Fourtitude.com - Mk6 Golf R Electronic Issues after WMI install
    Results 1 to 9 of 9
    1. n00b
      Nov 18th, 2017
      Seattle
      7
      2012 VW Golf R
      05-23-2020 02:32 AM #1
      I recently installed an Aquamist WMI kit recently and ever since the install i've been having issues. As a side note, this kit was heavily involved and required a lot of disassembly. I noticed my radio wasn't working so checked fuses and ran a scan, these were the results. My car was clear of all codes except for P2184 prior to the install. I'm at a loss and new to this community so any pointers/help would be greatly appreciated. Thanks!
      Code:
      Tuesday,19,May,2020,11:25:29:40752
      VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
      VCDS Version: 20.4.1.0 (x64)
      Data version: 20200331 DS317.0
      VIN: WVWPF7AJ7CW328644   License Plate:
      Mileage: 122440km-76080mi   Repair Order:
      Chassis Type: AJ-VW36 (7N0)
      Scan: 01 03 08 09 15 16 17 19 1C 22 25 2E 42 44 46 52 55 56 62 72
                77
      VIN: WVWPF7AJ7CW328644   Mileage: 122440km-76080miles
      01-Engine -- Status: Malfunction 0010
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: Malfunction 0010
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: Malfunction 0010
      1C-Position Sensing -- Status: OK 0000
      22-AWD -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      2E-Media Player 3 -- Status: Cannot be reached 1100
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      55-Headlight Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      77-Telephone -- Status: Malfunction 0010
      Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
         Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
         Component: 2.0l R4/4V TFSI     0020
         Revision: 5BH21---    Serial number:
         Coding: 0403010A180F0160
         Shop #: WSC 66565 257 00032
         VCID: 346699D057A45F26DF-8060
      1 Fault Found:
      008580 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                     P2184 - 001 - Signal too Low
                   Freeze Frame:
                          Fault Status: 01100001
                          Fault Priority: 2
                          Fault Frequency: 1
                          Reset counter: 255
                          Mileage: 122427 km
                          Time Indication: 0
                          Date: 2014.10.09
                          Time: 00:37:13
                   Freeze Frame:
                          RPM: 0 /min
                          Load: 0.0 %
                          Speed: 0.0 km/h
                          Temperature: 35.0°C
                          Temperature: 19.0°C
                          Absolute Pres.: 980.0 mbar
                          Voltage: 11.811 V
      Readiness: 0010 0100
      Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
         Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
         Component: ESP MK60EC1   H31 0121
         Revision: 00H31001
         Coding: 144B800C49248002281101E8921D0141B70000
         Shop #: WSC 01357 011 00200
         VCID: 7BF472ECFA7A505E5E-802E
      No fault code found.
      Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
         Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
         Component: Climatronic   H18 1112
         Revision: 00001004
         Coding: 0000001002
         ASAM Dataset: EV_Climatronic A01010
         ROD: EV_ClimaAutoBasis_VW36.rod
         VCID: 73E45ACCDA2A181E06-8026
      1 Fault Found:
      9480469 - Control Circuit for A/C Compressor
                B10A9 15 [009] - Open or Short to Plus
                Confirmed - Tested Since Memory Clear
                   Freeze Frame:
                          Fault Status: 00000001
                          Fault Priority: 2
                          Fault Frequency: 1
                          Reset counter: 85
                          Mileage: 122446 km
                          Date: 2020.05.19
                          Time: 23:15:43
      Address 09: Cent. Elect.
      Cannot be reached
      Unable to communicate with address 09. Are you sure the doors are unlocked?
      Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
         Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
         Component: AirbagVW10G   013 0724
         Serial number: 003GVRA21Z3%
         Coding: 00003131
         ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
         ROD: EV_AirbaVW10SMEVW360.rod
         VCID: 3F8CC6FCA6E28C7E32-806A
         Seat occupied recognition:
         Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
         Component: BF-Gewichtss.  006 0001
         Serial number: ---0000R--000040P600
         Crash sensor for side airbag: driver side:
         Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
         Component: S.Sens.Fahr.V  H01 ----
         Serial number: 3572MSME1425246CZZZT
         Crash sensor for side airbag: front passenger side:
         Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
         Component: S.Sens.Beif.V  H01 ----
         Serial number: 3582MSME4719626CZZZ+
         Crash sensor for side airbag: rear: driver side:
         Component: S.Sens.Fahr.H  --- ----
         Serial number: 3512QSME7E410F06ZZZ
         Crash sensor for side airbag: rear: passenger side:
         Component: S.Sens.Beif.H  --- ----
         Serial number: 3522QSME624C0E44ZZZ
         Crash sensor for front airbag: driver side:
         Component: F.Sens.Fahr  --- ----
         Serial number: 35527SME624A732FZZZP
         Crash sensor for front airbag: front passenger side:
         Component: F.Sens.Beif  --- ----
         Serial number: 35627SME742C712BZZZN
      Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
         Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
         Component: Lenks.Modul   008 0080
         Revision: --------    Serial number:  90422LDB000EP
         Coding: 1082140000
         ASAM Dataset: EV_SMLSNGKUDS A05001
         ROD: EV_SMLSNGKUDS_A05.rod
         VCID: 72EA5FC8A53011160D-8026
         Multifunction steering wheel control module:
         Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
         Component: E221__MFL-TAS  H31 0033
         Serial number: 0021881
         Coding: 820000
      Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
         Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
         Component: KOMBI         H04 0617
         Serial number: 00000000000000
         Coding: 270F01
         ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
         ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
