Fourtitude.com - 2.8L V6 Oil Pump Interchange (30V pump in 12V engine)?
    Results 1 to 1 of 1
    1. Member o2bad455's Avatar
      Aug 22nd, 2003
      Northeast USA and Canada
      1,257
      VW A1-Chassis ABA16vT VWMS, VW A5-Chassis PD-TDI DSG, Audi B5-Chassis 2.7T 6MT
      09-05-2019 12:57 PM #1
      Question: 2.8L V6 Oil Pump Interchange. Will the oil pump from a 30V engine with pump part number ending in 105 fit/interchange into a 12V engine where original pump part number ended with 103?
      Background: The 12V engine's from a 1996 Audi A4 Quattro, but left side camshaft is starving for oil and overheating front cam bearing cap. Can't find another 12-Valve oil pump, and assume a 30-Valve pump could provide higher flow *IF* it fits.
