Fourtitude.com - 2001 6266 stk fully built motor s4
    Results 1 to 8 of 8
    1. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      04 BMP R32, 2011 Audi A4 6 spd premium plus
      06-17-2019 10:40 AM #1
      I'm considering maybe letting my noggy go.
      The shell is a Virginia car and pretty clean with a few dings here and there. 211000 on it but you'd never know. I put a cluster with a new lcd in it that has 110k but I have the original cluster as well. I'd consider trades for a newer tundra or Silverado 4wd. Here's the mods list.
      2001 Audi S4 sport package
      Nogaro blue
      Blue Alcantara interior
      Pioneer double din
      Rs4 grille
      Carbon mirror caps
      Carbon b pillars
      Newer low mileage vogtlands coilovers
      Driveshaft shop 1 piece driveshaft (mild vibration at higher rpm)
      Awe dts bar with poly mount
      034 track performance motor mount and trans mount
      034 poly snub mount
      Apikol rear diff mount
      European e-codes headlights
      S4 front bumper shaved grilles
      Cupra lip
      Custom carbon fiber hood vents
      Treadstone front mount intercooler with all vibrant piping and vibrant vanjen flanges
      Tial type q 50mm blow off valve
      Tial mvr 44mm wastegate
      Project b5 single turbo pipping kit
      B6 transmission
      Precision pte6266 turbo 3.5" downpipe
      Custom 3.5" exhaust to a vibrant muffler I fabricated (pictures below)
      Hpx pmas blow through MAF
      Battery relocated to trunk
      Pioneer double din dvd
      Innovate lc1 wideband gauge (vent pod)
      Defi boost gauge (steering pod)
      Pb5 electric fan kit
      Jhm short shifter with upgraded linkage and a suede boot with nogaro stitch
      Motor:
      short block fully built
      82.5mm je pistons (2.8)
      Ie rods
      Arp rod hardware
      Race rods + main bearings (Glyco)
      ARP main caps studs
      Eurospec Main cap girdle
      Crank polished + balanced
      2.8 heads (with exhaust valves swapped from 2.7)
      Modified intake manifold
      Fluid ampr crank pulley
      80mm hemi throttle body
      Oem r8 coil packs
      Newsouth intake manifold spacer
      830cc injectors
      Hellcat 525lph in-tank fuel pump
      fx400 clutch kit
      Metal clutch slave
      Interior is in good shape. Headliner is sagging in the rear
      Genuine 18x8 and 18x9 BBS LM with good hankook tires
      Motor build has just about 5500 miles.
      The car is Blake tuned currently and runs a conservative 2.9 fats time. Has so much more in it.
      Few minor issues:
      Bottom of windshield cracked but I'm going to have it replaced with OE glass
      The girdle seaps oil alittle bit from where it meets the block and could use a reseal
      This is everything I can think of off the top of my head, I'll update it when I think of more.
      Text me at 315 383 6152
      15,000 obo
      The car is located in Syracuse, New York.
      Sent from my Pixel 3 XL using Tapatalk
    3. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      06-30-2019 09:25 PM #2
      14.5k
    4. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      07-15-2019 12:30 AM #3
      Bump 13.5
    6. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      07-21-2019 03:55 PM #4
      Most issues have been sorted. Windshield is scheduled to be replaced. New price 13k
    7. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      08-14-2019 04:21 AM #5
      Bump. 12.5k on LM and 10.5k on 18 inch b6 S4 avus
    8. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      08-22-2019 10:06 AM #6
      Sold
    9. Member mk4dan's Avatar
      Jul 12th, 2013
      Syracuse, NY
      110
      11-15-2019 12:58 AM #7
      And I quickly regret selling and want it back.
    10. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      FL
      4,947
      Mk3 VRT, Mk4 VRT, Mk4 VRT, 8P A3 QT VR, B6 3.6 4Motion VR, B5 Avant 1.8BT, B5 Avant QT VRT
      01-11-2020 07:42 PM #8
      Quote Originally Posted by mk4dan View Post
      Sad, truly a beautiful car.
      "OP sounds like a MKIV guy"
