Fourtitude.com - :: GruvenParts.com: Adjustable Control Arms, Billet Shift Repair Kits, and So Much More! ::
    Results 1 to 8 of 8
    1. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      06-28-2019 01:51 PM #1
      TT/R32 Rear Adjustable Control Arms
      Click on the picture to visit our product page for up to date pricing info.
      Poly Ends Now With Relocated Zirc Fittings for Easier Access !
      Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
      The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
      Choose from a zero deflection high radial load PTFE lined inboard spherical joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the spherical joint and bushings is nearly water tight!
      OR
      A poly bushing inboard end made from heat treated 4340 forged chromoly housing, thread in grease fitting, zinc plated steel protective sleeves, and race grade greaseable black polyurethane bushings from Energy Suspension.
      You decide which set up you want ! The zero deflection spherical joints are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
      All GruvenParts control arms feature the following :
      Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
      Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
      Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue.
      Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
      We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
      This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
      ***Save Big $ when buying these in conjunction with our Adjustable Rear Swaybar End Links and our Adjustable Front Swaybar End Links
      ...And finally...
      TT/R32 Rear Adjustable Control Arm Hardware
      Need to buy 1 off’s for a project? Want new/longer fasteners? Look below for the parts to get the job done!
      - High radial load GENUINE FK JMX Series PTFE lined heim joint kits
      - Custom 4340 Forged, Heat Treated poly bushing ends with Rolled Threads
      - Racing Grade protective rubber dust boots for ¾” heim joints
      - Longer bolt kits - 80mm in length, grade 8.8, zinc plated
      - Headlight Leveling System Bracket
    3. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      07-10-2019 05:33 PM #2
      Click Here for MK2/MK3/B3/B4 12V VR6 Cast Aluminum Thermostat Housing Assemblies!
      GruvenParts.com is now distributing these beautiful cast aluminum thermostat housing assemblies for all 12V VR6 engines found in Corrado, Eurovan, Golf/Jetta MK3 and Passat B3/B4 vehicles. This part replaces thermostat housing P/N 021-121-117A (021121117A), adapter P/N 021-121-133D (021121133D), and thermostat cover P/N 021-112-121A(021112121A). Pair this with our billet crack pipes shown below for additional savings and durability !
      This cast thermostat housing assembly includes the main thermostat housing with an integrated crackpipe adapter section and a cast aluminum thermostat cover. All new mounting fasteners, O-rings, and clips are included to complete your installation.
      This cast aluminum thermostat assembly will mate up with the GruvenParts.com billet crack pipes - buy them as a set and save $$ ! You can also choose to buy a new 80C or low temp 70C thermostat with thermostat O-ring.
      NOTE: VR6 housings are individually machined and cleaned of burrs and sharp metal edges from casting process. Your flange may differ slightly from the photos shown
      Product Fitment:
      Volkswagen Corrado VR6 12v
      Volkswagen Eurovan T4 VR6 12v
      Volkswagen Golf III VR6 12v
      Volkswagen Jetta III VR6 12v
      Volkswagen Passat B3 VR6 12v
      Volkswagen Passat B4 VR6 12v
      Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
      MACHINED FROM 6061-T651 ALUMINUM TO EXACTLY MATCH OEM PIPE DIMENSIONS - OURS DOES NOT COME WITH CHEAP THIN WALLED TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
      12V and 24V VR6 Coolant Pipes aka Crack Pipes
      GruvenParts.com was the 1st to build this part and it’s what started us off! We manufacture this pipe EXACTLY to match the OEM part shape so there is NEVER a fitment issue. Be careful when considering other billet pipes which do not match the exact shape of the OEM pipe. The fitment of this part is tricky and the shape MUST BE IDENTICAL to the OEM part to ensure correct alignment between the water pump and thermo housing.
      If you have a billet crack pipe in your VR6, chances are it was made by us. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! Our pipe has a modular design which allows you to plug the oil cooler feed line with a ¼ NPT plug if installing an external oil cooler. Ours can also be ordered with a chrome plated drain valve for quick and clean coolant flushes. The pipe can also be ordered with a brilliant chrome finish for those seeking the ultimate engine bay bling!
      If you dont want to do this job again, buy the LIFETIME WARRANTED GruvenParts.com billet CrackPipe !
      Make sure to see our website for the complete installation DIY
      The 12V version replaces OEM p/n 021-121-050C (021121050C) found in 12V VR6 : VW Corrado, Golf, Jetta, Passat, and Eurovan.
      The 24V version replaces OEM p/n 022-121-050 (022121050) found in 24V VR6 : VW R32, Golf, Jetta, Eurovan, EOS, Audi : 3.2L V6 TT and A3
    4. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      07-18-2019 04:49 PM #3
      Billet 12V VR6 Drive Belt Pulleys - All 12V VR6
      GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties. Comes with new crank bolt !
      Buy them as a set and save!
