got my passat running on MS finally. and now I have no tach on the cluster. anyone know what the pin out is on the cluster and do I put it to the coil or distributor? also where do you'll mount you'll MS units? have the wiring going out of a groument under the driverside in back of her fuseblock. but thinking about mounting the boxes under the passenger glove box with bolts and have the wiring going through the center console and out the driverside. or just putting hole in the passenger side and running the wiring out and over and into the engine bay.
