Fourtitude.com - 06A 1.8T water pump in ABF/ABA
    Results 1 to 2 of 2
    1. 08-07-2019 08:50 AM #1
      Hi
      I’m wondering if someone tried to use 058 1.8T water pump in ABF/ABA? It has single inlet water port so coolant system should be less complicated.
      I would like to remove also few things:
      1. Heater
      2. Oil cooler (I’m going to use external oil cooler with Mocal sandwich plate)
      3. Extension tank (I’m going to use radiator with cap).
      This is standard diagram of cooling.
      After modification sould looks like:
      Regards
      Lukas
    3. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      12,708
      '90 Corrado | '62 Harley Panhead
      08-08-2019 04:10 PM #2
      If you are not running a Heater Core or h20->oil Cooler then there is no real need for the extra nipple, and the AEB pump should work fine.
      Just don't under size the return from the head to that nipple above the Thermo. You want that circulation loop flowing at all times to even out head temps (esp while thermostat is closed).
