Fourtitude.com - 2010 Tiguan, PCV issues
    Results 1 to 3 of 3
    1. Member Lord_Verminaard's Avatar
      Apr 6th, 2004
      Columbus, OH
      3,150
      1981 Scirocco S, 2008 Audi A3 2.0T, 2008 GTI, 1976 Kawasaki KZ400
      11-16-2019 11:09 PM #1
      Hello all, have a real head scratcher.
      Working on a 2010 Tiguan that belongs to a friend, I have logged lots of hours working on this car as it ate it's timing chain and I did the R&R of the head with new valves, new timing set, etc... so the friend got a CEL, and it was the usual suspects: P0300, P0301, P0302, P0303, P0304, and P2187. I had him order a PCV valve and he brought the car and the part over, and I swapped it out. He got one of the aftermarket ones from Amazon for like 60.00. Well, on first startup, it was bucking and idle was all over the place and it would barely run. Tried to take it for a drive but it would stall at every stop. Pulled the hose from PCV to the intake manifold and installed a temporary plug in the intake manifold, cleared the codes, started it up and it was fine. Drove it for about a half hour, shut it off and back on several times, and it was fine and no CEL. Well, bad "new" PCV I thought. Had him order a genuine VW latest revision PCV. part arrives, I swap it out. Started it up. Misfiring and idling wierd, but not as bad as last time. CEL blinking but not on steady. It didn't stall. I drove it around the neighborhood, it was mostly fine. Took it for a longer drive, it was fine the whole drive, no issues. Gave it a couple full throttle rips up some onramps, drove it back home, shut it off, turned it on a few times, no CEL no issues.
      I am going to do another cold start test tomorrow to see if the issue is still there before I return the car to him, but is it possible that the aftermarket PCV really was bad? And why would it still misfire on cold start with the new PCV? I am crossing my fingers that it behaves tomorrow otherwise I don't know what I will do.
      BTW, when I did the head and chains, it also got new coils and plugs so all that should be good.
      Thanks,
      Brendan
      '81 Scirocco 'S ...
      '08 Audi A3 2.0T FWD 6MT
      '08 GTI 2-doors, 3 pedals, no sunroof.
      '76 Kawasaki KZ400
    3. Member jiffyjetta's Avatar
      Mar 13th, 2010
      Oregon
      2,291
      MK7 Golf Sportwagen, MK6 GLI
      11-17-2019 02:13 AM #2
      The PCV likely went bad and sucked the rear main seal in or blew it out. Now you have a vacuum leak at the rear main seal when you hook up the PCV line to the manifold.
      Also, avoid cheap pcvs. I have taken many of them apart from different manufacturers, and there are very few that are of good quality. I've seen the little orange valve stick open, rotted diaphragms etc.
      Tuned mk6 2.0t CBFA 6 speed ECU for sale. Launch control set @ 3800 & 8psi, immobilizer delete, cat delete, air pump delete. $300 shipped.
    4. Member Lord_Verminaard's Avatar
      Apr 6th, 2004
      Columbus, OH
      3,150
      11-17-2019 04:00 PM #3
      Thanks for that, looks like that is exactly what is happening.
      Started it up this morning, and yep, running rough again. And I know the rear main is leaking, as that was the first thing he talked to me about before the CEL came on.
      So he needs a new rear main seal too.
      Thanks for the input, time to deliver the bad news.
      Brendan
      '81 Scirocco 'S ...
      '76 Kawasaki KZ400
