Fourtitude.com - Valve Carbon Cleaning you WILL need it done
    Results 1 to 8 of 8
    1. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      4,272
      '11 GTI, 2018 Passat SE
      10-26-2019 10:30 AM #1
      It's not a matter of if....it's you WILL need to do it. It will probably solve about 10 posts on this page alone.
      Dirty hoe
      Clean bitch
      Also, a chemical scrape will not last as long as a walnut media blast. This is actually my second cleaning. The chemical scrape....done first, only lasted 45,000 miles
      It go down in the DM
    3. 10-26-2019 10:57 AM #2
      Good pictures, and we were lucky because my wife's GTI didn't need it until 160k miles. Next VW we own I will invest in the equipment and do it myself. Not worth paying someone what the going rate is when it's really pretty easy. Do you have a full write-up? I think a lot of people would like to see a step by step or at least major step by major step. I bet it drives and idles 1000x better!
      Sent from my SM-G930T using Tapatalk
    4. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      4,272
      10-26-2019 12:36 PM #3
      I had someone do it for me. Cost me $580 including the gasket and injector seals.
      Aug 15th, 2018
      Los Angeles, CA, USA
      175
      10-26-2019 05:01 PM #4
      I have recently used the chemical method via CRC GDI Intake Valve Cleaner. I'm sure it doesn't clean it as well as the physical method, but it's only $20 and it has fixed 98% the rough cold idling/misfire in the morning. That is the only symptom I have after 77K miles.
      I plan on doing it with ever oil change from now on. If you do it often enough, it will get as clean as the physical method. There's a guy on Youtube "nates interactive" who tests out many intake cleaners on GDI engines. His intake valves are now super clean compared to when he started.
    7. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      4,272
      10-26-2019 09:34 PM #5
      Yeah I am going to start using that CRC stuff at every oil change now
    8. Member jiffyjetta's Avatar
      Mar 13th, 2010
      Oregon
      2,360
      MK7 Golf Sportwagen, MK6 GLI
      10-27-2019 12:35 AM #6
      If you use a carbon cleaning chemical a few times a year, it will last a lot longer.
      Methanol injection and high rpm driving will also help keep it clean.
      Tuned mk6 2.0t CBFA 6 speed ECU for sale. Launch control set @ 3800 & 8psi, immobilizer delete, cat delete, air pump delete. $300 shipped.
    9. Member
      Dec 1st, 2009
      3,333
      2017 Audi SQ5, 2017 Corvette Grand Sport 7MT, 2010 Audi S4 6MT. 2015 Audi Q3 Quattro
      10-29-2019 12:19 PM #7
      My 2012 CC 2.0T is at 132000 miles....no carbon valve cleaning needed yet....but it did have a catch can....
    10. Member jiffyjetta's Avatar
      Mar 13th, 2010
      Oregon
      2,360
      11-22-2019 03:08 AM #8
      Here's one at my shop with 60k for the first cleaning. No misfires yet, the customer did it as maintenance.
