System
[https://www]
The APR Intercooler System dramatically lowers charge air temperature and resists heat soak far better the factory intercooler system. Through a massively increased core volume, superior intercooler core design and smooth, cast end tanks, APR’s engineers were able to create an intercooler capable of supporting power levels well beyond that of the factory unit. Expect increased horsepower and torque and dramatically prolonged performance.
Dramatically lowers intake air temperature
Increases horsepower and torque while prolonging performance
APR intercooler core dimensions: 2.25" x 16.25" x 22"
40% larger than stock
Larger inlets and outlets
Pressure tested for leak proof operation
Smooth cast aluminum end tanks
Barbed hose connection points for a slip proof fit
Machined mounting points for extra weight savings
CNC machined billet adapter
Multi Ply Silicon Hoses with APR's EZ-Flow stepped design
Direct OEM fitment with no trimming necessary
Full install directions and APR's world-renowned customer support
Sent from my GM1915 using Tapatalk
[https://www]
