Fourtitude.com - Build Thread: Quad Turbo LS Swap AWD B5 S4 Project is underway
    Results 1 to 14 of 14
    1. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03 RS6, 01 S4, 94 Miata
      02-20-2020 09:00 PM #1
      I figured ill share my build here aswell.
      First things first: Flame suit on []
      It’s officially starting. I have been waiting to start this build thread for sometime. Now it’s finally underway.
      And yes you read that right
      4 turbo (just for fun)
      LS Swap - LQ4 to start
      AWD
      All on a 2001 Audi S4 shell
      I’m still working out a lot of the details and still don't know if A LOT of the details will work. But I know you guys will help me out when I get stuck.
      I have a pretty aggressive target to have it driving by October 30th 2020 as I’d like for this to make it to an Airstrip Attack event this year. Wishful thinking and so little time. I better get to work.
      For those wondering why the above combo: After my last 600whp WS6, I’m ready to move on to an AWD V8 turbo Powerplant. Also got inspired by my current DD 2003 C5 RS6.
      Cut up the stock cross member to make room. Luckily I didn't have to cut it all the way and have to make a full custom front cross member.
      I will add bracing once everything is finalized.
      Also cut up a brand new GTO oil pan. Well more like trimmed.
      The first look at the set up
      Yup, LQ4 and 01E bolted together.
    3. Member colbymc's Avatar
      May 27th, 2012
      350
      MK4 R32
      02-20-2020 09:28 PM #2
      Wow this is going to be insane!! Sub’d
    4. 02-21-2020 01:46 PM #3
      Nice look fwd to the end results, subbed as well.
      Sent from my LG-H931 using Tapatalk
      Bump
    6. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      02-21-2020 10:29 PM #4
      Quote Originally Posted by colbymc View Post
      Quote Originally Posted by LegendaryT2 View Post
      Thank you guys
      More update. Things are falling in place.
    7. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-02-2020 12:16 AM #5
      Its rolling again, this time with the LS mounted
    8. Semi-n00b
      Aug 14th, 2018
      Saint Clair Shores MI
      16
      01.5 Audi S4/ 01.5 Audi 1.8t
      03-02-2020 09:58 AM #6
      Quote Originally Posted by Marnell Balmeo View Post
      Holy Wow is that oil pan close to the ground.
      Very interesting build. Will be watching this one
    9. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-02-2020 07:41 PM #7
      Quote Originally Posted by RuS4 View Post
      4.5" ground clearance but coilovers is dropped.*
      Worse part I think is its low that far forward. Should be fine though. If not ill figure something out.
    10. 03-08-2020 01:55 AM #8
      I would say a dry sump is calling out your name. That's not going to last very long at all being aluminium.
    11. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-22-2020 11:51 AM #9
      More updates: The modified cross member has been welded. feels pretty solid now/no more flex.
      I've also decided to delete the false firewall. More room.
    12. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-22-2020 11:51 AM #10
      Also posted a video on the False Firewall Delete.
    13. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-22-2020 11:55 AM #11
      Here is the Ground clearance of the oil pan
    14. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-24-2020 09:50 PM #12
      Swapped the front accessory.
      Check it out here.
      Heres a look at the clearance
    15. Member
      Jul 6th, 2012
      New York
      1,824
      1999 A4 Avant
      03-24-2020 11:06 PM #13
      Those LS4 pulley/accessories really slimmed things down a bit. I now have a lot more faith you'll be able to fit everything now lol. Still a long motor though. Do you have any ideas where you are going to mount the radiator and intercooler?
      Also, nice job on the video, I think they have potential if you keep it up
    16. Semi-n00b
      Sep 21st, 2019
      Bay Area California
      10
      03-26-2020 12:46 AM #14
      Quote Originally Posted by CactusAvant View Post
      Thank you
      and not sure yet, I'm still toying with where everything will go. Once I have all accessory mounted and the turbo I will know where I have space.
      Heres what i'm kind of thinking about.
      1. Trunk mounted Radiator and intercooler(concern though is airflow for street use). The good part is less weight up front
      or
      2. Radiator in the trunk and mount a thick and long inter cooler on the bumper.
      or
      3. Go with side mounted Porsche Radiators where the stock intercooler go and do a long front mount
      or
      4. Side mount radiator and hood mounted intercooler similar to what STI have.
