Fourtitude.com - VCDS Adaptation Error
    Results 1 to 5 of 5
    1. n00b
      Feb 27th, 2020
      Slovenia
      7
      2011 B7 Passat Variant 1.8T
      04-24-2020 02:57 PM #1
      Hi everyone, I was trying to code comfort folding mirrors on my B7 Passat and kept getting this error.
      Adaptation Error
      Error in input: please enter one hexadecimal byte, eg: FF
      The original value was 90 and I tried typing in 95 and 99 and even tried the original 90. The same error kept appearing.
      What could be the reason for this and is there a way to fix it?
    3. Junior Member maxx007at's Avatar
      Mar 3rd, 2008
      Netherlands
      22
      2006 VW Passat 3C Variant BVY 2.0 FSI (110KW/150HP)
      04-25-2020 06:54 AM #2
      Quote Originally Posted by Podlesniik View Post
      Adaptation Error
      Remove all the numbers in the adaptation field, as it contains leading and trailing spaces. Then put in the required number and click Do it and it should work.
      '99 MKIV Golf TDI Black Magic Pearl
    4. n00b
      Feb 27th, 2020
      Slovenia
      7
      04-27-2020 05:35 PM #3
      Will try in the morning, thanks
    6. n00b
      Feb 27th, 2020
      Slovenia
      7
      04-28-2020 08:39 AM #4
      Quote Originally Posted by maxx007at View Post
      Tried this today and unfortunately got the same result. Cleared the 'New value' field multiple times and no luck.
      What else could it be?
    7. Junior Member maxx007at's Avatar
      Mar 3rd, 2008
      Netherlands
      22
      04-28-2020 08:40 AM #5
      Did you do the security login first before going to the adaptations menu?
