Fourtitude.com - Introducing The All-New 2021 Acura TLX - Type S
    Page 1 of 11 12345 ... LastLast
    Results 1 to 25 of 251
    1. 05-28-2020 01:58 PM #1
      https://www.acura.com/future-vehicles/2021-tlx
      May 28, 2020 — TORRANCE, CALIF.
      • 2021 TLX delivers on the muscular design and proportions previewed in the Type S Concept with a wide stance, low roofline and stretched wheelbase
      • With a standard 2.0-liter Turbo, TLX offers top of class power with 66 more horsepower and nearly 100 lbs.-ft more torque than the outgoing entry engine
      • Ultra-rigid new body structure and advanced new chassis with double-wishbone front suspension sharpens the reflexes of Acura's top-selling sedan
      • Arriving Spring 2021, TLX Type S debuts Acura's new 3.0-liter V6 Turbo engine and a first-for-Type S, Super Handling All-Wheel Drive™
      • Acura today revealed the quickest, best-handling and most well-appointed sedan in the brand's 35-year history – the all-new 2021 Acura TLX. With a model-exclusive body structure and chassis architecture, all turbo engine lineup, and an athletic stance with bold proportions, the new TLX delivers dramatic gains in both style and dynamic performance. The first Acura sedan fully designed around the brand's Precision Crafted Performance ethos, the 2021 TLX will arrive at dealerships early this fall with a manufacturer suggested retail price (MSRP) starting in the mid-$30,000 range.
      Next-Generation Design
      The 2021 TLX features an athletic and powerful exterior design with proportions, stance and silhouette heavily influenced by the Acura Precision Concept and faithfully translated from the Type S Concept. The new TLX's performance intentions are conveyed through its low and wide stance, long dash-to-axle ratio, expansive hood, tapered greenhouse and pronounced rear haunches. Relative to the previous model, the new TLX features a 3.7-inch longer wheelbase, 2.2-inch wider body with wider front and rear tracks (+1.2 in. and +1.6 in., respectively), lower roof (-0.6 in.) and an extended dash-to-axle dimension (+7.8 in.).
      At the front, a bolder and more upright diamond pentagon grille is flanked by signature, next-generation Acura lighting cues previewed in the Type S Concept. These include new Jewel Eye® LED headlights with four LED elements and bright-white "Chicane" LED daytime running lights inspired by the championship-winning Acura ARX-05 Daytona Prototype race car.
      The sedan's sleek and dynamic side profile uses sheer, angled surfaces to create strong light-and-shadow contrasts and to accentuate the sedan's muscular rear wheel arches, which lead into a rear section featuring a shorter overhang, upswept rear decklid, "Chicane" LED taillights and exposed dual exhaust outlets.
      The neatly tailored cabin section is set farther back on the body and features more steeply inward-sloping roof pillars to further emphasize the TLX's muscular low and wide stance. The roof itself has been sculpted with a lower-set center section, defined by two inward curving grooves, for a more distinctive look that conveys a sense of movement and lower appearance.
      A-Spec: Sport Package
      Acura's highly popular A-Spec sport package continues, adding distinctive sport appearance upgrades inside and out. Unique exterior A-Spec features includes Shark Grey 19-inch wheels, gloss black accents front to rear, darkened headlight and taillight treatment, and a pronounced rear decklid spoiler.
      Type S: High Performance Variant
      Arriving spring 2021, the TLX Type S builds upon the A-Spec styling elements, elevating TLX's sporty appearance even further. At the front, a unique open-surface Diamond Pentagon grille and larger side air intakes feed an all-new powerful V6 turbo engine developed for Acura Type S models. Aerodynamic elements include a rear decklid spoiler, aggressive front splitter and rear diffuser, and large quad exhaust outlets that harken back to the 2007-2008 TL Type S. Two exclusive 20-inch wheels designs will be offered, a split-10 spoke design from the Type S Concept and an NSX-inspired lightweight "Y-Spoke" wheel, both wrapped in 255-series performance rubber. More details on the TLX Type S will be released closer to its on-sale date in the Spring of 2021.
      Exclusive New Body and Chassis
      The 2021 TLX is a sport sedan at its core, built on a new dedicated Acura sedan platform designed for Type S-levels of performance. The new chassis heralds the return of double-wishbone front suspension to Acura's top-selling sedan, offering more precise handling and cornering grip, as well as greater mechanical compliance for improved ride quality. In addition, the TLX chassis incorporates multiple new performance-focused engineering upgrades, including a variable-ratio steering system, electro-servo brake-by-wire technology applied from the NSX and an available driver selectable Adaptive Damper System.
