Fourtitude.com - Fuse 16 Keeps blowing
    Results 1 to 25 of 50
    1. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-09-2019 04:47 PM #1
      *** Final Edit *** Solved
      One of the wires going into t4 on the Fan Control Module was rubbing against the frame and shorted the internals of my after-run coolant pump.
      I fixed the wire that was rubbing against the frame and replaced my after-run coolant pump, and my TT has been running like a champ.
      *** Edited ***
      As stated in the title, Fuse 16 keeps blowing in my 2001 Audi TT Quattro Coupe 225. The fuse basically powers the Fan Control module, so it's used for the magnetic clutch on the A/C compressor and the after-run coolant pump on our cars. It also supplies power to the G65 A/C pressure switch (this can be confusing, as the VCDS scan will always say F129 switch open circuit - G65 is a newer version of F129 with three wires instead of four).
      I've checked continuity from the magnetic clutch to the Fan Control Module, and it's fine. Same for the after-run coolant pump and the G65 A/C pressure switch.
      You can remove blood stains with hydrogen peroxide.
    3. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-13-2019 04:17 PM #2
      For what it's worth, I'm investigating this. The wiring diagram with this fuse in is is on page EWD-79 of my Bentley manual, and it shows the following:
      J293 (Fan Control Module) to a red/grey wire
      red/grey wire to Fuse 16 (10 Amps)
      Fuse 16 to red wire to A98 = plus connector -4- (30) in instrument panel wiring harness
      red wire to B156 = Plus connector -4- (30) in wiring harness interior
      Aug 5th, 2002
      WA State
      303
      TT225, 76 Dasher, 2014 Golf
      08-15-2019 10:17 AM #3
      Curious what you've tried.
      Have you tried not having your AC on, (keep it on "economy") for a while? If so, does it still blow the fuse?
      If fuse stays good, does it immediately blow when turning on AC?
      Have you verified if the AC is actually working?
      Obviously all those questions are 100 percent related. That's where I'd start.
    6. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-16-2019 01:46 PM #4
      Thanks for asking!
      Edit: Fuse blows and battery dies whether or not I have A/C on.
      A/C does not work.
      What I've done so far:
      replaced the F129 switch
      replaced the radiator fans
      replaced the radiator thermo-switch for the fans
      replaced the Fan Control Module under the battery
      replaced fuse 16 several times now
      checked the voltage between pins 1 and 3 for the F129 switch with A/C on; voltage jumped around and the battery died very quickly after that.
    7. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-24-2019 03:55 PM #5
      Checked resistance at the A/C clutch coil, and it's good - 3.8 Ohms. Checked at the after-run coolant pump as well, but I'm not sure what that's supposed to be - came out to 1.2 Ohms.
      Still feels like looking for a needle in a haystack, but I'm thinking of borrowing one of those powered current checkers now - apply power to the fuse location, then use a tracer to see where it stops. I've seen people use them on youtube videos, but I've never used one myself...
    8. 08-24-2019 11:09 PM #6
      I would check your wiring to the alt and pump. This sounds like you have a wire grounding.
    9. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-28-2019 04:02 PM #7
      I agree. I definitely have a short to ground, and that's what's blowing my fuse.
      Wiring for the alt looks good, but I haven't taken it apart (it's bundled with the wiring for the A/C clutch coil, wrapped in a tight rubber tube).
      Wiring for the after-run coolant pump looks good, too, but it joins up with a bunch of other wires on the other side of the motor, so I'm still trying to figure out where the two sides meet. I think it's behind the motor somewhere, and I did do a bunch of work back there between rebuilding the turbo and replacing the downpipe/cat.
      I've also had the transmission and bevel box out twice in the last few years, but all the wires on TOP of the transmission look good.
      I hope we have today's weather again tomorrow, as I have the whole day 'off'. I still have to work from home, but I don't have to tend bar.
    10. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-30-2019 05:36 PM #8
      So I started testing continuity from G65 (a/c pressure switch), N25 (a/c clutch coil), and V51? (not sure; manual's not in front of me, but it's the After-Run Coolant Pump.
      I basically set my multimeter to continuity, and watched the numbers drop as I confirmed known grounds, and supposed open circuits.
      They all report no continuity on positive, no continuity on data, yes continuity on ground (I used the intake manifold for my ground in each case as it's right there).
      Remove battery, remove battery tray, remove new-ish J293 (Fan Control Module). 14-wire plug looks clean. 4-wire plug looks clean.
      I mocked the J293 (Fan Control module) back up in its installed position, and I can say that this wire was definitely touching the frame right next to it.
      I plan to put everything back together tomorrow and see what's good, but I bought five new fuses just in case.
      Edit: Not sure what's up with sharing a google image on here, but I'll fix it eventually so you can see the open wire.
    11. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-31-2019 02:14 PM #9
      Can someone tell me if the picture above is visible?
    12. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      08-31-2019 03:39 PM #10
      After wrapping that up and putting everything back together, I'm still blowing fuse 16.
      Fuse 16 blows as soon as I turn the ignition on, in fact.
      I'm wondering if the short circuit fried my Fan Control module...
    13. Member skills@eurocarsplus's Avatar
      May 27th, 2004
      Groton, Connecticut
      2,450
      08-31-2019 04:27 PM #11
      Quote Originally Posted by lite1979 View Post
      no photo on my end.
      if it's blowing on key on, it has to be a dead short. see what is on the 15 feed for that circuit (15 is key on +, 30 is + whenever the battery is hooked up etc)
    14. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-02-2019 08:11 PM #12
      Thanks. I'm thinking my short may be in the dashboard, then.
