Fourtitude.com - Immo2 to Immo3 cluster upgrade, now airbag light is on.
    Results 1 to 4 of 4
    1. 05-17-2020 12:39 AM #1
      Hi, I upgraded cluster on MK4 golf 1999. New cluster is immo3 from vw Bora and airbag wiring is with 1 wire only. What options I have, IF i code it out, then i dont have any airbag light, which doesnt work as it needs to come on for warrant of fitness. Can I run wires from CEL light to light up extra LED which i can put where Airbag light sits?
      I found some people done it, but on Diesel cars thru glow plug LED. Does anyone know if I use positive side from CEL led and then negative from blue connector, is it correct way?
      Cheers.
    3. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      1,169
      Jetta TDI 2006 with MK6 cluster & Golf TDI 2004 with MFA cluster
      05-29-2020 02:16 AM #2
      1999 has None Can Bus cluster VS Immo 3 has Can Bus cluster , So it is not just simple as you think to do this modification.
      Are you in USA and have USA 99 model?
      My Jetta TDI MK5 with MK6 Color cluster
    4. 06-02-2020 01:18 AM #3
      in New Zealand.
    6. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      1,169
      06-02-2020 10:09 AM #4
      Quote Originally Posted by mikk1000 View Post
      in New Zealand.
      Ok, Can you post part number of original Cluster ?
