Fourtitude.com - 3.6 BLV swap stalling when hot
    Results 1 to 4 of 4
      Jul 4th, 2016
      Palmyra, PA
      257
      92 Corrado 3.6, 2009 Taco Double Cab TRD-OR
      07-17-2019 09:11 PM #1
      Hello all - car is a Corrado with a 2006 3.6L BLV engine from a Passat. Car seems to run fine until fully warmed up, stalls and will not start again till it cools off. Below is the VCDS scan and some shots of group 103. I'm most curious about this since the adaptation value steadily increases to 2500 and from what I have read this value should be between -/+ 1000. I tried a different fuel pump control unit and that did not change anything which is leading me to believe there is a fuel pump issue.
      Several codes relate to control units not swapped over and some 02 sensor codes since only the front 2 are installed.
      Thanks in advance!
      Wednesday,17,July,2019,20:45:47:46012
      VCDS Version: Release 19.6.0 (x64) Running on Windows 7 x64
      www.Ross-Tech.com
      Address 01: Engine Labels: 03H-906-032-BLV.CLB
      Control Module Part Number: 03H 997 033 M HW: Hardware No
      Component and/or Version: P3.6-FSI-LEV2 G00 2370
      Software Coding: 0000175
      Work Shop Code: WSC 00028 028 00001
      VCID: 372B2BC2B346BF7F3BF-8062
      15 Faults Found:
      049409 - No Communication with Transmission Control Module
      U0101 - 008 -
      Freeze Frame:
      Fault Status: 01101000
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Absolute Pres.: 980.0 mbar
      Voltage: 11.938 V
      049493 - No Communication with Instrument Cluster
      U0155 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      049508 - No Communications with HVAC Control Module (J301)
      U0164 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      049489 - No Communications with Airbag Control Module
      U0151 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      049448 - No Communications with Parking Brake Control Module
      U0128 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      049478 - No Communication with Diagnostic Gateway
      U0146 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      U0146 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      005715 - Please check DTC Memory of ABS Controller
      P1653 - 001 -
      Freeze Frame:
      Fault Status: 01100001
      Fault Priority: 0
      Fault Frequency: 2
      Reset counter: 255
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      U0146 - 008 -
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 33.0C
      Voltage: 11.938 V
      001152 - Coolant Fan Control Circuit 1
      P0480 - 004 - Electrical Malfunction
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 755 /min
      Load: 41.9 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 32.0C
      Voltage: 11.430 V
      009216 - EVAP Leak Detection Pump Control Circuit
      P2400 - 004 - Malfunction
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 835 /min
      Load: 32.5 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 30.0C
      Voltage: 13.716 V
      012555 - Low Pressure Fuel regulation
      P310B - 008 - Fuel Pressure Outside Specification
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 2
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 880 /min
      Load: 36.5 %
      Speed: 0.0 km/h
      Temperature: 33.0C
      Temperature: 30.0C
      Voltage: 13.716 V
      P310B - 004 - Fuel Pressure Outside Specification
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 891 /min
      Load: 26.3 %
      Speed: 0.0 km/h
      Temperature: 57.0C
      Temperature: 32.0C
      Voltage: 13.589 V
      000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
      P0036 - 004 - Malfunction / Open Circuit
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 883 /min
      Load: 26.7 %
      Speed: 0.0 km/h
      Temperature: 69.0C
      Temperature: 35.0C
      Voltage: 12.446 V
      000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
      P0056 - 004 - Malfunction / Open Circuit
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Reset counter: 255
      Time Indication: 0
      Freeze Frame:
      RPM: 905 /min
      Load: 26.3 %
      Speed: 0.0 km/h
      Temperature: 69.0C
      Temperature: 35.0C
      Voltage: 13.716 V
      Readiness: 0110 0101
      Group 103 while car runs
      Group 103 after stall
      Former username: Magics5rip
      Corrado 3.6 build thread
    3. 07-23-2019 10:07 AM #2
      Hi!
      maybe a long shot, I'm no expert, but sounds remarkably similar to my Mk4 v6 2.8l BDE engine problem: fine when cool, wouldn't restart when hot. After trying a new fuel regulator and other "small easy/cheap things", it was off with the gearbox, replaced timing chains/guides/tensioners and intermediate sprocket, problem all gone now.
      The cam chain was beginning to rattle at ~1600 rpm, and I was getting cam/crank sensor errors occasionally.
      Old chains were clearly stretched (not shown using VCDS measuring blocks) and the intermediate sprocket teeth were VERY badly worn; reckon I was lucky not to have slipped a tooth leading to the destruction of the engine! Poor maintenance by previous owners I guess
      Did you physically check and/or replace the chains before putting the replacement engine in?
      It would probs be a good idea to get DTC sorted first, presume all the looms are OK, then any stall-related codes might be more specific !?
      Cheers and good luck!
      Jul 4th, 2016
      Palmyra, PA
      257
      07-23-2019 02:08 PM #3
      Quote Originally Posted by alicat_platina View Post
      Hi!
      I had read about people having this issue when the HPFP slips a took from the chains being worn. However, the engine got all new chains and guides before it went in the car and I even bought the HPFP cam locking tool so that it was oriented correctly when the chains went in.
      That being said...
      I got a low mileage LPFP and the old pump may have been the problem all along. Group 103 now shows a stable adjustment value and the car was hot and idled for a good bit and did not stall. Nice! Also, one of the plastic lines coming off the pump that I had plugged with two part epoxy softened up and blew out because it was submerged in gasoline. I'm sure this contributed to the problem. Either way, its fixed now!
      Group 103 with new pump
      Lets look at the internal filter for each of them. This was probably the culprit. Its the tea bag looking thing in this pictures...
      Old pump (dirty and clogged)
      Not as old pump (much cleaner)
    6. 07-25-2019 10:30 AM #4
      Quote Originally Posted by choobs View Post
      That being said...
      Great, a much easier fix!
