Fourtitude.com - multiple codes
    Results 1 to 6 of 6
    Thread: multiple codes
    1. Junior Member
      Jan 6th, 2009
      Pottstown,PA
      62
      2010 CC Lux 2.0T DSG
      07-24-2019 07:31 PM #1
      Hey all.
      Got a MIL on my way home today and did a scan. Googled each but I'm curious if they could be related.
      Could a faulty intake manifold cause all 3 codes?
      (I only care about the engine codes)
      Wednesday,24,July,2019,18:28:01:16603
      VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
      VCDS Version: 19.6.0.6 (x64)
      Data version: 20190529 DS308.0
      www.Ross-Tech.com
      Chassis Type: AN-VW46 (3C0)
      Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 37 42 44 46 4F 52 53
      56 62 65 6C 72 77
      VIN: WVWHL7AN1AE523027 Mileage: 153370km-95299miles
      01-Engine -- Status: Malfunction 0010
      02-Auto Trans -- Status: OK 0000
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      10-Park/Steer Assist -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      36-Seat Mem. Drvr -- Status: OK 0000
      37-Navigation -- Status: Malfunction 0010
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      4F-Centr. Electr. II -- Status: OK 0000
      53-Parking Brake -- Status: OK 0000
      56-Radio -- Status: Malfunction 0010
      62-Door, Rear Left -- Status: OK 0000
      65-Tire Pressure -- Status: OK 0000
      6C-Back-up Cam. -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
      Part No SW: 06J 906 026 DA HW: 06J 906 026 DA
      Component: MED17.5 TFSI 2,0 6987
      Revision: AAH07--- Serial number: VWZCZ000000000
      Coding: 0404010A1C070160
      Shop #: WSC 06404 444 12163
      VCID: 6CDDDC904FCB2C2F59-8038
      5 Faults Found:
      008583 - Bank 1; System too Lean at Idle
      P2187 - 000 - - Intermittent
      Freeze Frame:
      Fault Status: 00100000
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Mileage: 153330 km
      Time Indication: 0
      Date: 2013.12.14
      Time: 17:03:20
      Freeze Frame:
      RPM: 834 /min
      Load: 31.8 %
      Speed: 0.0 km/h
      Temperature: 78.0°C
      Temperature: 40.0°C
      Absolute Pres.: 1000.0 mbar
      008213 - Intake Manifold Flap Position Sensor (Bank 1)
      P2015 - 000 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 5
      Reset counter: 255
      Mileage: 153357 km
      Time Indication: 0
      Date: 2013.12.14
      Time: 17:37:45
      Freeze Frame:
      RPM: 2094 /min
      Load: 96.0 %
      Speed: 102.0 km/h
      Temperature: 95.0°C
      Temperature: 43.0°C
      P2015 - 000 - Implausible Signal - Intermittent - MIL ON
      Freeze Frame:
      Fault Status: 10100000
      Fault Priority: 0
      Fault Frequency: 9
      Reset counter: 255
      Mileage: 153357 km
      Time Indication: 0
      Date: 2013.12.14
      Time: 17:37:52
      Freeze Frame:
      RPM: 2314 /min
      Load: 16.1 %
      Speed: 115.0 km/h
      Temperature: 95.0°C
      Temperature: 42.0°C
      Absolute Pres.: 990.0 mbar
      001287 - Idle Control System RPM
      P0507 - 000 - Higher than Expected. - MIL ON
      Freeze Frame:
      Fault Status: 11100000
      Fault Priority: 0
      Fault Frequency: 2
      Reset counter: 255
      Mileage: 153366 km
      Time Indication: 0
      Date: 2013.12.14
      Time: 17:43:15
      Freeze Frame:
      RPM: 1097 /min
      Load: 20.4 %
      Speed: 0.0 km/h
      Temperature: 93.0°C
      Temperature: 51.0°C
      P2015 - 000 - Implausible Signal - MIL ON
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 5
      Reset counter: 255
      Mileage: 153366 km
      Time Indication: 0
      Date: 2013.12.14
      Time: 17:44:03
      Freeze Frame:
      RPM: 2092 /min
      Load: 25.1 %
      Speed: 46.0 km/h
      Temperature: 94.0°C
      Temperature: 45.0°C
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 02E-927-770.clb
      Part No SW: 02E 300 051 P HW: 02E 927 770 AJ
      Component: GSG DSG AG6 440 1912
      Revision: 00044002 Serial number: 00000909081308
      Coding: 0000020
      Shop #: WSC 05311 000 00000
      VCID: 2045F8A0F383384FB5-8074
      No fault code found.
      Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
      Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
      Component: J104 C4 440 V2 0015
      Revision: --025--- Serial number: 00000795576352
      Coding: 0000380
      VCID: 62C1B2A8BD0F6A5FE3-8036
      Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
      Part No SW: 5K0 907 044 BK HW: 5K0 907 044 BK
      Component: Climatronic H14 0608
      Revision: 00003001
      Coding: 0000000000
      Shop #: WSC 05311 115 00000
      ASAM Dataset: EV_Climatronic A01001
      ROD: EV_ClimaAutoBasis_VW46.rod
      VCID: 75EBF9F4D481EDE7B6-8020
      Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
      Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
      Component: Bordnetz-SG H54 2602
      Revision: 00H54000 Serial number: 00000003319945
      Coding: F1848F8B40041A0047970F00170000000028FF475C40017C17 0000000000
      Shop #: WSC 05124 123 12345
      VCID: 336F07EC5275B3D758-8066
      Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
      Component: Wischer 300709 022 0602
      Coding: 00046997
      Shop #: WSC 05124
      Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
      Component: RLS 080909 046 0204
      Coding: 00471077
      Shop #: WSC 05124
      4 Faults Found:
      01504 - Bulb for License-Plate Light (X)
      012 - Electrical Fault in Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00101100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 62
      Mileage: 152999 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 11.80 V
      ON
      ON
      OFF
      OFF
      OFF
      00985 - Right Tail Light (M2)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 32
      Mileage: 151838 km
      Time Indication: 0
      Freeze Frame:
      ON
      Voltage: 12.95 V
      ON
      ON
      OFF
      OFF
      ON
      02071 - Local Databus
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 2
      Fault Frequency: 12
      Reset counter: 65
      Mileage: 148854 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 12.20 V
      OFF
      ON
      OFF
      OFF
      OFF
      01520 - Rain and Light Recognition Sensor (G397)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 12
      Reset counter: 65
      Mileage: 148854 km
      Time Indication: 0
      Freeze Frame:
      OFF
      Voltage: 12.25 V
      OFF
      ON
      OFF
      OFF
      OFF
      Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
      Part No SW: 3C8 919 475 A HW: 3C8 919 475
      Component: PARKHILFE 8K H07 0009
      Revision: -------- Serial number: 08720924602632
      Coding: 300101
      Shop #: WSC 05314 000 00000
      VCID: 326102E86D6FBADF53-8066
      Address 15: Airbags Labels: 5N0-959-655.lbl
      Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
      Component: J234__302 VW10 HI 1916
      Revision: 20013000 Serial number: 003E1PJ0Y3MZ
      Coding: 0012338
      VCID: 428152281DCF0A5FC3-8016
      Subsystem 1 - Part No: 3C8 959 339
      Component: BF-Gewichtsens. 001 0003
      Subsystem 2 - Serial number: 00000000004EF5
      Subsystem 3 - Serial number: 0013.08.090000100000640044˙†63
      Subsystem 4 - Serial number: 640044˙†6332MTS603132389 ˙†63
      Subsystem 5 - Serial number: 32389 ˙†6342MTS604062389 ˙†63
      Subsystem 6 - Serial number: 62389 ˙†6351HTS6IMG056KR ˙†63
      Subsystem 7 - Serial number: 056KR ˙†6361HTS67VF356KR ˙†63
      Subsystem 8 - Serial number: 356KR ˙†63727TS6Q0P609KR ˙†63
      Subsystem 9 - Serial number: 609KR ˙†63827TS6GV9709KJ ˙
      Subsystem 10 - Serial number: 709KJ ˙
      Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
      Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
      Component: J0527 0030
      Revision: 00032000 Serial number: 3C5953507CN
      Coding: 0001711
      VCID: 74EDC4F017FBF4EF81-8020
      Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
      Component: E221__MFL-TK6 H05 0022
      Coding: 00000226
      Shop #: WSC 00000
      Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
      Part No SW: 3C8 920 970 J HW: 3C8 920 970 J
      Component: KOMBI H02 0206
      Serial number: 00000000000000
      Coding: 240F00
      Shop #: WSC 05314 115 00000
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
      ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
      VCID: 336F07EC9A75B3D758-8066
      Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
      Part No SW: 3C0 907 530 J HW: 3C0 907 951
      Component: J533__Gateway H13 0152
      Revision: H13 Serial number: 2900R09828807D
      Coding: FDA0FF07404613009002
