I believe the temp control button no longer works... these are electronic, right, there is an actuator which will move a slider inside the hot water circuit somewhere?
I thought initially that AC does not work, but it does, only it can't keep up with the heat... The air is just as hot no matter where you set the temp.
Any pointers before I split open the dash would be great...
