Fourtitude.com - 12v VR6 Rebuild Problems
    Results 1 to 4 of 4
    1. n00b Wolfdie's Avatar
      May 12th, 2015
      PA
      5
      2000 Jetta GLX VR6, 2001 Jetta 1.8t, 2006 Jetta TDI, 2016 Jetta Sport
      05-20-2020 01:50 PM #1
      Hey everyone. I have a 2000 12v VR6 Jetta that I did a lot of work on. New head gasket, timing chains, guides, and tensioners, valves, metal crack pipe and thermostat housing. Did a test fire with it yesterday (no front on car radiator or coolant in car) engine started shaking misfiring and backfiring out the intake. Took valve cover off and rechecked my timing top and bottom and it was still good . Also did a VCDS scan and this is what I got.
      Address 01: Engine Labels: 021-906-018-AFP.lbl
      Part No: 021 906 018 K
      Component: MOTRONIC ME7.1 G 6758
      Coding: 00033
      Shop #: WSC 06493
      VCID: 1675C610C193653B99E-5160
      12 Faults Found:
      16795 - Secondary Air Injection System
      P0411 - 35-10 - Incorrect Flow Detected - Intermittent
      16712 - Knock Sensor 1 (G61)
      P0328 - 35-10 - Signal too High - Intermittent
      16684 - Random/Multiple Cylinder Misfire Detected
      P0300 - 35-10 - - Intermittent
      16685 - Cylinder 1
      P0301 - 35-10 - Misfire Detected - Intermittent
      16689 - Cylinder 5
      P0305 - 35-10 - Misfire Detected - Intermittent
      16690 - Cylinder 6
      P0306 - 35-10 - Misfire Detected - Intermittent
      16686 - Cylinder 2
      P0302 - 35-10 - Misfire Detected - Intermittent
      17544 - Fuel Trim: Bank 1 (Add)
      P1136 - 35-10 - System too Lean - Intermittent
      16501 - Engine Coolant Temp. Sensor (G62)
      P0117 - 35-10 - Signal too Low - Intermittent
      17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-10 - - Intermittent
      16486 - Mass Air Flow Sensor (G70)
      P0102 - 35-00 - Signal too Low
      16497 - Intake Air Temp. Sensor (G42)
      P0113 - 35-10 - Signal too High - Intermittent
      Readiness: 0000 0000
      Please help
    3. 05-23-2020 06:15 PM #2
      Did you ever get this sorted out? To me it sounds like either you messed up the timing somewhere or possibly got your spark plugs wires wrong. Some of those codes are probably because of unplugged sensors if the front of the car is still off with no coolant.
      Sent from my Pixel 3 XL using Tapatalk
    4. n00b Wolfdie's Avatar
      May 12th, 2015
      PA
      5
      05-24-2020 12:56 PM #3
      Yep. Here I swapped the plugs for the Aux water pump and PCV heating element . Next time I do a job like this I am investing in paint markers to mark my plugs. Over all the engine runs great now. Just trying to sort out the brake error I have thats showing 3 bad ABS sensors or ABS pump
    6. Member Soren's Avatar
      Oct 31st, 2000
      Los Angeles
      3,046
      98 GTI VR6
      05-27-2020 10:12 PM #4
      Our abs boxes are notorious for getting broken solder joints or traces with the heat cycles and banging around over the years. If you’ve checked your sensors and connections it’s most likely the box. My 98 went bad at 7 yrs and I sent it to someone listing abs repair on eBay which worked and lasted a few years. Then I just ignored it for a few more. Sent it off to module masters last year after doing a little overhaul and deciding to make everything work. They warranty for 5 years and have been around a while so will prob honor it. Had it back in a little over a week including shipping. I think it was $100. Worth it since new is $$$ and junkyard ones will be in no better shape than ours.