      VCID: 2855E0809BB3C00FFD-807C
      Address 25: Immobilizer Labels: 3C0-959-433-25.clb
      Part No SW: 3C0 959 433 AP HW: 3C0 959 433 AP
      Component: IMMO 052 0383
      Revision: 00052000 Serial number: VWZCZ000000000
      VCID: 78F5F0C00B93908FAD-802C
      Subsystem 1 - Part No: 3C0 905 861 H
      Component: ELV 028 0380
      3C0905861H ELV 028 0380
      Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
      Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
      Component: SG EXT.PLAYER H13 0090
      Revision: A1001003 Serial number: 7667571429
      Coding: 010000
      VCID: 2649EEB851A7D67FCF-8072
      Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
      Part No SW: 3C8 959 760 HW: 3C8 959 760
      Component: J810 0801
      Revision: 00002000 Serial number: 00000000000000
      Coding: 0000001
      VCID: 72E1C2E86DEFFADF93-8026
      Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
      Part No SW: 3C0 035 684 C HW: 3C0 035 684 A
      Component: RNS-MID H02 1140
      Revision: AB001001 Serial number: VWZ6Z7J9239081
      Coding: 06000440040000A400
      Shop #: WSC 05314 123 12345
      VCID: 234FF7AC22952357A8-8076
      2 Faults Found:
      00857 - CD Changer Unit (R41)
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 5
      Fault Frequency: 254
      Reset counter: 30
      Mileage: 146216 km
      Time Indication: 0
      Date: 2019.03.29
      Time: 17:59:37
      02635 - Tuner Not Enabled/Activated
      000 - -
      Freeze Frame:
      Fault Status: 01100000
      Fault Priority: 7
      Reset counter: 30
      Mileage: 146216 km
      Time Indication: 0
      Date: 2019.03.29
      Time: 19:01:09
      Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
      Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
      Component: J386 TUER-SG FT 1533
      Revision: 71009005 Serial number: 00000886298813
      Coding: 0001463
      VCID: 4085582013C3184FD5-8014
      Address 44: Steering Assist Labels: 5N1-909-144.clb
      Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
      Component: J500__APA-BS KL.141 0703
      Revision: 1AH03256 Serial number: 00092020139502
      Coding: 0000258
      Shop #: WSC 55553 001 1048576
      VCID: 3A712AC8751F429F9B-806E
      Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
      Component: KSG PQ46 RDK 052 0412
      Coding: 1B910F8001860C763202141FF08A8F0E085801
      Shop #: WSC 05311 123 12345
      Subsystem 1 - Component: Sounder n.mounted
      Subsystem 2 - Component: NGS n.mounted
      Subsystem 3 - Component: IRUE n.mounted
      Address 4F: Centr. Electr. II (J533_) Labels:. 1K0-907-532.clb
      Part No SW: 1K0 907 532 HW: 3C0 907 951
      Revision: -------- Serial number: 2900R09828807D
      Coding: 01030100
      VCID: 66C9AEB89127167F0F-8032
      Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
      Component: J245/J878 H04 0054
      Serial number: 933200075005
      Coding: 000006
      Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
      Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
      Component: J387 TUER-SG BT 1533
      Revision: 71009005 Serial number: 00000884498828
      Coding: 0001462
      VCID: 41835D2418C91147DA-8014
      Address 53: Parking Brake Labels: 5N0-907-801.clb
      Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
      Component: J540 EPB3 VW-15417 0007
      Revision: 010 Serial number: 00000000023146
      Coding: 0000057
      VCID: 2C5D1C908F4BEC2F19-8078
      Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
      2 Faults Found:
      Freeze Frame:
      Fault Priority: 5
      Reset counter: 30
      Mileage: 146216 km
      Time Indication: 0
      Date: 2019.03.29
      Time: 17:59:37
      000 - -
      Freeze Frame:
      Fault Priority: 7
      Reset counter: 30
      Mileage: 146216 km
      Time Indication: 0
      Date: 2019.03.29
      Time: 19:01:09
      Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
      Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
      Component: J388 TUER-SG HL 0309
      Revision: 43004101 Serial number: 00000001062646
      Coding: 0001168
      VCID: 31630DE4A86981C72A-8064
      Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
      Component: RDK 0453
      Coding: 0100101
      Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
      Part No SW: 3C8 907 441 HW: 3C8 907 441
      Component: J772__Rearview 0022
      Revision: 00H06000 Serial number: 525PA8-J970133
      Coding: 0120008
      VCID: 67D7A3BC562D0F7734-8032
      Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
      Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
      Component: J388 TUER-SG HR 0309
      Revision: 43004101 Serial number: 00000001060215
      Coding: 0001168
      VCID: 326102E8AD6FBADF53-8066
      Address 77: Telephone Labels: 5P0-862-335.lbl
      Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
      Component: FSE_2P8x H35 0170
      Revision: 00000000 Serial number: 00000005084135
      Coding: 0013077
      VCID: 387530C04B13508F6D-806C
      End-------------------------(Elapsed Time: 03:31)--------------------------
    3. 07-24-2019 08:45 PM #2
      Flapper motor would be my bet...
      Sent from my SM-G965U using Tapatalk
      Shade Tree Wrencher
      2010 Jetta Wolfsburg 2.0T
    4. Member joeyfrost's Avatar
      Feb 26th, 2017
      Greater NYC
      721
      MK6 Golf R
      07-24-2019 08:51 PM #3
      Yea same suggestion over here. look around your mani to see anything obvious.
      MKVI Golf R
      Stage 2+
      IG: Charlotte.Mk6R
    6. Junior Member
      Jan 6th, 2009
      Pottstown,PA
      62
      09-13-2019 08:25 AM #4
      Just to finish this up, I finally got it to the dealer. They replaced the intake manifold under the extended warranty. Cleaned the intake valves and replaced the breather valve (PCV).
      $581.00 out of pocket.
    7. 12-26-2019 01:29 PM #5
      Sorry man, just saw this. I have a spare good intake from my 2010 Jetta Wolfsburg 2.0T that I'd be willing to part with.
      Why, you ask? Water pump failed - figured I'd do this, injectors, plugs valve cleaning, high pressure pump all while I had them off for the water pump...
      Sent from my SM-N970U using Tapatalk
      Shade Tree Wrencher
      Nov 27th, 2011
      MD
      6,331
      12-27-2019 08:37 PM #6
      Quote Originally Posted by eljw24 View Post
      Hey all.
      Code:
      www.Ross-Tech.com
                56 62 65 6C 72 77
      5 Faults Found:
                   Freeze Frame:
                          Fault Priority: 0
                          Fault Frequency: 1
                          Reset counter: 255
                          Mileage: 153330 km
                          Time Indication: 0
                          Date: 2013.12.14
                          Time: 17:03:20
                   Freeze Frame:
                          RPM: 834 /min
                          Load: 31.8 %
                          Speed: 0.0 km/h
                          Temperature: 78.0°C
                          Temperature: 40.0°C
                   Freeze Frame:
                          Fault Priority: 0
                          Fault Frequency: 5
                          Reset counter: 255
                          Mileage: 153357 km
                          Time Indication: 0
                          Date: 2013.12.14
                          Time: 17:37:45
                   Freeze Frame:
                          RPM: 2094 /min
                          Load: 96.0 %
                          Speed: 102.0 km/h
                          Temperature: 95.0°C
                          Temperature: 43.0°C
                   Freeze Frame:
                          Fault Priority: 0
                          Fault Frequency: 9
                          Reset counter: 255
                          Mileage: 153357 km
                          Time Indication: 0
                          Date: 2013.12.14
                          Time: 17:37:52
                   Freeze Frame:
                          RPM: 2314 /min
                          Load: 16.1 %
                          Speed: 115.0 km/h
                          Temperature: 95.0°C
                          Temperature: 42.0°C
                   Freeze Frame:
                          Fault Priority: 0
                          Fault Frequency: 2
                          Reset counter: 255
                          Mileage: 153366 km
                          Time Indication: 0
                          Date: 2013.12.14
                          Time: 17:43:15
                   Freeze Frame:
                          RPM: 1097 /min
                          Load: 20.4 %
                          Speed: 0.0 km/h
                          Temperature: 93.0°C
                          Temperature: 51.0°C
                   Freeze Frame:
                          Fault Priority: 0
                          Fault Frequency: 5
                          Reset counter: 255
                          Mileage: 153366 km
                          Time Indication: 0
                          Date: 2013.12.14
                          Time: 17:44:03