         VCID: 387EADE083CCBB46F3-806C
      Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
         Part No SW: 7N0 907 530 M    HW: 1K0 907 951
         Component: J533  Gateway H42 1623
         Revision:   H42       Serial number: 120412F2001548
         Coding: 350002
         VCID: 3A7AB7E8B5C0A95605-806E
      1 Fault Found:
      03272 - Control Module for Audio Interface
                  004 - No Signal/Communication
                   Freeze Frame:
                          Fault Status: 01100100
                          Fault Priority: 2
                          Fault Frequency: 1
                          Reset counter: 85
                          Mileage: 122446 km
                          Time Indication: 0
                          Date: 2014.10.10
                          Time: 23:15:48
      Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
         Part No SW: 5N0 919 879     HW: 5N0 919 879
         Component: Kompass         002 0002
         Revision: 00002000    Serial number: 1225223RHPHN07
         Coding: 0000002
         VCID: 7EF27BF82968457679-802A
      Address 22: AWD        Labels: 0AY-907-554-V1.clb
         Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
         Component: Haldex 4Motion      3018
         Coding: 0000005
         Shop #: WSC 00000 000 00000
         VCID: 4580D4140C3ED6AE78-8010
      Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
         Part No SW: 5K0 953 234     HW: 5K0 953 234
         Component: IMMO          H04 0617
         Coding: 000000
         ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
         ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
         VCID: 6ADA47A88DE0D9D6B5-803E
      Address 2E: Media Player 3
      Cannot be reached
      Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
         Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
         Component: Tuer-SG         009 2105
         Coding: 0001204
         VCID: 377CAEDC46D2B43EFA-8062
      Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
         Part No: 1K0 909 144 P
         Component: EPS_ZFLS Kl. 251    3305
         Revision: 00H22000
      Address 46: Central Conv.
      Cannot be reached
      Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
         Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
         Coding: 0001204
         VCID: 387EADE04BCCBB46F3-806C
      Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
         Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
         Component: AFS-Steuergeraet    0148
         Revision: 00H04000    Serial number:
         Coding: 1479708
         Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
         Component: AFS-Lst.-Modul l    0005
         Coding: 00000022
         Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
         Component: AFS-Lst.-Modul r    0005
         Coding: 00000022
      Address 56: Radio        Labels: None
         Part No SW: 3TD 035 156     HW: 3TD 035 156
         Component: RadioSK46MID  006 0010
         Coding: 01000424041000
         Shop #: WSC 00078 790 00000
         VCID: 7F0C86FCEE624C7E72-802A
      Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
         Part No SW: 5K0 959 703 D    HW: 5K0 959 703 D
         Component: Tuer-SG         007 2101
         Coding: 0001168
         Shop #: WSC 01357 011 1012552
         VCID: 3560A4D45CDE462EE8-8060
      Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
         Part No SW: 5K0 959 704 D    HW: 5K0 959 704 D
         Coding: 0001168
         VCID: 3662A3D841D84D36E1-8062
      Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
         Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
         Component: TELEFON       H09 2902
         Revision: 1B001001    Serial number: 00007662287119
         Coding: 0A10040000010100
         ASAM Dataset: EV_UHVNA A01719
         ROD: UHVNA.rod
         VCID: 275C7E9C5E7224BE6A-8072
      2 Faults Found:
      9457427 - Left audio channel for speech/telephone
                B104F 13 [009] - Short to GND
                   Freeze Frame:
                          Fault Priority: 4
                          Fault Frequency: 1
                          Reset counter: 85
                          Mileage: 122446 km
                          Date: 2020.05.19
                          Time: 23:15:41
      9457171 - Right audio channel for speech/telephone
                B104E 13 [009] - Short to GND
                   Freeze Frame:
                          Fault Priority: 4
                          Fault Frequency: 1
                          Reset counter: 85
                          Mileage: 122446 km
                          Date: 2020.05.19
                          Time: 23:15:41
      End-------------------------(Elapsed Time: 02:35)--------------------------
    3. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      678
      MK6 Golf R
      05-23-2020 06:36 AM #2
      Interesting I havent had any issues but where are you tapping the fuse box for power?
      MK6 R
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
    4. n00b
      Nov 18th, 2017
      Seattle
      7
      2012 VW Golf R
      05-23-2020 01:15 PM #3
      I tapped into the red/green wire on pinout 3 which is 12V SW
    6. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      678
      MK6 Golf R
      05-23-2020 05:52 PM #4
      Do you remember what that fuse is used for in the system? Maybe disconnect that temporarily and see if you still get the electrical issues after clearing the codes
      MK6 R
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
    7. n00b
      Nov 18th, 2017
      Seattle
      7
      2012 VW Golf R
      05-23-2020 06:52 PM #5
      It came with its own fuse, so I didn't tap into the fusebox. I'd post a link but fourms aren't letting me.
    8. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      678
      MK6 Golf R
      05-23-2020 08:02 PM #6
      I know theres a fuse on my kit for the setup but also i used a fuse tap in a specific location on the drivers inside fusebox for that 12v switched power. Where is your power source coming from
      MK6 R
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
    9. n00b
      Nov 18th, 2017
      Seattle
      7
      2012 VW Golf R
      05-23-2020 10:37 PM #7
      It taps into my Headlamp switch and ECU wires for power
    10. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      678
      MK6 Golf R
      05-24-2020 01:12 AM #9
      Interesting thanks for the diagram. Assuming its hooked up right maybe contact aquamist?
      MK6 R
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