    15. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-03-2019 05:28 PM #13
      So though I fixed that wire, I think there's still a short inside my Fan Control Module. Once I disconnected it, Fuse 16 stopped blowing.
      The module is relatively new, but I think that bad wire messed up the FCM since I didn't know about the short...
    16. Member skills@eurocarsplus's Avatar
      May 27th, 2004
      Groton, Connecticut
      2,450
      09-03-2019 10:57 PM #14
      sounds like you're on the right track. you don't have a stuck fan do you? as in, the fan itself could be internally shorted
    17. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-05-2019 02:10 PM #15
      Image fixed. Had to create an imgur account, but I hope to be more active on here to make it worth it.
      Both fans spin just fine (and they're only three years old at this point).
      I'm waiting for a new FCM to come in the mail, then hopefully I can mark this thread as solved.
      What happened, if I understand correctly, is that wire was touching the frame, and in turn fried my Fan Control Module. I didn't know this was the reason my fans were staying on after shutting the car off, so I was checking for a parasitic drain.
      Naturally, in my process of checking for a parasitic drain, pulling fuses at night time checking to see if the amperage draw went to zero didn't help, because when I pulled fuse 16 it was already blown.
      When fuse 16 blows, the car makes the fans run all the time, because the Fan Control Module isn't in control anymore, and it's better to have a dead battery than to have a warped head from overheating, I guess.
      I replaced a bunch of stuff thinking the parts were bad, like my G65 A/C pressure switch (at the recommendation of the place that charged up my refrigerant). They were able to apply 12V to the A/C clutch coil and get cold air, so I figured either the radiator thermo-switch was bad or the FCM was bad. I replaced both, and still couldn't get cold air, and that's when I read about fuse16 and how the fans work if it's removed/blown.
      Hopefully I don't have to replace either the G65 or the radiator thermo-switch again once the new FCM comes in. I'll update when I get it.
    18. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-07-2019 06:28 PM #16
      Update:
      New FCM came in today. Installed it, hooked up the battery, fuse 16 blows. Grrr.
      Pulled the 30A fuse for the fans on top of the battery - fuse 16 does not blow. At this point, I think my short to ground has to be between the FCM and the fans. Am I right?
    19. Member skills@eurocarsplus's Avatar
      May 27th, 2004
      Groton, Connecticut
      2,450
      09-07-2019 09:58 PM #17
      Update:
      that's why I asked about the fans...
      even if they spin, they could be internally shorted (low speed to high, low to ground etc)
      I would put it all back together, put in all fuses, FCM etc and disconnect the fan(s) if the fuse(s) don't blow I would suspect the fan(s) are NFG
    20. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-10-2019 01:48 PM #18
      Fuse 16 still blows with the radiator fans disconnected (at the two 3-wire junctions, one female, one male).
      I'm going to inspect the wires going from T4 to its respective endpoints. Wondering if the radiator thermo-switch could be internally shorted?
    21. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-10-2019 06:40 PM #19
      Disconneting the radiator thermo-switch STILL blows the fuse.
    22. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-10-2019 06:46 PM #20
      Just disconnected the T4 from the FCM and tried again - fuse does not blow when T4 is disconnected. I think this suggests that the wires from T4 are grounded somewhere.
    23. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-10-2019 08:24 PM #21
      I'm still tracing the wires, and I don't see any clear evidence of shorts to ground. I'm behind the left headlight now, and this ground kind of stuck out to me:
    24. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-10-2019 10:22 PM #22
      I'm losing my mind on this one.
      I traced all four wires from T4 at the FCM to their respective destinations, and not one of them shows any sign of touching ground, anywhere.
    25. Member
      Aug 5th, 2002
      WA State
      303
      09-11-2019 10:35 AM #23
      You'll figure it out eventually. So many of us have been there for one reason or another. Wish I had more than just words of encouragement.
    26. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-11-2019 04:11 PM #24
      I was thinking, since it doesn't blow until I turn the ignition on, maybe I'm looking at this the wrong way.
      Ignition switch goes to Plus connection (15) in instrument panel wiring harness on a 2.5mm black wire.
      That black wire goes to fuse 5 (7.5 amps - fuse is fine) on the left of the dash. - if the fault were in this circuit, the 7.5 Amp fuse would blow, correct? It doesn't though, so I think that once the fan relay in the FCM is activated, that's what causes fuse 16 to blow. Low power from ignition activates the relay, high power from the fan circuit goes back through the FCM to a peripheral with no resistance, which in turn blows the fuse.
      From the fuse panel, a 0.5mm black/blue wire goes to B135 connector inside dash board, and splits to both G65 in the engine bay (A/C pressure switch), and T17 behind instrument panel > D/9 at the HVAC control head.
      I'll trace the wires from the ignition switch and report my findings. It's also possible that the G65 wiring is to blame, since that's on the same circuit, but when I tested for continuity on the G65 connector, ground was continuous, and neither the data nor the hot wire showed continuity to ground. Perhaps that because the ignition was off when I tested.
    27. Member lite1979's Avatar
      Sep 9th, 2005
      North Buffalo
      1,913
      2001 Audi TT 225 QC
      09-30-2019 03:46 PM #25
      My next step is to remove all of the wires from T14 except the red one (power). If the fuse doesn't blow, then I'm re-connecting each wire to T14 until it does, then chasing that wire down for cracks/missing insulation...
