Fourtitude.com - New VAG-COM user, help with settings/blocks?
    Results 1 to 3 of 3
    1. n00b
      May 21st, 2019
      8
      94 EU Mk3 Cabrio 2.0 2e
      09-20-2019 01:00 PM #1
      I have a 1994 euro-spec Cabriolet MkIII, ODB-I.
      I downloaded VCDS and purchased the HEX-V2 USB connector.
      I have hooked up to the car and scanned for codes, none found. I know that the software/interface works (tested by removing the connector from the temp sensor, verified the fault code and cleared it).
      I see mention of settings/blocks and people using the program to see sensor output, is this something that can be done with an OBD-I vehicle? Is there any listing of measurement blocks (looked on the ross-tech site and others, couldn't find anything).
      Any info is greatly appreciated!
      - Mike
      1994 Euro-spec Cabrio III
      2.0l 2E engine, 5 spd manual
      Feb 25th, 2010
      Wilkes-Barre, PA
      866
      09-20-2019 09:01 PM #2
      OBD 1 was really basic and didn't offer much.
      You choose a measuring block # 001 and you get 4 fields of data.
      # 002 and you get 4 more fields of data.
      OBD 1 didn't have much at all in the US!
      Good Luck
      Nov 27th, 2011
      MD
      4,709
      09-25-2019 08:39 AM #3
      I usually like to take a look at the AMV (Advanced Measuring Value) to get a quick look at what is actually available in that module to look at, then I can go into MB (Measuring Blocks) and punch in the appropriate group number/s. Lots of times the group numbers do not contain any info from that specific module and you can see that easily with AMV.
