Fourtitude.com - how do you clean your shop?
    Results 1 to 19 of 19
    1. Member Spike00513's Avatar
      Jul 13th, 2012
      SoCal
      535
      B6 A4
      08-25-2019 05:09 PM #1
      shop/garage
      how do you clean it?
      Am asking because I'm having difficulty and would like to know if there's a better way.
      Besides sweeping tools of various types (regular broom, mini hand broom, etc.), as well as mops of various types
      I've been taught to use rags and WD-40, under the claim that "it's a solvent" and thus naturally good at dissolving and cleaning up dirty stuff like smeared oil.
      For example, if you've got a dirty surface, other cleaners might do nothing. But WD-40 might make quick work of it.
      Is that how everyone else does it too?
      However, the problem with WD-40 is the product itself also leaves a thin clear film of oil on where you use it. Especially bad if someone else doesn't know it's been "treated" with WD-40 and accidentally leans on it.
      I haven't figured out what to clean that residual coating with, or if there's a better way than all of this in general. So far I just try to use window cleaner such as Windex or something, as a second go-around after the WD-40.
      But as you can imagine, going once with WD-40 and then over that with Windex; cleaning becomes a huge PITA, and long drawn-out ordeal.
      I used to put my tools on an NSF steel food prep cart table (with a matching size oil drip pan on top) if they were dirty, to use that to clean with WD-40.
      Another good thing about the WD-40 part; it probably doesn't smell toxic and bad like brake cleaner.
      But again; it takes a while and leaves an oily film.
      Some say cars (and the places they reside) aren't meant to be clean. But when it is, other people are definitely impressed by it.
    3. Member Rakshas's Avatar
      Mar 12th, 2013
      531
      08-25-2019 05:32 PM #2
      Mild citrus based degreased, diluted with water appropriately. Windex as necessary
      Oct 22nd, 2007
      Syracuse, NY
      4,438
      982, F22, E88, etc.
      08-25-2019 06:07 PM #3
      Just a garage not a shop, but in general, shop vacs and Simple Green. Simple Green is sustainable and works darn well. Can mop with it, spray bottle it, or dab it on a cloth. I recommend the one gallon concentrate which lasts a while.
      https://simplegreen.com/products/all-purpose-cleaner/
      If I've accidentally made a liquid mess I'll use a bit of kitty litter to soak it up, fortunately that doesn't happen to often. Splitting a transmission case or something.
      WD-40 is great when you've got some water or something squeaking up a mechanism, but IMO it's used for far more things than it's really best for. Particularly cases where people think it's a lubricant (e.g., bike chains).
    5. Geriatric Member @McMike's Avatar
      Oct 9th, 2002
      Northern part of the Virginia
      37,980
      German Vans, British cars, and a motorbike.
      08-25-2019 07:12 PM #4
      Sweep/shopvac workbench
      Sweep/shopvac floor
      Move car on dollys
      Sweep/shopvac where car was.
      Mop under car
      Move car back
      Mop everything else.
    6. Member DneprDave's Avatar
      Sep 8th, 2018
      Western Washington State
      182
      2008 VW Passat 3.6l 4motion
      08-25-2019 07:42 PM #5
      Citriclean and water, it'll cut through anything.
      2008 Passat VR6 3.6 4Motion Wagon, 2010 MINI Cooper S, Dnepr MT-16 motorcycle
    7. Just Milking my Carrot in the Honda break room. Metallitubby's Avatar
      Aug 20th, 2001
      Atlanta, GA
      32,746
      Honda, Ducati
      08-25-2019 08:55 PM #6
      One of our new sponsors is a biodegradable cleaning product that works wonders on pretty much every surface. I dilute it with water and mop, or clean small-parts with it. I've been really impressed with the stuff.
      * My contributions are not representative of American Honda
    8. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      34,126
      Hot hatchback coupé heaven
      08-25-2019 09:05 PM #7
      My shop just has a concrete floor.
      So hard bristle broom. "Kitty litter" for large spills.
    9. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      23,440
      88 Cabby, 91 Jetta, 15 GSW, 19 Tiguan
      08-26-2019 06:52 AM #8
      I generally sweep out the corners and edges and then use a leaf blower to do the rest. As far as cleaning solvent Simple Green (as was suggested) works amazingly well on just about everything.
    10. Member mach250's Avatar
      Apr 7th, 2005
      Tampa
      919
      2019 BMW M550i
      08-26-2019 07:09 AM #9
      I'm pretty simple with a concrete floor and cars that don't leak. Just use a leaf blower to blow out the dirt and debris every once in a while.
      Previous cars: 2016 VW GTI PP - 2015 VW GTI - 2004 VW R32 - 2001 Subaru Legacy B4 STI - 1997 Nissan 180SX Type-X
      My Flickr
    11. Member capkurt6's Avatar
      Jul 31st, 2009
      Metro Detroit, Mi
      100
      2015 GTI SE
      08-26-2019 08:02 AM #10
      Quote Originally Posted by ghost03 View Post
      When did WD-40 become such a magnet for internet scientists? I think people hate on it because its cheap, ubiquitous and doesn't come in an orange can. WD-40 is MOST ASSUREDLY a lubricant. Is it a good lubricant? maybe not. Definitely a lubricant though.
