Fourtitude.com - 07 EOS VW intermittent EPC + traction control - VAG-COM decoding
    Results 1 to 4 of 4
    1. 09-16-2019 09:08 AM #1
      Struggling with an intermittent problem that shows as EPC + traction control lights. Car goes into limp mode when this happens. Can someone interpret the scan results below:
      VIN: WVWAA71FX7V049491 License Plate:
      Mileage: 138290km-85929mi Repair Order:
      Chassis Type: 1F (1K0)
      Scan: 01 03 08 09 15 16 17 19 1C 25 26 42 44 46 52 56 62 63 65 72
      VIN: WVWAA71FX7V049491 Mileage: 138290km-85929miles
      01-Engine -- Status: Malfunction 0010
      03-ABS Brakes -- Status: Malfunction 0010
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: Malfunction 0010
      19-CAN Gateway -- Status: Malfunction 0010
      1C-Position Sensing -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      26-Auto Roof -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      56-Radio -- Status: Cannot be reached 1100
      62-Door, Rear Left -- Status: OK 0000
      63-Entry Assist,D -- Status: OK 0000
      65-Tire Pressure -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      Address 01: Engine Labels: 06F-907-115-AXX.clb
      Part No SW: 1Q0 907 115 E HW: 8P0 907 115 B
      Component: 2.0l R4/4V TFSI 0020
      Revision: 5BH16--- Serial number: VWX7Z0G33NB8R0
      Coding: 041C010A18070160
      Shop #: WSC 25096 444 85863
      VCID: 2E54D5FAB98C05314B-807A
      3 Faults Found:
      000289 - Throttle Position Sensor (G69)
      P0121 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Status: 00101000
      Fault Priority: 2
      Fault Frequency: 4
      Reset counter: 255
      Mileage: 136605 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 07:52:51
      Freeze Frame:
      RPM: 2164 /min
      Load: 7.8 %
      Speed: 56.0 km/h
      Temperature: 72.0°C
      Temperature: 45.0°C
      Absolute Pres.: 990.0 mbar
      Voltage: 13.716 V
      005699 - Please check DTC Memory of Electric Load Controller
      P1643 - 001 - - Intermittent
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 4
      Reset counter: 255
      Mileage: 136605 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 07:52:51
      005497 - Throttle Actuator (J338)
      P1579 - 001 - Adaptation Not Started - Intermittent
      Freeze Frame:
      Fault Status: 00100001
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 255
      Mileage: 138243 km
      Time Indication: 0
      Freeze Frame:
      RPM: 195 /min
      Load: 66.6 %
      Speed: 0.0 km/h
      Temperature: 63.0°C
      Temperature: 60.0°C
      Absolute Pres.: 980.0 mbar
      Voltage: 10.414 V
      Readiness: 0000 0000
      Is it the throttle position sensor? Any help is greatly appreciated.
      Thanks!
    3. Semi-n00b maxx007at's Avatar
      Mar 3rd, 2008
      Netherlands
      15
      2006 VW Passat 3C Variant BVY 2.0 FSI (110KW/150HP)
      09-16-2019 09:12 AM #2
      This code:
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 4
      Reset counter: 255
      Mileage: 136605 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 07:52:51
      Might well be the source of your problems.
      It seems like either your alternator or battery is on it’s way out.
      My guess would be the first one.
      '99 MKIV Golf TDI Black Magic Pearl
      Sep 20th, 2013
      Cle Ohio
      2,508
      2007 VW Golf GTI
      09-17-2019 10:38 AM #3
      Looks like you got an issue with throttle body and can gateway you want to sort out too. Issues with throtel body more then likely causing limp mode.
    6. 09-18-2019 09:51 AM #4
      Throttle body was replaced recently. Throttle body wiring repair had already been done (TSB 2018652/2). Work looked kinda shoddy, so I redid it the other day. Only ~30 miles, but so far so good...
