Fourtitude.com - Engine Code ID
    Results 1 to 9 of 9
    Thread: Engine Code ID
    1. Junior Member
      Jul 27th, 2014
      Glens Falls NY 12801
      97
      2003 VW Passat
      02-06-2020 09:55 AM #1
      I've gone from a 2003 1.8T to a 2017 1.8T. For future reference, how do I determine its the engine code ID ?
      Feb 8th, 2018
      Kamloops
      585
      2002 TDI
      02-06-2020 10:31 AM #2
      Quote Originally Posted by Drbrown View Post
      The engine code should be on top of the timing belt cover
    4. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      21,814
      1984 GLi 20v, '16 M3, '85 Golf, '17 R, '19 Q7
      02-06-2020 01:36 PM #3
      Completely different platform, generation, engine and everything else.
      Wrong forum.
      Sent from my SM-N975U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
      Jan 4th, 2007
      MA
      2,044
      2004 Jetta GLS 1.8T
      02-06-2020 06:22 PM #4
      What do you think of the old 1.8t and the newer 1.8t? I'm just curious.
    7. Junior Member
      Jul 27th, 2014
      97
      2003 VW Passat
      02-15-2020 11:00 AM #5
      Quote Originally Posted by radlynx View Post
      I use to drive full-sized V8 automatic american cars until VW's in the 1990's. Aside from the need to replace the timing belt, I thought my 2003 1.8T 5.5 standard shift VW was a good performer for a 4 cylinder. It was reliable, handled very well and fun to drive, got comparatively great gas mileage and I did all the work on it including VW's common flaws: half-axles and computer module under the front driver's carpet that got corroded connections due to the darn moon roof drain problem. I loved it and drove it fir 16 years. (no rust) I also had a 2003 but auto tranny which was a good driver but not very peppy.
      My "new" 2017 1.8 with 55,000m is of course auto tranny but compared to the 2003 auto tranny I had is very responsive to throttle i.e. I never need to shift into the "S" sport gear which throws my head backwards (ha - as the gas gauge goes down). I enjoy its comparatively new clean and tight condition and performance. At age 82 it doesn't take much to please me.
    8. Junior Member
      Jul 27th, 2014
      97
      2003 VW Passat
      02-15-2020 11:06 AM #6
      Quote Originally Posted by Vegeta Gti View Post
      Wrong forum.
      Don't understand .... recently got the 2017 1.8T and this is the only forum section I could fine at this site that appeared relevant.
    9. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      21,814
      02-16-2020 06:03 PM #7
      Because there's an entire subforum dedicated to that engine. And then broken down into what platform it came in.
      This is the 1995-2006 1.8t 20v engine. There's an FAQ, that has broken down information engine identification codes. Years, makes and models, etc.
      What vegeta said.
    10. Junior Member
      Jul 27th, 2014
      97
      2003 VW Passat
      02-17-2020 10:25 AM #8
      Found engine ID code. Per Manual and bar code on engine .... 2017 TSI 1.8L 20 valve 170 hp 110 CID Turbo, Engine ID Code CPR. Thanks to all for input.
    11. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      21,814
      02-18-2020 11:41 PM #9
      It's a 16 valve, not 20v
      What vegeta said.
