Hello guys. Maybe someone had similiar problems with mine, and know how to fix it? Any suggestions?
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 HW: 5WK 470 22
Component: Kessy 6700
Revision: 67005614 Serial number: VWZ3Z0E3399463
Coding: 0217324
Shop #: WSC 01065 000 00000
VCID: 64C6940CA45BBE660E-5178
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
001 - Upper Limit Exceeded
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
00165 - Switch for Transmission Position P/N
007 - Short to Ground - Intermittent
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 007 P
Component: ZAB COCKPIT 0223
Coding: 0500725
VCID: 2642CE0492E70C76D0-5178
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No: 3D0 920 882 N
Component: KOMBIINSTRUMENT RB8 0521
Coding: 0005111
Shop #: WSC 33677 136 68631
VCID: 326A2254AE2F60D64C-515A
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 12345 123 99999
VCID: 70EEE85C60A312C67A-5178
1 Fault Found:
011 - Open Circuit
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: HSG 0101
Coding: 0000040
Shop #: WSC 29431 000 1048576
VCID: 33642750513569DE47-4B32
Subsystem 1 - Part No: 3D1 959 701 J
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 3D1 959 702 J
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 3D0 959 703 H
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 3D0 959 704 H
Component: Tuersteuergeraet HR 0201
Subsystem 5 - Part No: 3D0 909 610 C
Component: 3L HDSG 2330
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
6 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
00316 - Bulbs for Rear Illumination
011 - Open Circuit
00485 - Drivers Outside Door Handle Central Locking Button (E369)
00106 - Signal Central Locking SAVE/LOCK Passenger Side
008 - Implausible Signal - Intermittent
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
