How do I check if catalytic converters were removed on vw phaeton?
one easy way would be to get a whiff of the exhaust while the car is running. I don't mean stick your face in the exhaust pipe. Standing within 2 feet of the rear of the car should tell you. Since the exhaust gases have quite a different smell, easily detected, without any cats in place.
No hammer needed. No OBDII needed. Cold-start and stand behind the vehicle 30 seconds later. Without a catalyst, it will smell terribly of unburned hydrocarbons.
Smooremin: "Dont worry. My corset really fills me out."
Sold Over Sticker: "The only difference between innuendo and flirting is the desired result.![]()
KidL: "Dammit, Chippy! You're making bad choices!"
As others mentioned, eyeball check to confirm if they're still physically attached and nose check to confirm if they're working.
The ECU can be fooled by O2 spacers, resistors, or a tune... And even if you see the cats in place, they could have been hollowed out...
The only 100% absolute way to confirm would be to run the car on an exhaust gas analyzer to ensure that tailpipe emissions are where they should be. BUT... Ain't nobody got time fo' dat.
Thinking to buy phaeton...but don't trust Lithuanian scammers in kaunas
https://autoplius.lt/skelbimai/volks...s-8663621.html
The sniff test is good but not foolproof. You'll need to park the car in a garage, close the door and start the car.
Let the car idle for 15-20minutes while taking deep breaths to smell the exhaust. If you become sleepy then you'll know if the car has cats.
