golf Mk II 1.8L carburetor engine wiring diagram
7K views 2 replies 2 participants last post by  Jettaboy1884
dear All
i am new here but i am a vw car owner and own 2 mk2 cars
1 i modified for my racing habit driving
the other is automatic i bought recently with 1.8L engine pierburg carburetor system
problem is the engine wiring is messed up and nothing is connected very well to its place
you can guess all sort of problems when driving , slow response , more fuel consumption , engine rough idling ....
i hopefully get a reply and to ask for the engine wiring diagram pdf .
some info : 1986 made
1.8 L engine 4 cylinders
( standard ignition coil with distributor and 3 wires hall sender , vaccuum advanced , 7 pin ignition module. )
instrument cluster: analogue clock and speedometer ( 2 plugs model )
automatic transmission .
will later post my cars photos if anyone is interested to view.
best regards : mk2 buddy
#3 ·
Your engine troubles sound more like carburetor needing cleaned, and not necessarily electrical.
I am not sure if your engine and wiring are like US models, but on US the ignition system is a very simple and nearly standalone setup that is not incorporated into other parts of the engine.
Do you have an electric choke?
There really is very little electrical going on with a carburetor setup. I would recommend you start with cleaning your carb.
