Fourtitude.com - VCDS Help
    Results 1 to 13 of 13
    Thread: VCDS Help
    1. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      15,870
      2004 E46, 2019 Q7
      06-29-2020 08:51 PM #1
      Car is 2008 C6 A6 3.2 Quattro.
      I've got a code on the dash for defective adaptive headlight. Headlights work, so with that being said is there a way to code it completely out? In other words, just turn off the adaptive headlights and make it stop monitoring the code? I can VCDS and this is the result for the fault.
      Address 55: Headlight Range Labels: 4F0-910-357.lbl
      Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
      Component: AFS 1 H01 0020
      Revision: 00000001 Serial number:
      Coding: 0000016
      Shop #: WSC 02325 785 00200
      VCID: 290FF81525F71333245-807C
      Subsystem 1 - Part No: 4F0 941 329 D
      Component: AFS-Modul links H01 0010
      Subsystem 2 - Part No: 4F0 941 329 D
      Component: AFS-Modul rechtsH01 0010
      1 Fault Found:
      02626 - Dynamic Cornering Light Motor; Right (V319)
      010 - Open or Short to Plus - MIL ON
      Freeze Frame:
      Fault Status: 11101010
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 236
      Mileage: 227368 km
      Time Indication: 0
      Date: 2020.06.29
      Time: 19:36:30
      Also, what does this result mean?
      Instagram - efrie004
      You take that fake rich sled back to the toothless masses and rub their stupid meth faces in your success. Do it for me.
    3. Member IdontOwnAVW's Avatar
      Jun 17th, 2004
      Wilmington DE
      7,219
      MK1TDI, BoltEV, G8GXP
      06-29-2020 08:55 PM #2
      Maybe post this in the right section?
      https://www.audizine.com/forum/forum...5-C6-A6-S6-RS6
      IG: @geeofff
      MK1 TDI Swap
    4. You can't look at my avatar for just a second, can you? Just Another Sweater's Avatar
      Aug 11th, 2002
      Southwest Ohio
      5,184
      GTI Sport 6M
      06-29-2020 08:56 PM #3
      From my experience with later cars, open address 55, click on coding. Do you see boxes that can be 'check marked'?
      Give me a few minutes, I'll grab my cable and try to walk you through this.
    5. Turtles walk slowly, but get angry fast! Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      8,559
      2019 Audi eTron, 2018 R8 RWS, 2002 Chevy 2500HD, 1988 16v Scirocco
      06-29-2020 08:57 PM #4
      Quote Originally Posted by IdontOwnAVW View Post
      He could also just go to
      https://lmgtfy.com/
    6. Millennial Pizza Cat's Avatar
      Dec 2nd, 2006
      Near McBanagon
      22,912
      North American German crap and German German crap
      06-29-2020 09:04 PM #5
      Right?
      Cmon noob.
      SS registry owner-emeritus
      Quote Originally Posted by Vee-Dubber-GLI View Post
      NATORabbitCat5PizzaSand
    7. You can't look at my avatar for just a second, can you? Just Another Sweater's Avatar
      Aug 11th, 2002
      Southwest Ohio
      5,184
      GTI Sport 6M
      06-29-2020 09:09 PM #6
      Open 55: Headlight range
      Click Coding-07
      Click Long coding helper
      You might see boxes, for my car I went to the fifth box (0B),
      Byte 4, Bit 1 Is this box 'Checked'? If so unchecking the box should turn off the dynamic cornering lights.
      Hope this helps.
      Edit: If this works you will also have to open 'Fault Codes-02' and clear the code. If the code keeps coming back then you'll need someone else to chime in.
    8. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      15,870
      2004 E46, 2019 Q7
      06-29-2020 09:25 PM #7
      I got it. Light is off.
      Thanks!
    9. You can't look at my avatar for just a second, can you? Just Another Sweater's Avatar
      Aug 11th, 2002
      Southwest Ohio
      5,184
      GTI Sport 6M
      06-29-2020 09:29 PM #8
      Thanks!
      Sweet. I'm glad it worked.
      Now scan your car for any other fault codes. Then save the fault scan for reference (it will save as a word document).
    10. How do I resize a picture? Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      15,870
      2004 E46, 2019 Q7
      06-29-2020 09:52 PM #9
      Quote Originally Posted by Just Another Sweater View Post
      There was a bit more to it, but overall not bad.
      https://www.audiworld.com/forums/www....php?t=2964755
    11. I’m not a loser. I’m a winnah!! patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      38,755
      made in ‘murica truck and wagon
      06-30-2020 08:55 AM #10
      Quote Originally Posted by Smooremin View Post
      https://lmgtfy.com/
      Quote Originally Posted by Pizza Cat View Post
      Right?
      Cmon noob.
      This what happens when you let mkIV kids have TCL access. Shut the gate.
      this signature kills fascists.
    12. Millennial Pizza Cat's Avatar
      Dec 2nd, 2006
      Near McBanagon
      22,912
      06-30-2020 09:31 AM #11
      I’d never subject myself to a Mk4, sir.
    13. Member Smigelski's Avatar
      Dec 9th, 2008
      Annapolis, MD
      8,367
      '19 Ridgeline, '19 Miata
      06-30-2020 09:44 AM #12
      Open the gate. A little.
    14. I’m not a loser. I’m a winnah!! patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      38,755
      06-30-2020 10:36 AM #13
      No but Erik did. And so did I.
      It was a decent car. But then again, it was after a mkIII VR6 and before a B5.5. And between Subarus 1 & 3 for that matter. It was a decent beater, just too small for newlyweds with a newborn.
