Fourtitude.com - 1.4tsi upgraded power
    Results 1 to 10 of 10
    1. 06-07-2019 08:33 PM #1
      Just curious if anyone knows how much power a 1.4tsi can handle before it makes it un reliable?
      Sent from my SM-G960U using Tapatalk
    3. 06-07-2019 09:18 PM #2
      Quote Originally Posted by Clv3 View Post
      336hp with Nitrous I think? Lol
    4. 06-07-2019 09:25 PM #3
      I was just meaning like is a tune a intake and exhaust going to do anything to make it unreliable
    6. 06-07-2019 09:29 PM #4
      Not at all. I have had a K&N panel air filter since 15k miles until 70k or so. About 5-10k with a short ram done myself. I had a shop do the exhaust. Stock is about 2 inch before the downstream cat. After the middle it’s like 1 7/8inch or so. I went with 2.25 inch exhaust from the downstream o2 sensor delete the cat and straight back with a 2.5 magnaflow straight thru muffler and tip. Sounds great to me. Stock tune tho would love to tune but clutch would be an issue. I redline this car at least once every time it’s warmed up. Had it since 40 miles now at almost 82k still runs like a champ!!!
    7. 06-07-2019 09:38 PM #5
      Okay thank you
    8. 06-07-2019 09:41 PM #6
      I really want to do a tune but didn't know if it was going to mess with the reliablility
    9. 06-07-2019 09:42 PM #7
      Stage one? Make sure you always use the right octane even before tuning and check your trans fluid regularly as well as change your engine oil sooner . I change my filter and oil every 5k miles
    10. 10-03-2019 09:38 PM #8
      I've had the jb4 on my 1.4 for about 5 months now (maybe more) intake, bov with silicon pipe, solid upper mount, poly in the dog bone and trans mounts, and an ecs short throw kit. Depending on the temps I hit between 20-23psi without any issue. Currently at 86k, jb4 installed around 77k. These engines are pretty stout
    11. Member
      Oct 7th, 2019
      South Florida
      149
      2016 Jetta S 1.4t
      10-14-2019 11:16 PM #9
      Unitronic says 196hp tune plus cai +7ish hp has " OEM like drivability and reliability" I wouldn't push more then 225 but that's just me!
    12. 10-14-2019 11:29 PM #10
      There’s a Mk7 Golf 1.4Tsi 5 speed in Mexico. K04 , meth injection, 3 inch Downpipe and few more upgrades pushing 240 to the wheels. Then they also did the same engine but with a 100 hp nitrous shot. Car made 330ish hp to the wheels... stock internals... again they did said it could blow any time
