Fourtitude.com - Vacuum pump replacement
    Results 1 to 3 of 3
    1. 10-29-2019 06:14 PM #1
      Hello,
      I can’t find anything on how to replace the vacuum pump on a VW GTI 2.0 TSI engine. If anyone has instructions on a DIY for it I’d really appreciate it!
    3. n00b
      Jan 8th, 2019
      San Diego
      7
      2012 VW GLI
      11-22-2019 02:45 AM #2
      depending on the issue with the vacuum pump - if it's just an oil leak you can get this:
      https://www.rkxtech.com/collections/vacuum-pump-repair
      otherwise be prepared to shell out upwards of $300 for repair - it's always good to get a replacement gasket as well, which is 06H103121F
    4. 11-22-2019 03:18 AM #3
      Thanks!
      It seems to just be an oil leak. I had the car looked over by Volkswagen before purchasing it and they said the whole pump needed to be replaced because of the leak. I think I’ll try the kit before spending a lot more on a new pump.
