Fourtitude.com - IIHS releases small overlap crash for the arteon
    Page 3 of 5 FirstFirst 12345 LastLast
    Results 51 to 75 of 104
      Oct 13th, 2008
      Canada
      366
      10-09-2019 05:28 PM #51
      Quote Originally Posted by BsickPassat View Post
      Essentially, since the measurement is taken at a height of 3'7"
      Interesting, seems low given every other vehicle is a pickup truck.
      The performance of the lights, seemed to meet their requirements, but then it was given a low score, just trying to figure how it's calculated or if it's just an arbitrary opinion.
      Jul 21st, 2000
      Boca Raton, FL
      3,504
      2019 VW Arteon SEL Prem R-line
      10-09-2019 05:32 PM #52
      Quote Originally Posted by sandwich-chris View Post
      The headlights were rated down because of excessive glare measurements to oncoming drivers. They actually scored higher in the illuminated distance effectiveness than quite a few 'acceptable' rated headlights - so glare was the only demerit. Of course, that only matters to oncoming drivers - the Arteon driver's experience with the headlights will be that they are quite good...especially in the higher trim levels where they have the auto high beam assist and bend into curves.
      _____
      Justin
    4. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      41,958
      '66 Beetle (X2) '08 Fit
      10-09-2019 05:37 PM #53
      The parameters may or may not be questionable (I don't know), but it I don't believe that anything is left to interpretation that doesn't absolutely have to be.
      Quote Originally Posted by Boyz in da Park
      Proletariat, Bourgeoise - Everybody smellin' my potpourri...
    5. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      23,257
      10-09-2019 06:31 PM #54
      Quote Originally Posted by compy222 View Post
      this true, the only concern i'd have would be automatic door locks and/or any electronics in the door mechanism to get out of the vehicle. that said, if you hit something hard enough for the battery to exit the vehicle, as long as the airbags deployed i'm not sure it matters much.
      Quote Originally Posted by patrikman View Post
      Which is why I think this is such a cause for concern. In modern times we’ve begun to rely so heavily on these post crash features I fear we’ve begun to move away from the importance of what to do after a crash if these systems aren’t available to us. Even basic things like the inability to turn on flashers in the even of an accident can cause even more risk to the occupants.
      Most if not all modern cars at this point open the locks when the airbags deploy, we can see from the video airbags went off so door locks should have opened at the same time.
      We also seem to be ignoring that some cars literally disconnect the battery upon firing of the airbags. So we are literally building in systems that cut off these modern features in the case of an accident. You can buy cars today that even if your battery remains intact and you can open the door yourself and go whoops I messed up.. you still can't reach back in and turn the hazards on because the car disconnected all power for you.
    6. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      23,257
      10-09-2019 06:35 PM #55
      Quote Originally Posted by Samson View Post
      How is the battery in the Arteon clamped? Is it one of those little guys that grabs the lower lip of the battery case?
      Quote Originally Posted by ice4life View Post
      Some Arteon battery porn.
      Bolted in not just plopped.
      One ends sits under a lipt and the other side is held down with a little metal plate about 2x3 and a single bolt. Same basic way VW has done it for a few decades. The trays are now fiber reinforced plastic thing not metal, they have been using that since the mk4s? And its been in the same spot as the Aerton since the mk5s or about 05ish.
    7. Member Samson's Avatar
      Dec 2nd, 1999
      12,017
      Lifted G37 wagon, Lifted AWD Prius
      10-09-2019 06:47 PM #56
      Quote Originally Posted by Air and water do mix View Post
      That's pretty good for an '07.
      Yeah, surprising. Our old '12 Tucson got a fail.
      Some Arteon battery porn. It's kind of just plopped in there with an insulation surrounding it. The clamshell hood and front end are pretty wild, and I think it contributed to the projectile battery.
      Interesting design, and that's a cool color. If I recall correctly, my old A3 VR6 had a similar mounting style. I guess a 40lb brick ejecting itself upon impact is not considered an issue, as odd as it seems. It's not like it would be a difficult problem to solve.
    8. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      4,532
      2019 Volkswagen Arteon SEL-Premium (non R-Line)
      10-09-2019 06:49 PM #57
      Quote Originally Posted by chris86vw View Post
      Pretty sure my Touareg battery was in the trunk. And the earlier gen was under the driver's seat. So not all have it in the same spot- Based on your description, the battery did not look like it was bolted down. But that was just my observation looking at it head on.
    9. Senior Member
      Aug 20th, 2000
      In a minivan by the river with a squirrel and rat
      25,121
      grey ghost wagon and a 944
      10-09-2019 06:51 PM #58
      Quote Originally Posted by spockcat View Post
      Just preparing for when all VWs are EVs and they don’t want occupants burning from a battery fire.
      Tesla does this very well, today.
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
      If you have a problem with anything I do here, feel free to call me on my cell to discuss at anytime: (781)452-2079 LEAPRZ
    10. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      23,257
      10-09-2019 07:00 PM #59
      I'm referring strictly to the transverse platform vehicles that were predecessors to the aerton or currently use similar mounting and are on the same platform.
      It is 100% bolted down in your car, if not contact the NHTSA and get the recall started. I tried to find it in the FMVSS but little hard to search that now that there is a bunch of EV stuff that mentions battery over and over again. But I am 99.9% sure that some sort of battery tie down is a requirement.
      ETA... even then both those Touaregs had their batteries bolted down in a very similar fashion. Slightly different physical tie downs but same idea on the early ones, blanking the late ones but I think might use the same little thing as the arteon
    11. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      4,532
      10-09-2019 07:03 PM #60
      Thanks- What is an A3 VR6? Is that a Euro model? I know they made a TT 3.2 VR6 (Eos too), but I didn't know there was an A3 VR6.
