Fourtitude.com - 2015 Beetle R - RCD330, another backup cam not working??...im stumped
    Results 1 to 4 of 4
    1. Member f.rizzo's Avatar
      Jun 29th, 2008
      Los Angeles
      1,294
      2015 SRT392
      03-26-2020 11:50 AM #1
      My backup cam dilemma is a little different.
      Wifes 2015 Beetle 'vert R-line. Has a factory RNS-315 w/Fender, a little dated but works fine including the factory backup cam.
      Bought and installed RCD330 noname and it works fine - - - except the backup cam. When I put the car in reverse, the factory cam flips open, but the screen on the 330 never changes. I know a lot of people get a black screen, but I dont even get that, it stays on what ever the 330 is doing (car play, radio, etc).
      The seller sent me an OBD programmer that looks like this:
      https://www.aliexpress.com/item/3290...archweb201603_
      Im not too enthused about plugging a device into the car that I can not read any of the writing. I have VAG, so if anyone knows anything about what bits and bytes might be amiss, I appreciate any info. I noticed that all of the RCD330 type units never list a Beetle in their list of applications and I think I now know why...
      thanks in advance!
      EDIT: Sorry - I forgot to mention that i have installed two different RGB to RCA converters as well. The first one was a Schoche (sp?) brand. The second one was the "Passat" specific one because apparently the Passat has something different. I also installed two different 10 pin to RCA converters as well. Nothing worked.
      THe issue is that the head unit never looks for a reverse image when the car is put in reverse. The screen never changes into reverse camera mode.
      thanks again.
      Hers:2015 Beetle R Line 'Vert Sound/Nav. Previous: 2011 CC VR6/4mo, 2008 R32. 2006 Beetle 'vert, Pkg 2. MK4 GLX VR6 Jetta
    3. Junior Member
      Dec 13th, 2014
      South Carolina
      76
      2013 VW CC R-line
      03-26-2020 12:26 PM #2
      RCD 330/340s use an RCA camera input which is not what the factory camera puts out. There are adapters out there to convert the camera canbus output to RCA for RCD330/340s or aftermarket head units. I can't speak for the one you have referenced.
      Sent from my SM-N970U1 using Tapatalk
    4. Member f.rizzo's Avatar
      Jun 29th, 2008
      Los Angeles
      1,294
      2015 SRT392
      03-26-2020 03:52 PM #3
      Quote Originally Posted by JoeIsuzu View Post
      Thanks Joe. I forgot to mention that I tried two different RCA adapters. I added the info above.
    6. Member f.rizzo's Avatar
      Jun 29th, 2008
      Los Angeles
      1,294
      2015 SRT392
      Today 11:20 AM #4
      Bump.
