I am chasing some ignition timing issues with my Unitronic K04 on my MkV. It's a FSI motor.
Got some logs over the last few days but I need a point of reference on what the numbers should look like on a car that is running well.
*Need a WOT pull from 30mph in 3rd gear if some of you can share your logs. The more logs the better!
Channels I am interested in:
Group 1-0: RPM
Group 3-3: Ignition Timing Angle
Group 20-0: Timing Pull Cylinder 1
Group 20-1: Timing Pull Cylinder 2
Group 20-2: Timing Pull Cylinder 3
Group 20-3: Timing Pull Cylinder 4
Group 30-0: Lambda (Actual)
Group 54-2: Accelerator Pedal %
Group 101-2: Injection timing
Group 115-2: Boost (Requested)
Group 115-3 Boost (Actual)
Group 230-1: Rail Pressure (Actual)
Group 1-0: RPM