      The TLX's all-new chassis is anchored to an advanced new body structure — NSX aside, the most rigid ever offered on an Acura vehicle— delivering a 50 percent increase in global torsional stiffness and up to a 100 percent improvement in localized rigidity where the suspension is mounted to the body. The new structure uses 56 percent (by weight) advanced, lightweight materials, including aluminum and press-hardened steel, more than any previous Acura sedan.
      An ultra-rigid new center tunnel serves as the backbone of the TLX's higher structural rigidity, complimented by triangulated front shock tower bars, front and rear underfloor braces, a one-piece rear bulkhead stiffener and new cast-aluminum front shock tower mounts. Front-to-rear weight balance is also improved by an extensive use of aluminum, including the front bumper, hood, front fenders and front damper mounts, in addition to locating the 12-volt battery in the trunk.
      NSX Electro-Servo Brakes
      First developed for the second-generation NSX, the new TLX utilizes a highly sophisticated electric-servo brake system. This system allowed Acura engineers to finely tune the brake pedal force and electronically control the brake pressure to optimize the vehicle's performance driving characteristics.
      For the TLX Type S, multiple hardware upgrades will improve braking performance, including larger discs and four-piston Brembo® front calipers complemented by performance-focused tuning of the entire braking system.
      Wheels and Tires
      The TLX's athletic stance is grounded by larger standard 18-inch (+1-in.) wheels and available 19-inch wheels in various finishes, depending on trim. Performance-tuned 255-series rubber provides 20 percent more lateral grip than the outgoing tires.
      TLX Type S models will be equipped with 20-inch split-10 spoke alloy wheels finished in Shark Gray. An optional lightweight wheel inspired by the NSX "Y-spoke" design will be offered alongside a high-performance summer tire, further increasing grip while reducing unsprung mass.
      Two High-Output Turbo Powertrains
      The new TLX will offer two, powerful and high-torque turbocharged engines.
      Standard power comes from a 2.0-liter DOHC, direct-injected and turbocharged engine with VTEC, mated to Acura's incredibly responsive 10-speed automatic transmission with Sequential SportShift. With peak output of 272 horsepower and 280 lb.-ft. of torque (SAE Net), the TLX's 2.0-liter turbo boasts the highest horsepower in its core competitive set, delivering dramatic gains in horsepower (+66) and torque (+98 lb.-ft. at peak, +123 lb.-ft. at 1,500 rpm) when compared to the previous model's naturally aspirated 2.4-liter 4-cylinder. Compared to the previous TLX's optional 3.5-liter V6, the new 2.0-liter turbo delivers an additional 13 lb.-ft. of peak torque, as well as an additional 48 lb.-ft. at 1,500 rpm.
      When it arrives in spring 2021, the TLX Type S will deliver power from an all-new 3.0-liter, 24-valve, DOHC direct-injected and turbocharged engine developed by some of the company's most experienced powertrain engineers, including members of the team that developed the NSX's bespoke twin-turbocharged V6 hybrid power unit. The new transverse-mounted V6 will be highly compact and lightweight, utilizing a dual scroll turbocharger and electronic wastegate to deliver immediate, high-torque response. Compared to the outgoing, naturally aspirated 3.5-liter V6, the new engine delivers dramatic gains in peak horsepower and, more critically, in torque, across the engine's full operating range, including a more than 50-percent increase in low-end torque. Final specifications for the new engine, including power output, will be released closer to launch timing.
      Acura's 10-speed automatic, with Sequential SportShift and standard paddle shifters, takes full advantage of both turbocharged engines' high-torque output, offering a wider ratio range, more discrete gears, four-gear direct downshifts and a lower first gear compared to the previous 8-speed dual-clutch and 9-speed automatic transmissions. Type S models will receive unique transmission tuning to provide an aggressive and responsive characteristic during performance driving scenarios.
      Torque Vectoring SH-AWD®
      Superior handling capabilities are now offered on all TLX models with the available rear-biased Super Handling All-Wheel Drive™ (SH-AWD®), Acura's industry-leading torque-vectoring all-wheel drive technology. SH-AWD is offered as optional equipment on the 2.0-liter TLX and as standard technology on the TLX Type S, the first Type S model to feature all-wheel drive.