      These pulleys replace the following OEM part numbers :
      Crank Pulley : 021-105-243 (021105243)
      Tensioner Pulley: 021-145-299 (021145299)
      Water Pump Pulley: 021-121-031A (021121031A)
      Alternator Pulley: 021-903-119 (021903119)
      Power Steering Pulley : 021-145-255 (021145255)
    6. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      08-07-2019 02:32 PM #4
      Billet VW/Audi 24V 2.8/3.2/3.6L Oil Filter Housing Caps !
      Modular Billet Aluminum Oil Filter Housings For VW And Audi 24V 2.8/3.2/3.6L Engines !
      This product is intended to replace VW/Audi Part Number 071-115-433 (071115433). Please check the OEM part number of your oil filter housing cap before ordering. You can do this easily by calling your dealer and giving them your VIN # and asking them to tell you the part number for your oil filter housing cap.
      Just like our best selling billet MK2/MK3/MK4 VR6 and 4.2L V8 oil filter housing caps -- This one was worth the wait ! Never, but NEVER break a flimsy plastic oil filter housing again. Or deal with the unsightly leaks created by the cheaply made (yet expensive) plastic OEM housing cracking and deflecting. We made this one the way VW and Audi should have – from A SOLID BLOCK OF ALUMINUM, by God!
      First, we start with a massive solid chunk of Aircraft Grade 6061-T6511 Aluminum. The section is delicately placed on one of our special CNC machining centers and precision cut to EXACTLY match the OEM plastic housing. The metal gods (well, in this case, one of our highly talented CNC programmers) has programmed elaborate steps for the very time consuming and expensive operation of profiling the special buttress threads into the housing using the exact DIN spec thread cutting tool required for a perfect seal.
      This part comes with 2 threaded holes (M10x1) with steel drain plugs installed in both as shown in the pictures. You can therefore choose to install a VDO pressure sender in the center hole (VDO P/N 360 015) and/or a VDO temperature sender in either the outboard threaded hole or center threaded hole (VDO P/N 323 423). Please note the pressure sender will only fit in the center hole due to its size. Either hole can be retained as a drain. Please note the temperature and pressure senders are not included, you can source those from many retailers (such as Summit Racing). This DOES include the 2 steel drain plugs.
      This product is intended to replace VW/Audi Part Numbers 071-115-433 (071115433) or equivalent. Please check the OEM part number of your oil filter housing cap before ordering. You can do this easily by calling your dealer and giving them your VIN #.
      Application Guide :
      Audi A3 8P All 3.2L
      Audi A3 8P All V6 3.2L
      Audi TT MKI All 3.2L
      Audi TT MKII All 3.2L
      Volkswagen CC 4Motion VR6
      Volkswagen CC FWD VR6
      Volkswagen Eurovan T4 All VR6 24v
      Volkswagen Golf IV All VR6 24v
      Volkswagen Jetta IV All VR6 24v
      Volkswagen Passat B6 All 3.6L
      Volkswagen R32 MKIV All All
      Volkswagen R32 MKV All All
      Special Note At The End :
      You will need to carefully remove the sping bypass valve located at the base of your OEM plastic oil filter cap and install it into this billet housing cap. Carefully push down on the bypass valve inside your OEM cap and deflect the spring to 1 side fully. The whole bypass valve will then unclip from the plastic OEM cap. Install it in the same position into our billet cap. It is easiest to do this on a work bench, just use a suitable deep well socket to fit against the spring bypass valve, face the cap down (bowl at top) while aligning the bypass valve with the metal tangs on our billet housing. Then apply about 10 lbs of force downward while wiggling side to side gently. Your existing bypass valve will snap into place over the metal tangs in our housing. YOU MUST INSTALL THE BYPASS VALVE. If you do not, the oil will simply bypass the filter and will not be cleaned.
      When installing this cap into the oil filter housing, please clean all threads and use a bit of anti-seize on the threads of our part to make this easier to remove during your next oil change. Also, be sure to lubricate the o-ring with some fresh oil so it is not torn during installation. This part doesnt come with the O-ring -- that comes with the filter itself.
    7. Forum Sponsor Chad@GruvenParts.com's Avatar
      Dec 13th, 2013
      3,902
      08-27-2019 01:31 PM #5
      Cast Aluminum MKIV and MKV 12V and 24V VR6 Thermo Housing Assemblies ARE FINALLY HERE !!
      GruvenParts.com is happy to distribute these beautiful cast aluminum thermostat housing assemblies for the Audi MK1 and VW MKIV and MKV 12V and 24V VR6 engines. This part carries a LIFETIME WARRANTY !!
      This cast aluminum thermo housing assembly replaces OEM P/N 022-121-117C (022121117C) main housing and OEM P/N 021-121-121C (021121121C) thermostat cover or OEM P/N 022-121-121E (022121121E) thermostat cover, depending on your vehicle. The assembly consists of a cast aluminum main housing and thermostat cover, new bolts, seals, clips and o-rings. You can also choose to add in our billet machined crack pipe and a 70C or 80C thermostat as well. Buy them as a package deal and save $$ !