    12. Member
      Aug 22nd, 2014
      Houston
      459
      2012 Accord, 2012 Escape, 69 (nice) Beetle
      08-26-2019 09:02 AM #11
      Where are you putting this wd40? I can see machine tables and stuff, but from an industrial welding/machine shop to a garage wood shop to a hot rod garage, I've only ever gone with vacuum/blow/sweep large empty surfaces, wipe down anything else with a dry cloth. Rough wood work surfaces might get a sanding every year or so.
      Tool chest tops get sprayway glass cleaner in one guys shop. Mine don't seem to need it (mostly wood work at the moment). Guys at the big shop just wiped with a dry rag and covered for the nights.
      Oct 22nd, 2007
      Syracuse, NY
      4,438
      982, F22, E88, etc.
      08-26-2019 09:52 AM #12
      Quote Originally Posted by capkurt6 View Post
      I suppose I meant primary function, which is of course water displacement not lubricant. Lubing a bike chain or other mechanisms that sees a lot of movement with WD40 is a bit like taking Advil to cure a broken leg--it'll help but the issue will come back. But yes, the residual oil that OP is struggling to clean up will provide a bit of lubrication, which could be adequate in some cases.
    14. Member Surf Green's Avatar
      Feb 16th, 1999
      Silver Spring, GerryMarylandering
      14,789
      2 Manuel Turbo Wagons... One is incredibly slow.
      08-26-2019 10:06 AM #13
      Quote Originally Posted by Metallitubby View Post
      Looking for the link embedded in this spam post.
      No seriously... what's the brand?
      It's comforting to know there's always a chronically angry person at the ready to correct my think.
      2002 Golf Wagon TDI, 210k - 2007 Fuji Heavy Industries WRB WRX Wagon, 126k
      Past: 1996 Surf Green GTI VR6 - 1985 Golf 1.8L - No Trim Level Edition
      Grammatical and spelling errors may be intentional
    15. Member The_Real_Stack's Avatar
      Oct 18th, 2016
      Arlington Heights, the center of the universe
      3,785
      AP1 and JLU
      08-26-2019 10:26 AM #14
      Team leaf blower.
      Quote Originally Posted by Volkl View Post
      My wife wanted a SUV with a manual transmission. I suggested a Wrangler, she said no way, too masculine
    16. Member Disgruntled Ziemniak's Avatar
      Oct 24th, 2016
      In the cupboard down by your knees
      995
      Oil-Thirsty Broad
      08-26-2019 10:50 AM #15
      Good at everything,
      The best at nothing.
      Its still damn good though.
      And it smells like candy
      Your favorite Ziemniak, hold the gravy.
    17. You can't look at my avatar for just a second, can you? Just Another Sweater's Avatar
      Aug 11th, 2002
      Southwest Ohio
      5,741
      GTI Sport 6M
      08-26-2019 11:01 AM #16
      Quote Originally Posted by Disgruntled Ziemniak View Post
      Good at everything,
      You eat some weird candy.
      I use Kroil for things that matter.
      Ballistol for firearms.
      For dirt I use a leaf blower or a shop vac.
    18. Just Milking my Carrot in the Honda break room. Metallitubby's Avatar
      Aug 20th, 2001
      Atlanta, GA
      32,746
      Honda, Ducati
      08-26-2019 11:10 AM #17
      Quote Originally Posted by Surf Green View Post
      I didn't want to spam this thread with their product and their website is garbage, but since you asked.
      https://www.buygtech.com/default.asp
    19. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      14,420
      08-26-2019 12:08 PM #18
      Quote Originally Posted by The_Real_Stack View Post
      Team leaf blower.
      My first thought too.
      I also use a broom in corners, and kitty litter for spills.
      I don't use WD-40 for tool cleanup as much as I use it to clean my hands. It smells awesome and knocks hard to get grease right off my hands.
      For tools, I just tend to wipe them down with a dry rag. I'm okay with the oily residue as it will ensure they don't rust. But if they're really dirty I'll use some soapy water and soak them a large peanut butter container and let them soak for a few days.
      Chris
      | 20 Ram | 13 Altima | 00 Tahoe | 94 Integra GS-R | 74 SuperBeetle | 62 Ford Unibody |
    20. Member
      Sep 25th, 2010
      wilmington DE
      4,222
      1964 corvair spyder, 1976 bmw 2002 rally car, 1998 bmw 328i, 2001 C5, 2001 X5 5spd
      08-26-2019 12:32 PM #19
      Quote Originally Posted by Iroczgirl View Post
      pretty much this, and then park car over oil stains to hide it
      Instagram! @freedo70
      Quote Originally Posted by stevegolf View Post
      You could buy a high tech fleshlight that'll take you from zero to jizz in 3 seconds, but wouldn't you rather take your time and enjoy the experience?
      #FREEPATRIKMAN
