secures the chute with the pin in place, it will not open.
    9. Learning New Things Every Day. GreenandChrome's Avatar
      May 24th, 2002
      COVID-19 Ground 0 - USA
      15,935
      '12 Earth F****r Limited EL; '12 A4q; '18 UBM Q3q
      09-10-2020 02:17 PM #108
      Just like fire bottles. We had a "remove before flight" lanyard on our fire bottle pin. One of the things on the checklist before the car hits the track. Someone forgot to re-pin the bottle after the night's event and the guy cleaning the interior accidentally hit the button in the shop. Oops.
      "Excluding the possibility that a female Scandinavian Olympian was running around outside our house last night, what else might be a possibility?"
      If someone you know is afflicted with Dunning-Kruger, please help. #knowthecure
      @mbull | instagram #imhardlyeverserious
      __________________________________________ #srtallthethings
    10. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      17,704
      RS3, JKU
      09-10-2020 02:21 PM #109
      Quote Originally Posted by GreenandChrome View Post
      Back in my drag racing days in a former life my good friend had a seven second car and I used to pack his chute all the time (that sounds bad ).
      Basically there is a nylon bag type thing with four flaps that is secured to the mount. I guess it kind of looks like a flower with four pedals. There is a big spring which is compressed with the chute folded a certain way and then the flaps are folded over the chute and secured with the cable. So when the cable is pulled the spring fires the chute back out.
    11. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The Orange Crush
      41,851
      09-10-2020 02:26 PM #110
      i thought we were going to keep it a secret
    12. Member SchnellFowVay's Avatar
      May 20th, 2001
      Las Vegas, NV
      15,205
      09-10-2020 04:24 PM #111
      This is going in my sig shortly.
    13. Member Senior Member's Avatar
      Jul 1st, 2016
      Original Join Date 2001 Central NJ
      2,450
      OG 2001 Jetta 1.8t
      09-10-2020 07:39 PM #112
      Modern technology and drive by wire, everything is controlled by computer, the throttle, transmission, steering, brakes, etc.. A little of water or fire and the cars is done.
    14. Member
      Feb 12th, 2019
      280
      09-15-2020 02:15 PM #113
      I didn't hear if he had it pinned or not. Seems silly to leave it pinned if you are going to be doing high speed runs. But all of that stuff is silly/stupid anyway soooo yeah
      Boiler Up!
    15. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      17,704
      RS3, JKU
      09-15-2020 02:20 PM #114
      You're not going to use that ish on the street
    16. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere close to Lyon Mountain.
      24,288
      SR71 C30 t53a/b/b
      09-15-2020 04:09 PM #115
      Not if you fall off a cliff.
    17. Member
      Feb 12th, 2019
      280
      09-15-2020 05:27 PM #116
      hind sight 20/20
      Boiler Up!
    18. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      17,704
      RS3, JKU
      09-15-2020 05:36 PM #117
      hind sight 20/20
      Could you imagine someone pulling a parachute on the highway
      At the track he would have hit the sand pit at like 120+ mph with no brakes and no chute. On the street he coasted for like five miles and didn't hit anything at all
    19. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      16,986
      2004 E46, 2019 Q7, 2008 A6
      09-15-2020 06:01 PM #118
      If I was the passenger in that car it would have come to "You need to stop this f*cking car right now, stuff it, do something, or I'm about to start punching you in the ear until you do".
      Risking a life over saving an economy car? Get the f*ck out of here with that bullsh*t.
      Instagram - efrie004
      You take that fake rich sled back to the toothless masses and rub their stupid meth faces in your success. Do it for me.
    20. Member ohiodub_99.5's Avatar
      Jun 4th, 2007
      Cinci
      10,728
      2019 Alltrack, 2018 Tiguan
      09-15-2020 08:56 PM #119
      At the track his chute would have been prepped to deploy, and he’d have a chance of less damage to the car because there would have been appropriate safety equipment on hand to deal with said fire...
      not just one jackass with an extinguisher that looked like they got it in a happy-meal ...
      /| OMGHAI |\ GFG/Marrakesh/6-spd/S
    21. Learning New Things Every Day. GreenandChrome's Avatar
      May 24th, 2002
      15,935
      09-15-2020 09:40 PM #120
      Driver didn't want to "wreck the car." They had ample time to stop via steel-to-concrete friction. He was burning up and he says, "I'm looking for a good spot to pull over."
    22. Member rammalammadingdong's Avatar
      Mar 2nd, 2007
      Norf
      1,490
      One SUV, One CUV, One Hairdressermobile
      09-15-2020 09:57 PM #121
      ....or was making sure it burnt the f to the ground
      #conspiracytheories
      Make insurance claims great again!
    23. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      16,986
      09-16-2020 10:33 AM #122
      Exactly.
      Um, dude. You're car is f*cked.
      Now let's get out before we are as well.
    24. Member
      Dec 2nd, 2010
      2,007
      09-16-2020 10:46 AM #123
      I always thought the purpose of a drogue chute was not to primarily slow you down but to give you enhanced handling ability to keep you in a straight line when you let off when finishing a run. The drag lowers the amount of wiggle and lengthens the vehicle physics and keeps the rear wheels straight.
      This is also why i am decidedly not a fan of an electronic parking brake. I would rather have at least one fully analog cable safety system in case of a catastrophic failure like this, even though it was 99.9% user error in being in such a situation.
      Aug 5th, 2004
      So IN
      43,733
      '66 Beetle, '92 Ranger, '08 Fit
      09-16-2020 10:54 AM #124
      Quote Originally Posted by Aseras View Post
      Agreed on both counts, but the drag chute does double-duty in that regard.
    26. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      17,704
      RS3, JKU
      09-16-2020 11:09 AM #125
      That's somewhat true for a dragster with large bias ply tires on the rear but not so much with a car like this
