Fourtitude.com - Audi C5 S6 Avant, RS6, D2 S8 Part-Out - Harrisburg, PA
    Results 1 to 5 of 5
      Jul 26th, 2001
      PA
      4,551
      93 Passat VEEARRRRRRRRR
      01-14-2020 03:37 PM #1
      Time to clean up around here
      (Some pics here):
      https://york.craigslist.org/pts/d/le...054001132.html
      For Sale:
      (Documented 56k Miles) 4.2 V8 Engine Assembly (with exh manifolds, alt, ac, ps) $2,500
      (Documented 56k Miles) ZF Tiptronic Transmission $1,500 (w/Torque Converter)
      2002-2003 Audi C5 S6 Avant Parts:
      (Car was Silver with a Grey interior)
      160k Miles 4.2 V8 Engine Assembly (with manifolds, alt, ac, ps) $1,500 (Wire harness is cut)
      160k Miles ZF Tiptronic Transmission $1,000 (w/tq converter)
      Alcantara Headliner and Pillars - Grey color $500
      Rear Differential (4.11 ratio, great for C5 manual swaps) $200
      Rear Axle Shafts $70 each / $100 both
      Rear Subframe w/Suspension Arms (Aluminum used on S6 only) $150
      Propeller Shaft $100
      Front Right Axle Shaft $70
      Front and Rear Shocks/Springs $100
      Cats/Downpipes $300
      Exhaust System $100
      Radiator Support $100
      Radiator $80
      AC Condenser $80
      Rear Brakes $50
      Front Brakes $100
      Engine ECU/ECM $100
      Transmission TCU/TCM $200
      Gauge Cluster *(Rebuilt by Module Masters) $200
      Rear Door Shell with regulator frame $75 each - have both left and right
      Rear Hatch complete $300
      Rear Quarter Panel cuts $200 each (or only $100 if you cut them off)
      Other Audi Parts:
      C5 RS6 Seats - Black Leather Fronts + Rear Upper only $700
      D2 S8 18" OEM Wheels, Toyo tires, 4 in pictures, I have 5 wheels - $500
      Rear Quarter Panels (already cut from a Ming Blue S6 Avant) $200 each
      *** Many more Audi and VW parts available - email with your needs!
      *** Package Discounts!
      Lugtronic.com
      Eurodyne Maestro Tuning, Stand-Alone ECU Install/Tuning/Wiring Harnesses
    3. 01-14-2020 03:58 PM #2
      Pmd
      Jul 26th, 2001
      PA
      4,551
      01-14-2020 04:21 PM #3
      Got it, thanks.
      Lugtronic.com
    6. Member 92VdubSLC's Avatar
      Mar 6th, 2001
      Middletown, NY
      4,366
      2013 Passat TDI SEL, 1976 Scirocco
      01-14-2020 08:37 PM #4
      Pm’d
      Sent from my iPhone using Tapatalk Pro
    7. 01-31-2020 05:09 PM #5
      I'm interested in the S8 wheels and possibly some C5 S6 parts.
      '03 S8
      '02 S6
      '02 RS6 Avant
      '89 964