                   Freeze Frame:
                          RPM: 2092 /min
                          Load: 25.1 %
                          Speed: 46.0 km/h
                          Temperature: 94.0°C
                          Temperature: 45.0°C
         Coding: 0000020
         Coding: 0000380
         Revision: 00003001
         Coding: 0000000000
         Coding: F1848F8B40041A0047970F00170000000028FF475C40017C170000000000
         Coding: 00046997
         Shop #: WSC 05124
         Coding: 00471077
         Shop #: WSC 05124
      4 Faults Found:
                   Freeze Frame:
                          Fault Priority: 2
                          Fault Frequency: 1
                          Reset counter: 62
                          Mileage: 152999 km
                          Time Indication: 0
                   Freeze Frame:
                              ON
                          Voltage: 11.80 V
                              ON
                              ON
                              OFF
                              OFF
                              OFF
                   Freeze Frame:
                          Fault Priority: 2
                          Fault Frequency: 1
                          Reset counter: 32
                          Mileage: 151838 km
                          Time Indication: 0
                   Freeze Frame:
                              ON
                          Voltage: 12.95 V
                              ON
                              ON
                              OFF
                              OFF
                              ON
                   Freeze Frame:
                          Fault Priority: 2
                          Fault Frequency: 12
                          Reset counter: 65
                          Mileage: 148854 km
                          Time Indication: 0
                   Freeze Frame:
                              OFF
                          Voltage: 12.20 V
                              OFF
                              ON
                              OFF
                              OFF
                              OFF
                   Freeze Frame:
                          Fault Priority: 2
                          Fault Frequency: 12
                          Reset counter: 65
                          Mileage: 148854 km
                          Time Indication: 0
                   Freeze Frame:
                              OFF
                          Voltage: 12.25 V
                              OFF
                              ON
                              OFF
                              OFF
                              OFF
         Coding: 300101
         Coding: 0012338
         Coding: 0001711
         Coding: 00000226
         Shop #: WSC 00000
         Coding: 240F00
         Coding: 010000
         Coding: 0000001
      2 Faults Found:
                   Freeze Frame:
                          Fault Priority: 5
                          Reset counter: 30
                          Mileage: 146216 km
                          Time Indication: 0
                          Date: 2019.03.29
                          Time: 17:59:37
                  000 - -
                   Freeze Frame:
                          Fault Priority: 7
                          Reset counter: 30
                          Mileage: 146216 km
                          Time Indication: 0
                          Date: 2019.03.29
                          Time: 19:01:09
         Coding: 0001463
         Coding: 0000258
         Coding: 01030100
         Coding: 000006
         Coding: 0001462
         Coding: 0000057
      2 Faults Found:
                   Freeze Frame:
                          Fault Priority: 5
                          Reset counter: 30
                          Mileage: 146216 km
                          Time Indication: 0
                          Date: 2019.03.29
                          Time: 17:59:37
                  000 - -
                   Freeze Frame:
                          Fault Priority: 7
                          Reset counter: 30
                          Mileage: 146216 km
                          Time Indication: 0
                          Date: 2019.03.29
                          Time: 19:01:09
         Coding: 0001168
         Component:    RDK              0453
         Coding: 0100101
         Coding: 0120008
         Coding: 0001168
         Coding: 0013077
      VW has a warranty extension for intake manifold for 10 years 120K based on VIN, I would see the dealer and see if you qualify.