      Acura's 4th-generation SH-AWD® system has 40 percent more rear torque capacity and 30 percent quicker front-to-rear torque transfer than the 3rd-generation system in the outgoing TLX. The Acura SH-AWD® system in the new TLX transfers up to 70 percent of engine torque to the rear axle during normal driving conditions, while continuously apportioning up to 100 percent of that rear-axle torque between either the left and right rear wheels. Additionally, the rear axle is continuously overdriven by 2.9 percent, which amplifies the yaw moment effect of left-to-right torque transfer, elevating performance through sharper and more accurate turn-in, and improved traceability when cornering.
      Driver-focused, Premium Cockpit Design
      The 2021 TLX's more premium, personal and tech-focused cabin takes inspiration from the Acura Precision Cockpit's intuitive functionality and flowing lines. Designed around the desires of today's luxury sport sedan enthusiasts, the TLX is tastefully appointed with available authentic, high-grade materials including real aluminum, open-pore wood and full-grain Milano leather.
      Developed under the theme of "Dual Personal Cockpit," the sedan's new, more luxurious interior places a strong emphasis on the driver and front-seat passenger. The TLX's high and wide center tunnel and wrap-around instrument panel create a more personal and strongly delineated space for both front-seat occupants, while its wider body design enables true first-class seating comfort for both, with top-of-class hip and shoulder room (+0.5 in. and +0.7 in., respectively).
      Both the driver and front passenger also benefit from the tailored design of Acura's advanced front sport seats, highly customizable with up to 16-way power adjustability. For the driver, a stout leather-wrapped steering wheel, clean and clear instrumentation, and improved forward visibility serve as the foundations for an in-command and exhilarating driving experience.
      A-Spec and Type S models feature unique details throughout the cabin, including a thick-rimmed, flat-bottom steering wheel wrapped in perforated leather with contrast stitching and larger metal-plated paddle shifters. In addition to unique materials and colors, the TLX Type S interior is distinguished by Type S badging on the door sills, steering wheel and embossed headrests.
      Intuitive Technology and Connectivity
      The 2021 TLX also incorporates a full array of Acura technologies designed for enhanced comfort, connectivity and audio entertainment, starting with a new implementation of Acura's innovative and driver-oriented True Touchpad Interface™. This system features a high-mounted 10.2-inch HD display and a console mounted touchpad with "Absolute Position" mapping. For more intuitive control, the TLX's upgraded interface features physical Power, Volume and Seek controls positioned within easy reach to the immediate right of the touchpad. Utilizing the latest True Touchpad Interface software, the TLX offers more accurate swipe zones and handwriting recognition, as well as other performance enhancements. In addition, an ergonomically friendly wrist rest provides an anchor point for operation of the touchpad.
      The 2021 TLX features a standard 7-inch full-color Multi-Information Display (MID) in the center gauge cluster and an available 10.5-inch full-color Head-Up Display (HUD). The available award winning Acura ELS STUDIO 3D® premium audio system features four ultra-slim Highline™ ceiling-mounted speakers as well as a new Twin Telford™ subwoofer design.
      The new TLX also features the latest generation of AcuraLink™ with in-vehicle 4GLTE Wi-Fi, over-the-air software update capability and a wide array of available cloud-based services, including emergency roadside assistance, remote locking/unlocking and engine start, stolen vehicle tracking, remote diagnostics, geofencing, speed tracking and Acura concierge services.
      Color and Trims
      The new TLX will feature an expanded color palette with nine exterior finishes including five premium colors. New to the TLX for 2021 is a distinguished Phantom Violet Pearl. The TLX Type S will be offered in an exclusive, bold Tiger Eye Pearl. Apex Blue Pearl, previously available only on A-Spec models, will be added to the Type S catalog.
      A total of seven interior color options will be offered on the 2021 TLX. Ebony, Espresso, Graystone and Parchment will be offered on the standard TLX models, depending on trim. TLX A-Spec and TLX Type S models will feature either Ebony or Red Leather, both with black Ultrasuede® inserts. Additionally, the TLX Type S will offer an exclusive Light Orchid leather interior option.
      Further enhancing the driving environment, the new TLX features available ambient LED lighting throughout the cabin. The new system provides a unique interior ambient lighting scheme that changes with each driving mode (Comfort, Normal, Sport), as well as 24 selectable interior lighting schemes, each named after an iconic performance driving destination or track, such as "Pacific Coast" and "Suzuka".
