Fourtitude.com - Lowered/Stanced Ferarris.. Yay or Nay?
    Page 4 of 4 FirstFirst 1234
    Results 76 to 86 of 86
    1. 07-11-2019 10:04 AM #76
      I don't particularly care either way. Some of those look neat-o. I like lowered things. That said if you gave me a F40 I'd likely leave it alone.
      _/_/_/__/___/____/_____/______/_______/________/_________/__________/
      Dub Cult | Simply Clean
    3. Member Chris_V's Avatar
      Jun 18th, 2009
      Pikesville, MD
      18,555
      '13 Volt, '20 Bolt, '02 Suburban 2500LT
      07-11-2019 10:20 AM #77
      Quote Originally Posted by Nealric View Post
      I suppose if it makes you happy, fine. Still won't make me like it. There is no way you can lower a car 4 inches without reducing suspension travel and ground clearance. More likely to scrape on speed bumps, potholes. If you didn't correct the suspension geometry, lowering a car 4 inches will usually cause some nasty bump steer. You are realistically looking at re engineering the entire suspension to lower a car that much properly.
      No, actually. I raised the upper shock mount an inch, raised the upper a-arm mount an inch (unnecessary, but a common mod on lowered early Mustangs, which are just pretty Falcons, lol) and used 4" shorter coil springs. The rear was leafs with 3" lowering blocks, so the geometry didn't change at all (what little geometry there is in a solid axle, leaf spring suspension). Set the toe properly and as you can see there's no camber or caster change. I drove that car for 4 years with no issues, no weird tire wear, and even though it was only an inch and a half off the ground at the crossmember, never scraped on speed bumps and in the PNW, there were almost zero potholes to worry about (and if there were it was easy to drive around them). I have decades of lowered car experience as daily drivers, both track at an just lowered street cars.
      Again, you have zero direct experience, just an ill-informed opinion that you use to be insulting. Why is that a valuable goal for you?
      "Like a fine Detroit wine, this vehicle has aged to budgetary perfection"
    4. I had to ask.... Turbo II's Avatar
      Jun 9th, 2017
      2,227
      4-door Mustang GT 4.6L
      07-11-2019 02:33 PM #78
      There is a right way to tune a Ferrari and a wrong way. Lowered is fine, but camber just looks bad. Ferraris really don't need much to look good
    5. Member
      Oct 25th, 2002
      Ozarks
      937
      2006 Slow Honda Insight
      07-11-2019 03:04 PM #79
      Nope
      2006 Slow Honda Insight runabout
      2005 Lava Orange MazdaSpeed Miata Hers
      2013 Prius V Hers
      2007 Jeep GC CDI Ours
      2002 Ram Cummins Ours
    6. Member Nealric's Avatar
      Feb 16th, 2013
      8,014
      '16 WRX STI, Turbo S3 Alfa Spider, 2020 Ascent
      07-11-2019 03:09 PM #80
      Quote Originally Posted by Chris_V View Post
      I don't doubt that some of the lowrider types are well engineered, and there's certainly craftsmanship to it. But there are also a LOT of lowered cars that are downright dangerous. Kudos to you for doing it right.
      If you like it, more power to you. It just doesn't personally do it for me. I'm not saying it to be insulting. The question for the thread was whether you like lowered cars. Sorry, but I just don't unless there is a compelling performance reason for it.
      The great thing about aesthetics is it's pretty much all BS anyways
    7. Member TurboREX's Avatar
      Aug 6th, 2006
      Fancy CT
      5,481
      4 Cars, 30 cylinders, 2 turbos, 1500hp and 23 gears
      07-11-2019 06:06 PM #81
      i love it on the 90's cars, ppl need to drive these things so id rather see them bagged then not at all.
    8. Member PainKiller's Avatar
      Oct 3rd, 2007
      by the mountain
      10,388
      02 24V GTI - outback - 84 Softail
      07-11-2019 07:06 PM #82
      HARD NO
      And all those with the camber, seriously ... NO
      Quote Originally Posted by Mr Miyagi View Post
      Please tell me how this does. I have a massive amount of stuff I need to kill
      Quote Originally Posted by TheDarkEnergist View Post
      Sprinkle some of your personality on it.
      PSN: PainKiller-sas-
    9. 07-11-2019 07:10 PM #83
      Nay
      Americans hate EVs because they grew up with Power Wheels that were glacially slow, ran out of power in 20 minutes and took an entire day to recharge.
    10. Member worth_fixing's Avatar
      Dec 23rd, 2009
      Montreal, Qc
      7,089
      2014 Mazda3 Sport GS - 1982 Honda CB750K
      07-11-2019 07:12 PM #84
      lowered: not sure what the point would be. it's engineered to have that ride height for optimal road and track use.
      leave it as is, you're not improving anything.
      stanced : doing it wrong, for the wrong reasons on any car. i don't care how dope you think it is. it's dumb. just stop it.
      http://badges.fuelly.com/images/sig-metric/286588.png
      Any car which holds together for a whole race is too heavy.
    11. Member Senior Member's Avatar
      Jul 1st, 2016
      Original Join Date 2001 Central NJ
      2,340
      OG 2001 Jetta 1.8t
      07-11-2019 07:28 PM #85
      It's nothing more than a stupidity cycle. Rich stupidity vs. poor stupidity.
      Quote Originally Posted by LooseNuts View Post
      Yeah and it was the dummest joke ever were no one laught and everyone made fun of.
      The relevance to the stupid camber he did still pertains to this thread.
      The cops did all of us a favor by impornding the POS and potentially saving others lives.
      Heres the link to the stupidity
      https://forums.vwvortex.com/zerothre...4581867&page=1
    12. Geriatric Member Chapel's Avatar
      Jun 23rd, 1999
      Boston
      54,592
      12 XC70 T6 | 09 Silverado
      07-11-2019 08:43 PM #86
      Quote Originally Posted by Senior Member View Post
      **** yes
