Fourtitude.com - Jack points 2017 q7?
    Results 1 to 1 of 1
      May 1st, 2002
      Mechanicsville, VA
      216
      2015 Golf R, 2016 Volvo XC90 T6, 1979 Triumph Spitfire, 2006 Toyota Tundra
      01-06-2020 11:51 PM #1
      Just purchased a 2017 q7 and I知 trying to make sure I知 jacking the rear of the vehicle correctly.
      Manual says:
      When I look under the vehicle I at the designated rear jack points I see:
      The front jack points have plastic blocks, should the rears?
      Found my answer to this question. Yes, there are blocks for the rear:
      I知 gathering from the manual I should be using a floor jack on the plastic covered pinch weld at the rear but want to make sure.
      Kind regards!