      Customizable Driving Performance
      The 2021 TLX provides for a more versatile and personalized driving experience through the use of Acura's Integrated Dynamics System, now featuring an Individual Mode. As before, the system integrates a multitude of powertrain and chassis systems, accessed via the drive mode dial prominently positioned on the center console. Comfort, Normal and Sport modes (and Sport+ on TLX Type S) incrementally dial up the sporting reflexes of the TLX using pre-set programs for the Drive-By-Wire™ throttle, transmission, SH-AWD®, electric power steering, available Adaptive Dampers and more.
      An Acura-first, the 2021 TLX will feature an Individual Mode, activated by pushing the Acura logo at the center of the drive mode dial. The new Individual Mode provides for discrete control of all the same features, enabling the driver to choose their preferred individual settings for each element of system control.
      Advanced Safety and Driver-Assistive Technologies
      All 2021 TLX models will come equipped with the AcuraWatch™ suite of advanced safety and driver-assistive technologies standard. This includes several new features, such as Traffic Sign Recognition (TSR), Driver Awareness Monitor and Traffic Jam Assist (TJA). Working in conjunction with Adaptive Cruise Control with Low Speed Follow, Traffic Jam Assist helps reduce driver stress in highly congested traffic situations by helping keep the vehicle in its lane and at a set interval behind a car detected ahead.
      Additionally, the 2021 TLX features the first-ever application of the company's new front passenger airbag technology. This new proprietary airbag uses a three-chamber design that functions much like a baseball catcher's mitt, designed to more effectively cradle, and helping to protect the front seat occupant's head to help mitigate potential injury in more steeply angled frontal collisions.
      The new TLX also delivers advanced levels of passive safety (collision protection) performance through the use of Acura's proprietary Advanced Compatibility Engineering™ (ACE™) body structure, which has been further refined to provide additional occupant protection in a wider range of collision scenarios. Additional structural safety features include ultra-high-strength-steel one-piece door rings and an ultra-stiff center tunnel that helps optimize the absorption and direction of collision forces around the cabin.
      Design, Development and Manufacturing
      Design, engineering and development of the 2021 Acura TLX was conducted primarily in America. Styling was led by Acura Design in Torrance, Calif., while full platform development was led by engineers in the company's development center in Raymond, Ohio. Engineering development of the new 3.0-liter turbocharged V6 was led by the company's R&D center in Tochigi, Japan.
      The new TLX will be manufactured exclusively at the company's Marysville, Ohio, plant using domestic and globally sourced parts. The TLX's 2.0-liter and 3.0-liter turbocharged engines will be produced exclusively at the company's Anna, Ohio, engine plant, also home to the twin-turbocharged V6 hybrid power unit in the Acura NSX supercar. The 10-speed automatic transmission will be manufactured exclusively at the company's Tallapoosa, Georgia, plant, and the SH-AWD® system's front power takeoff unit and rear differential will be manufactured in the company's Russells Point, Ohio, plant
    3. 05-28-2020 02:00 PM #2
      Jul 25th, 2004
      Denver/Frankfurt
      2,720
      05-28-2020 02:01 PM #3
      We need those 3.0L specs! Hopefully 400/400.
      19 Mini Cooper S Countryman ALL4 6MT JCW Tuning Kit
      18 BMW X3 M40i
      17 Volvo XC90 T6 Inscription P*
    5. Member
      Jun 17th, 2014
      Florence Y'all
      1,800
      05-28-2020 02:05 PM #4
      Interesting that the 3.0 only mentions one turbo. Hot Vee? That might mean they're targeting S4/C43/340i levels of power so more like 350 to 380 rather than 400. Also not sure how I feel about brake by wire.
    6. Senior Member Lwize's Avatar
      Dec 4th, 2000
      Los Angeles
      28,256
      15 Rav4
      05-28-2020 02:06 PM #5
      Mazda tail lights?
      Looks good for a sedan no one will buy.
      Save the V6 for the next crossover.
      YouTube is not a medical device.
    7. 05-28-2020 02:12 PM #6
    8. Member CostcoPizza's Avatar
      Jan 20th, 2008
      USA
      6,918
      '12 MINI Clubman S '99 BMW 328ic
      05-28-2020 02:13 PM #7
      Looking forward to more V6 specs, Honda's sixes usually make pretty good noises to boot.
      Also, side note: Was the 8 speed DCT only used by the ILX and TLX? The former on it's last legs, the latter now using a 10AT.
      Seems like a lot of resources for a dedicated transmission used by two average selling cars!
