Fourtitude.com - 2011 Tiguan - Drivers side inner CV Axle stuck, will not budge
    Results 1 to 4 of 4
    1. 04-04-2020 10:27 PM #1
      Started the job of replacing the struts, CV Axles and front sway bar bushings today. Strut went okay and is ready to put back together but the CV Axle came apart when we yanked on it and the inner cup will not come out.
      Have tried the vice grip trick and they just come off the cup when we hit them with the slide hammer. Have dremelled slots through the cup in two places but the jaws for the slide hammer also come off without budging it.
      I've soaked the top of it near the transmission with penetrating oil and am currently praying that this will eat enough of the oxidation to break it free in the AM but am not confident..
      What's the trick? What are we not doing right?
      https://imgur.com/a/jCecGYx
    3. 04-05-2020 04:44 PM #2
      Got it out this am. A different Autozone had a axle puller kit with an adapter that had the correct thread to use on a set of vice grips and the slide hammer. Took three tries (vice grips kept slipping off) but it did come out.
      Driver's side is back together.
      ...next weekend, the passenger side!
    4. 04-30-2020 08:57 PM #3
      Remember to grease the splines of the new CV joint before inserting.
      They rust in otherwise.
    6. 04-30-2020 10:34 PM #4
      Done. With 160000 miles on the OEM set I'm hoping that the next CV axle replacement will be someone else's issue...