    12. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      23,257
      10-09-2019 07:06 PM #61
      I believe he is referring to a MK3, until the Mk4 which made it confusing since Audi had the A4, they were usually referred to as A1, A2, A3 because they were the A platform cars.
      So a mk1 rabbit is an A1
      A mk2 golf is an A2
      A mk3 gti like he is talking about is an A3
      But also yes there is a 3.2 VR6 Audi A3 that was sold in the US.
    13. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      4,532
      10-09-2019 07:09 PM #62
      A mk2 golf is an A2
      Gotcha! Thank you for the clarification. Also- thank you for reminding me of the A3 hatch 3.2- DUHH. I got hung up on the later sedan/cabrio.
      I'll take your word for it- But it really does look like it is just free standing with the two connections (one covered with a plastic like plate).
    14. 10-09-2019 07:11 PM #63
      Quote Originally Posted by S1ack View Post
      Happened on the Mk7 GTI as well.
      Yep.
      https://www.youtube.com/watch?v=2apWN173D4A
    15. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      4,532
      10-09-2019 07:14 PM #64
      Quote Originally Posted by gti_matt View Post
      Yep.
      My first arteon had the engine cover with the silver VW badge (like this GTI). They cheaped out during production, and my later build now has an all black plastic engine cover without the silver badge.
    16. I’m not a loser. I’m a winnah!! patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      37,862
      made in ‘murica truck and wagon
      10-09-2019 11:57 PM #65
      This is an a3 VR6, mine circa 2008
      [IMG] https://www.subaruoutback.org/cdn-cgi/image/format=auto,*********redirect,width=1920,height=19 20,fit=scale-down/http://farm5.static.flickr.com/4060/4259450885_7372511d49_b.jpg[/IMG]
      this signature kills fascists.
      Support Your Local Homebrewery
    17. I’m not a loser. I’m a winnah!! patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      37,862
      10-10-2019 12:25 AM #66
      [QUOTE=chris86vw;113781959]
      We also seem to be ignoring that some cars literally disconnect the battery upon firing of the airbags. QUOTE]
      Are we ignoring this? This is not something common knowledge in my world.
    18. Member adrew's Avatar
      Aug 15th, 2003
      Texas
      18,152
      '12 Yaris, '17 Corolla
      10-10-2019 12:29 AM #67
      I know it's common to deactivate the fuel pump in an accident (like Fords that have the reset switches in the trunk) but have never heard of the battery disconnecting. Maybe some hybrids disable the high voltage stuff?
      Improving the signal-to-noise ratio
    19. Member mach250's Avatar
      Apr 8th, 2005
      Tampa
      856
      2019 BMW M550i
      10-10-2019 02:25 AM #68
      Why dont they include the driver seat headrest?
      Previous cars: 2016 VW GTI PP - 2015 VW GTI - 2004 VW R32 - 2001 Subaru Legacy B4 STI - 1997 Nissan 180SX Type-X
      My Flickr
    20. Member MGQ's Avatar
      Apr 16th, 2002
      The City (:-l)
      10,595
      Fusion Hybrid
      10-10-2019 02:33 AM #69
      Quote Originally Posted by mach250 View Post
      probably blocks a camera angle if you see the in-car video
      This is only temporary, unless it works. - Red Green
    21. Senior Member
      Feb 23rd, 2000
      Shepherdstown, WV
      23,257
      10-10-2019 07:17 AM #70
      Quote Originally Posted by adrew View Post
      I'm referring to standard 12v systems.
    22. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      22,227
      15 GSW, 19 Tiguan SE, 03 20th, 88 Cabby, 64 Yamaha
      10-10-2019 08:17 AM #71
      I noticed the same on a Tiguan I was looking at yesterday. Even if they didn't do a separate badge at least having it painted silver would help. Looks really cheap.
    23. Member Samson's Avatar
      Dec 2nd, 1999
      12,017
      10-10-2019 08:42 AM #72
      Sorry - '95 Jetta GLX. It did have a padded battery "parka" though. Maybe the thought was that when the battery ejects itself, the parka will cushion the impact a little.
    24. Member
      Jan 18th, 2018
      4,688
      '16 TLX SH-AWD- NA is BEST
      10-10-2019 09:21 AM #73
      You had to get it replaced already???
    25. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      41,958
      10-10-2019 09:26 AM #74
      How is something so inconsequential worth banging your head?
      The only VW logos on my old cars are on the fuel pump (which you can see) and cast into the case, but you have to crawl under the car to see those. Worse yet, on later cars there isn't one on the fuel pump at all. The horror! Those bastards totally cheaped out!
      Quote Originally Posted by CTK View Post
      Yeah, that seems more serious. If you mentioned it previously I missed it. I hope it wasn't a big accident. If it was are you okay? Really. I hope everything is okay.
    26. Member ice4life's Avatar
      Nov 5th, 2017
      CO
      4,532
      10-10-2019 10:25 AM #75
      Quote Originally Posted by UncleJB View Post
      Okay maybe not bang head worthy. But it def felt like a cheap-out that was unecessary given it's the flagship and it had it months earlier. They also removed the aux jack from the first one I had.
      The first one had undisclosed damage from the port or the dealer. VW never found out what happened to it but the intercooler had a dent in the bottom of it, the paint was literally peeling off the bumper after a week, and the grill was all sand blasted after I washed it. After 45 days of the dealer and corporate fighting back and forth, they finally replaced the car by doing a trade assistance as there were none at the port to give us. It was a real pain in the arse. It's our last VW after buying 8 in 8 years.