    9. Member vwpiloto's Avatar
      Nov 26th, 2006
      Orange County, CA
      12,173
      1987 944 S, 2003 S2000, 2011 E90 M3, 2013 Mazda 3, 2014 4Runner Trail
      05-28-2020 02:18 PM #8
      The first mainstream Acura that I've liked in a long time (loved the Legends back in the day). It's not great, but it's very good, especially given the pedestrian impact requirements of today. It never ceases to amaze what that dash to axle ratio (prestige gap) does for design. Good proportions are key, and this has that.
      I do hate seeing Acura double down on that infotainment though, much like Lexus has with theirs. Either do a rotary knob, or make it a touchscreen, or both. Enough with the nonsense of trying to be unique at the expense of poor UX.
    10. 05-28-2020 02:24 PM #9
      I like the exterior, but the interior...
    11. Senior Member Mazda 3s's Avatar
      Nov 12th, 2003
      Garner, NC
      23,430
      2017 Audi A4 Quattro Prestige, 2017 Subaru Outback 2.5i Limited
      05-28-2020 02:24 PM #10
      So much want!!!!!!
      "Of course that's just my opinion; I could be wrong."
      Quote Originally Posted by The Igneous Faction
      Have you ever popped the hood on a powerstroke E350?
      Quote Originally Posted by WhistlerYOW
      No, I got good grades in school
    12. Member Uber Wagon's Avatar
      Dec 8th, 2003
      Pickup Truck Capital, USA
      15,714
      Audi e-Tron, BMW X3, and a Toyota appiiance
      05-28-2020 02:26 PM #11
      Nice! I applaud Acura for not abandoning the sedan segment. The new TLX should do well in market filled with ho-hum luxury sedans.
      Beer: The cause of, and solution to, all of life's problems.
    13. Member Unilateral Phase Detractor's Avatar
      Aug 23rd, 2005
      Columbus, Ohio
      13,810
      05-28-2020 02:58 PM #12
      Quote Originally Posted by vwpiloto View Post
      Quote Originally Posted by vb22 View Post
      Yeah, Honda used to be so good at useable driver interfaces years ago. This is still terrible.
    14. Member MrKevkevL's Avatar
      Nov 6th, 2009
      Philly Burbs
      1,954
      B9 Audi A4 Quattro P+/W205 Mercedes-Benz
      05-28-2020 02:59 PM #13
      Much better than the current generation TLX. Still wouldn't buy one though. Interior is a bit too busy for my taste and that exterior wouldn't look out of place with a Honda badge.
      Past: 1999.5 MKIV VW GTI, 2009 MKV Jetta, 2009 MKV Golf, 2007 B7 Audi A4, 2014 F30 BMW 328i, 2015 8V Audi A3, 2017 MK7 VW GTI
      Quote Originally Posted by Roketdriver View Post
      Toyota is kind of like the Black Eyed Peas. The majority of their product line is cars for people who don't like cars.
    15. Member vwpiloto's Avatar
      Nov 26th, 2006
      Orange County, CA
      12,173
      05-28-2020 04:27 PM #14
      Quote Originally Posted by MrKevkevL View Post
      Definitely way too busy. The central "mode selector" sort of makes more sense here than in the RDX, but I still think it's silly to have the mode selector be front and center, when it's something that's least used. It just sends a confusing message to the average buyer, imo.
      In any case, the materials shown, and the general design seems far less premium than anything we're seeing from comparable Audi, BMW, MBZ, Genesis, and Volvos. It's more in line with Lexus, but that's not the benchmark to works towards, imo. Not for appearance, feel, and ergonomics anyway.
    16. Member landstuhltaylor's Avatar
      Jul 21st, 2011
      CBUS
      1,669
      13 Golf TDI, 09 Speed Triple, 06 RX8, 02 M3, 98 C2500, 94(98) CP Camaro
      05-28-2020 04:33 PM #15
      Subscribing just because I enjoy watching the public speculate
    17. Member TangoRed's Avatar
      Sep 7th, 2005
      Seattle, WA
      12,296
      05-28-2020 04:50 PM #16
      That's where I'm at.
      Quote Originally Posted by Doug Butabi View Post
      And on the tenth day of the two thousand fifteenth year, TCL finds out about rich people.
    18. 05-28-2020 05:00 PM #17
      I dig it. This is the first Acura sedan in years that I've liked. We have a '19 RDX. The UX is a little ridiculous but it is pretty easy to use. It's pretty quick after it boots up and you get access to the screen. I'm usually at the end of my driveway by the time it's ready for me to do something with. It's annoying but not a dealbreaker. We usually only have it on XM anyway, so it's not a huge deal to us. I like the interior and it looks very much like the RDX. And I agree, the drive mode switch feels awkward and the PRND button selectors suck. I seriously hate it. But then again, I hate the one in our Mercedes too. I liked the old setup, but alas, I'm starting to sound old and crotchety. You get used to it and it's a minor annoyance.
