Fourtitude.com - EA888 Gen 3 Oil Filter
    Results 1 to 2 of 2
    1. Junior Member
      Jul 22nd, 2018
      Colorado USA
      21
      2017 VW Beetle S
      08-23-2019 10:55 AM #1
      I was a bit surprised to find there was no oil in the filter assembly area when removing the filter. Is there no check valve to keep oil in the filter when the engine is turned off?
      Obviously having no check valve makes for a clean, easy filter change, but requires a couple of seconds for the oil pressure to build up.
      I have always filled oil filters prior to installation on engines where that is possible, e.g., Chevrolet V-8. Of course that is not possible on the subject engine.
      Craig
      2017 Beetle S
    3. 08-23-2019 11:51 PM #2
      Should have been oil in there untill you pulled the filter out . If no oil was there your o-ring on your dangle is bad and letting it leak down after shut down .
