Fourtitude.com - " Life time belt "
    Results 1 to 7 of 7
    1. 01-30-2020 09:17 PM #1
      The 1.4tsi has said to have gone from chain drive back to a " life time belt drive for the cams. See the thing is l can get a 180hp 1.8T for 400$ but if l have a belt failure it could kill me in texas.
      Texas is slick it has a mini autobahn . Speed limit is 65 to 85 but 70mph.
      So is there a " life time " or chain reinforced belt for the 20v? I would really not mind having a 20"( extensive fender work) wheeled mk3 gls 20v although they say the 16valves are better the 20valve has too much airflow
    3. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      21,807
      1984 GLi 20v, '16 M3, '85 Golf, '17 R, '19 Q7
      01-30-2020 10:33 PM #2
      No such thing as life time.
      Sent from my SM-N950U using Tapatalk
      :HOMEGROWN MOTORSPORTS..SingerVehicleDesign...1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
      Jan 4th, 2007
      MA
      2,044
      2004 Jetta GLS 1.8T
      02-06-2020 03:31 AM #3
      None. Just replace the belt every 60000 miles and you are golden.
    6. Junior Member
      Jul 27th, 2014
      Glens Falls NY 12801
      97
      2003 VW Passat
      02-06-2020 09:32 AM #4
      Just curious. For the 1.8T early in the 2000's (I had a 2003) VW said change belt at 110,000. Then they dropped down to 80,000. Is 60,000 their new norm or is that just a personal preference ? (a lot of work for an 82 yr old back yard no-garage guy)
    7. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      21,807
      02-06-2020 01:38 PM #5
      The belt can go 100k, the hydraulic tensioner can fail out if the box. Hence the sudden change in bent interval. 60k is good to change hydro tensioner.
      Sent from my SM-N975U using Tapatalk
      What vegeta said.
      Jan 4th, 2007
      MA
      2,044
      2004 Jetta GLS 1.8T
      02-06-2020 06:16 PM #6
      Quote Originally Posted by Drbrown View Post
      It actually depends. The combination of belt age and mileage should be considered when changing the belt. If you had the belt for at least 6 years or at least 60000 miles, you should consider replacing it for your peace of mind and your safety. You should include the tensioner and water pump. Save yourself a headache.
    9. Junior Member
      Jul 27th, 2014
      97
      2003 VW Passat
      02-07-2020 10:39 AM #7
      Thanks to both of you for response. VW sure likes to "enhance" their shop/maintenance income. My old domestic cars always had metal timing chains that often out-lived the life of the engine under normal driving. Got a 1947 that's still running strong.