      If it drives anything like the RDX, it'll be quite pleasant and "sporty". Let's face it, in today's world, we are downright spoiled with our cars. Having driven countless rentals and cars from every brand on the planet, they are all quite similar. Many family sedans would embarrass sports cars from the 80's. IDK, they are all starting to feel homogenous with very few things that separate them from each other -- other than looks. Even at that, looking at the side profiles, they all start to look similar too.
      So what am I saying? I like it. Would I ever buy one? No. Probably because I don't really want a sedan and we have no need for one. But if I were to look at sedans again, this would be on my list of cars to test drive and consider. I'm glad they are producing it and I hope it's a success for them though.
    19. 05-28-2020 05:21 PM #18
      A nice, thoughtful response BAO; I wouldn't mind getting back into a sedan like this, but while currently owning a small SUV and an Alltrack, if I can't throw a bike in the back, even with the front wheel off, I'm not too interested. I prefer not to use racks and would rather throw my bike inside the car. That's not to say it can't be done in a sedan -- I was able to fit a Fat bike in the back of an '02 Passat sedan with the front wheel off, but it's just a lot harder. I guess what I'm trying to say is that the only sedans that interest me anymore are sedans with a hatch like the Arteon, Stinger or A5, A7, though the latter two are a little out of my price range. Too bad really, this Acura looks like a hell of a car.
    20. Member
      Jul 17th, 2006
      4,364
      Ram & S4
      05-28-2020 05:50 PM #19
      Quote Originally Posted by Lwize View Post
      Mazda tail lights?
      I see ILX tail lights.
      I'm happy to see Acura stay in the sedan segment, the Germans can't have all the fun.
    21. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      24,808
      VWs & Audis
      05-28-2020 05:57 PM #20
      I'll admit, it does look good. Still can't see people buying them though.
      Dave
    22. Member
      Jan 18th, 2018
      6,854
      '16 TLX SH-AWD- NA is BEST
      05-28-2020 06:06 PM #21
      Quote Originally Posted by JitteryJoe View Post
      I thought this was interesting too. I was told that a 60 degree vee was too narrow for a hot vee setup. This might be the start of the end for the J series. Will be interesting to see how they deal with heat. That has always been a pain point for hot vee setups.
      This looks good. I have no interest in replacing my TLX with another sedan but I won't lie.... I'm looking at my TLX differently lol. We'll see if this delivers on its promises.
      Quote Originally Posted by QUIRKiT View Post
      I spent my entire season budget during the off-season on go fast parts, so now I'm wishing I hadn't and had saved a little so I could buy a sim rig.
    23. Member BlakeV's Avatar
      Oct 24th, 2015
      Original join 1999
      2,144
      2019 Audi S5 Sportback
      05-28-2020 06:15 PM #22
      The wait was very very long, it sounds like it was worth it. Some reserves for that dash, hopefully it is better in person.
    24. Member GTijoejoe's Avatar
      Oct 5th, 2001
      8,073
      '06 Evo Mr, '18 Accord Sport
      05-28-2020 06:36 PM #23
      Quote Originally Posted by CostcoPizza View Post
      I believe you are correct, that 2.4L NA matted with the 8DCT... probably engine power/tq reason it was not used else were, like the Civic Si or something which would make it cool for the chicks
      The V6 uses a ZF 9spd.
      Brake by wire got all the rave on the NSX if I recall. Porsche was very interested when it was presented at the SAE Brake Colloquium because of its capability with performance hybrid technology.
      I do like that they finally offer the lower grade model with SH-AWD.
      2.0T+034efi+meth = 300+whp = RIP
      Quote Originally Posted by Ryukein View Post
      Everyone always praises function over form until the form is something that they don't like
    25. 05-28-2020 06:44 PM #24
      I'd put money on Acura not being around in 5 years.
      They dont exist outside NA, and this, along with most of their lineup could just be a Honda.
      He who dies with the most toys wins..........I'm losing, but having fun keeping up
      similar is subjective. a bj from a chick and a bj from a dude are also similar
    26. 05-28-2020 07:27 PM #25
      Quote Originally Posted by VYLENT View Post
      MDX has a cult following with soccer moms, its not going anywhere
