Hello, I have spacer Engilsh an audi A3 8v version from 2013. unfortunately I have a problem with recoding the abs controller with RHD on LHD because I do not know which bit (bytes) need to be recoded maybe someone has some kind of coding calculator or knows exactly which is the number
Thank you in advance
Code:
Friday,28,June,2019,20:33:11:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WAUZZZ8V5EA008112 License Plate:
Mileage: 126064km-78332mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V5EA008112 Mileage: 126064km-78332miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5514
Revision: 83H22---
Coding: 02190012032401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79F8D578F8D95389AE-802C
1 Fault Found:
17158 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 126064 km
Date: 2019.06.28
Time: 20:21:14
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 66 °C
Intake air temperature: 61 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.140 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 4
Drivetrain coordinator: brake function status-Bit 0: 0
Drivetrain coordinator: brake function status-Bit 8: 0
Acceleration: 0.000 m/s˛
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61443000000146
Coding: 12F18AA224200A740178060141C5294851245080608294F2026100040508
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
VCID: 7BF4CF70F2E56199BC-802E
2 Faults Found:
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Date: 2019.06.28
Time: 20:21:43
8299 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Date: 2019.06.28
Time: 20:21:43
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 B HW: 8V0 820 047 B
Component: AC Manuell el H09 0031
Revision: 20017000 Serial number: 00000000017730
Coding: 03000104002000001000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008016
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 35601948944177E90A-8060
1 Fault Found:
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 126064 km
Date: 2019.06.28
Time: 20:20:23
Outside air temperature: 21.5 °C
Compressor current: actual value: 0.000 A
Temperature after evaporator: 38.6 °C
Refrigerant pressure: 1.2 bar
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 196 s
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011314700504
Coding: 07000842C241005D03844004B31407080000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_011.rod
VCID: 489E60BCF3B3FA0161-801C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 131017 041 0580
Serial number: 131019012827
Coding: 0A47F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 N HW: 8V0 941 531 N
Component: E1 - LDS MQB H05 0032
Serial number: 13 04 2013 00000002
Sensor For Anti Theft Alarm System:
Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131001TFP
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000056772756
No fault code found.
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831315100221
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 387E107C83538A8111-806C
1 Fault Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 126064 km
Date: 2019.06.28
Time: 20:18:06
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01RMM/
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4B945FB0E2C511194C-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 405 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000FC1012D0T
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 405 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000008B1012D0M
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 705 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502BD1050662211R
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 705 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502C9105EDD4425J
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 402 404 13
Component: FrontSensor_D 001 6149
Serial number: 3556502C7101233342CX
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 605 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502C5105065231BX
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_P --- ----
Serial number: -------------------$
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 605 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C11050653E12P
Coding: 2D2D2D
3 Faults Found:
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
B1033 15 [137] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126064 km
Date: 2019.06.28
Time: 20:00:01
1055237 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Mileage: 126064 km
Date: 2019.06.28
Time: 20:11:29
1052933 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Mileage: 126064 km
Date: 2019.06.28
Time: 20:11:29
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 13011504400916
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0918A5B8A8394309BE-805C
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 960 E HW: 8V0 920 960 E
Component: KOMBI H02 2210
Coding: 07A50900228046000102A800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 3D700168AC71AFA9C2-8068
1 Fault Found:
13637376 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Mileage: 126064 km
Date: 2019.06.28
Time: 20:11:29
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0000640298
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 3A7A0A74BD5F9891E7-806E
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 20 05 2013 A1178099
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051453188
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07051301100886
Coding: 001D8E204000040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3F8C7B60A67DBDB9D0-806A
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 41887D98D089CB49A6-8014
1 Fault Found:
23552 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 126064 km
Date: 2019.06.28
Time: 20:14:52
Motor status: 00
System status: Waiting for start request
Supply voltage: 11.75 V
Temperature: 42.0 °C
KFC: 5C
KFA: 00 00
Environmental conditions: 5F
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.02 V
uAdSensI_SwitchedKl30_xdu16: 12.01 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 16051302090266
Coding: 001D86204C00040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E720664A177B4B1DB-806A
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 874 A HW: 8V0 035 874
Component: MU-S-ND-ER 040 0370
Serial number: A7F00206130238
Coding: 01730300FF00000021111101000A00002F0001460100010002
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG6017TM
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 H HW: 8V0 919 614 D
Component: ControlUnit_H H64 0764
Serial number: C1000008081300020094
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 34
Mileage: 126053 km
Date: 2019.06.28
Time: 18:03:17
Voltage terminal 30: 11.9 V
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 21051304080245
Coding: 000086204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 010 0006
Serial number: 21051303110244
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 03:52)--------------------------