      The Billet Crackpipes we sell replace :
      OEM P/N 021-121-050C (021121050C) found in 12V VR6
      OEM P/N 022-121-050 (022121050) and 022-121-085 (022121085) found in 24V VR6
      Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32, Cayenne, and Touareg!
      The thermostats we sell are OE replacements for OEM P/N 075-121-113D (075121113D) for the 12V motors and OEM P/N 022-121-113 (022121113) for the 24V motors. You can choose these in either 70C (low temp) or 80C (normal temp). If you need a different thermostat, let us know, we can probably get it !
      NOTE: VR6 housings are individually machined and cleaned of burrs and sharp metal edges from casting process. Your flange may differ slightly from the photos shown.
      Applications :
      Replaces OEM P/N 022-121-117C (022121117C) main housing and OEM P/N 021-121-121C (021121121C) thermostat cover or OEM P/N 022-121-121E (022121121E) thermostat cover, depending on your vehicle. Please verify your OEM P/N before ordering !
      Audi - A3/A3 Quattro, TT/Quattro w/ VR6
      VW – EOS, R32, Golf, Jetta, Passat, Eurovan w/VR6
    8. Forum Sponsor Chad@GruvenParts.com's Avatar
      Dec 13th, 2013
      3,902
      09-06-2019 12:22 PM #6
      A4/S4, A6/S4, Passat, Boxster Stainless Slave Cylinder Bleeder Screws
      GruvenParts.com Introduces Stainless Bleeder Screws for Audi A4/S4, A6/S6, VW Passat and Porsche Boxster!
      Our 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw which Audi and VW provide on their clutch slave cylinder P/N 8E0-721-257F (8E0721257F), 8E0-721-257M (8E0721257M), 8E0-721-257A (8E0721257A), and 8E0-721-257B (8E0721257B).
      How many times have you gone to bleed the brakes on your Audi, Passat or Boxster only to round off the hex on the cheap plastic bleeder screw on your clutch slave cylinder? The problem is corrosive brake fluid actually melts the plastic bleeder screw and bonds it into the slave cylinder housing making it impossible to open. This problem makes it impossible to bleed your brakes properly and causes soft brake and clutch pedals. The only remedy until now has been to replace the entire slave cylinder unit, which is expensive, time consuming, and NOT FUN (to say the least!).
      GruvenParts.com has addressed this problem with our new 303 Aircraft Grade Stainless Steel Bleeder Screws. We machine these in house on state of the art HAAS CNC lathes and mills with custom screw machining capability to exactly match the OEM threads for a perfect fit. These come complete with preinstalled Viton O-rings for maximum life. The hex will never round off or become stuck in the slave cylinder body and you likely will never need to replace a slave cylinder again.
      This 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw found in clutch slave cylinders P/N P/N 8E0-721-257F (8E0721257F), 8E0-721-257M (8E0721257M), 8E0-721-257A (8E0721257A), and 8E0-721-257B (8E0721257B).
      This product fits the following vehicles :
      Audi A4/S4 1996 thru 2006 1.8T, 2.8L, 3.0L. 4.2L including Quattro
      Audi A6/S6 1995 thru 2005 2.7L, 2.7T, 2.8L, including Quattro and Allroad
      Volkswagen Passat 2000 thru 2005 1.8T, 2.8L including 4 Motion
      Porsche Boxster 1997 thru 2004
    9. Forum Sponsor Chad@GruvenParts.com's Avatar
      Dec 13th, 2013
      3,902
      09-10-2019 11:53 AM #7
      12V, 24V, and Touareg/Cayenne VR6 Billet MODULAR Coolant Pipes aka Crack Pipes
      The Touareg/Cayenne versions replaces OEM p/n 022-121-085A (022121085A) and 022-121-050A (022121050A) found in 3.2L Porsche Cayenne and VW Touareg.
      ** PLEASE VERIFY YOUR OEM PART NUMBER BEFORE ORDERING TO ENSURE CORRECT FITMENT **
    10. Forum Sponsor Chad@GruvenParts.com's Avatar
      Dec 13th, 2013
      3,902
      10-10-2019 11:32 AM #8
      VR6 Billet Aux Water Pump Bracket – All VR6
      This part replaces the useless rubber donut OEM P/N 035-959-209E (035959209E) that does a poor job supporting your PRICEY auxiliary water pump, and related PRICEY hoses. The OEM rubber donut allows the weight of the pump and hoses to sag, causing stress which can lead to pump and hose failure. Our billet version is the way VW should of designed it to begin with and locks the pump and hoses tight! On or off track, this part will secure the aux pump and prevent pump and hose failure.
      Replaces OEM P/N 035-959-209E (035959209E) common to the following vehicles -
      Corrado - all VR6
      Eos - 2007 + 3.2L VR6
      Eurovan - All VR6
      R32 - 2004
      Golf, Jetta, Jetta Wagon - 1993-2007 All VR6
      Passat - 1992-2005 - All VR6 and V8
      Phaeton - 2004-2007 6L V12
      Touareg - 2003 on 3.2L VR6
