Fourtitude.com - ** GruvenParts.com: Get your Thermostat Housings, Shift Repairs, and More Right Here! **
    Results 1 to 5 of 5
    1. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      06-28-2019 01:08 PM #1
      Click Here for MK2/MK3/B3/B4 12V VR6 Cast Aluminum Thermostat Housing Assemblies!
      GruvenParts.com is now distributing these beautiful cast aluminum thermostat housing assemblies for all 12V VR6 engines found in Corrado, Eurovan, Golf/Jetta MK3 and Passat B3/B4 vehicles. This part replaces thermostat housing P/N 021-121-117A (021121117A), adapter P/N 021-121-133D (021121133D), and thermostat cover P/N 021-112-121A(021112121A).
      This cast thermostat housing assembly includes the main thermostat housing with an integrated crackpipe adapter section and a cast aluminum thermostat cover. All new mounting fasteners, O-rings, and clips are included to complete your installation.
      This cast aluminum thermostat assembly will mate up with the GruvenParts.com billet crack pipes - buy them as a set and save $$ ! You can also choose to buy a new 80C or low temp 70C thermostat with thermostat O-ring.
      NOTE: VR6 housings are individually machined and cleaned of burrs and sharp metal edges from casting process. Your flange may differ slightly from the photos shown
      Product Fitment:
      Volkswagen Corrado VR6 12v
      Volkswagen Eurovan T4 VR6 12v
      Volkswagen Golf III VR6 12v
      Volkswagen Jetta III VR6 12v
      Volkswagen Passat B3 VR6 12v
      Volkswagen Passat B4 VR6 12v
    3. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      07-10-2019 03:11 PM #2
      Happy Hump Day Everyone!
      Make sure to stop by our website at GruvenParts.com to purchase any of our TDI products, as well as our multitude of other Volkswagen and GM car parts.
      Contact Us!
      [email protected]
      404-556-6663
    4. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      07-18-2019 04:34 PM #3
      02A Billet Stainless Steel Short Shifter Bracket
      Replace the weak plastic link in your cable shift mechanism with this one made from Aerospace grade, hardened stainless steel. Reduces side/side shift throw by 35%! This part replaces OEM P/N 1J0-711-256 (1J0711256) an 1H0-711-260 (1H0711260) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
      Replaces OEM P/N 1J0-711-256 (1J0711256) and 1H0-711-260 (1H0711260).
      Stainless FWD/AFT Steel Shift Cable Repair Block
      GruvenParts.com is proud to release these solid stainless fwd/aft cable and side/side cable shift repair blocks for cable shift VW vehicles. These parts will quickly replace the weak forward end of the factory fwd/aft and side/side shift cables P/N 1H0711265 (1HO-711-265) where it connects to the transmission linkage. There is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken fwd/aft or side/side shift cable. And if your cables are not yet broken, throw 1 of each of these in the glove box and be prepared for the inevitable!
      These repair blocks repair the FWD/AFT and SIDE/SIDE cables P/N 1H0711265 (1HO-711-265) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6. Please select the appropriate cable, as the blocks are different.
      Add some indestructible hardware to the factory cable shift mechanism where it needs it most! Buy these parts together and save!!
    6. Forum Sponsor GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      19,529
      Too many to list !
      08-07-2019 02:17 PM #4
      Product Fitment:
    7. Forum Sponsor Chad@GruvenParts.com's Avatar
      Dec 13th, 2013
      3,902
      09-06-2019 12:11 PM #5
      A4/S4, A6/S4, Passat, Boxster Stainless Slave Cylinder Bleeder Screws
      GruvenParts.com Introduces Stainless Bleeder Screws for Audi A4/S4, A6/S6, VW Passat and Porsche Boxster!
      Our 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw which Audi and VW provide on their clutch slave cylinder P/N 8E0-721-257F (8E0721257F), 8E0-721-257M (8E0721257M), 8E0-721-257A (8E0721257A), and 8E0-721-257B (8E0721257B).
      How many times have you gone to bleed the brakes on your Audi, Passat or Boxster only to round off the hex on the cheap plastic bleeder screw on your clutch slave cylinder? The problem is corrosive brake fluid actually melts the plastic bleeder screw and bonds it into the slave cylinder housing making it impossible to open. This problem makes it impossible to bleed your brakes properly and causes soft brake and clutch pedals. The only remedy until now has been to replace the entire slave cylinder unit, which is expensive, time consuming, and NOT FUN (to say the least!).
      GruvenParts.com has addressed this problem with our new 303 Aircraft Grade Stainless Steel Bleeder Screws. We machine these in house on state of the art HAAS CNC lathes and mills with custom screw machining capability to exactly match the OEM threads for a perfect fit. These come complete with preinstalled Viton O-rings for maximum life. The hex will never round off or become stuck in the slave cylinder body and you likely will never need to replace a slave cylinder again.
      This 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw found in clutch slave cylinders P/N P/N 8E0-721-257F (8E0721257F), 8E0-721-257M (8E0721257M), 8E0-721-257A (8E0721257A), and 8E0-721-257B (8E0721257B).
      This product fits the following vehicles :
      Audi A4/S4 1996 thru 2006 1.8T, 2.8L, 3.0L. 4.2L including Quattro
      Audi A6/S6 1995 thru 2005 2.7L, 2.7T, 2.8L, including Quattro and Allroad
      Volkswagen Passat 2000 thru 2005 1.8T, 2.8L including 4 Motion
      Porsche Boxster 1997 thru 2004
