Fourtitude.com - Mk4 R32 turbo questions
    Results 1 to 9 of 9
    1. Member mpowertech's Avatar
      Mar 9th, 2012
      Baltimore
      525
      2004 TR R32T
      06-05-2019 09:39 PM #1
      I am looking for guidance and recommendations for a tune to be purchased immediately after my build.(United Motorsports seems to be the goto) Particulars are as follows:
      2004 R32
      HGP R 30 turbo(unsure of the actual size;its their entry level turbo)Has internal diverter valve
      HGP exhaust manifold
      8.5.1 compression pistons
      3" Catless exhaust
      CTS turbo Short runner intake
      SAI delete
      CTS Crank and powerpulley kit
      Front Mount intercooler
      CTS intercooler piping kit
      APEXi AVC-R Boost controller
      DeatschWerks DW65v AWD High-Flow Fuel Pump
      Stage 3 Daily SouthBend clutch and flywheel kit
      Questions:
      1.) I still need to purchase injectors and am a bit unsure of what size should be considered and what boost level correlates to that size.
      2.)Spark plug type?
      3.)What is the approximate HP I can safely look forward to with the build particulars listed above?^
      Any thoughts to help put the remaining list together before I reach out to UMS is greatly appreciated.
    3. Junior Member
      Dec 25th, 2016
      Sacramento, CA
      28
      2004 Volkswagen R32
      06-07-2019 03:35 PM #2
      I’m running UM’s 630cc injectors for their 630 tune, no complaints. If you end up going the 630 route I’d probably buy them from CTS because they have to be machined for the R32 Head. You’ll need injector adapters aswell. But if you wanted to spend some more dough then go with the 870 ProMAF set up UM offers. You’ll need 870cc injectors and then the promaf. But with your set up and depending on how much boost you run, with the 630 set up 500 is possible for sure.
    4. Junior Member
      Dec 25th, 2016
      Sacramento, CA
      28
      2004 Volkswagen R32
      06-07-2019 03:36 PM #3
      Forgot to mention the plugs I’m running, DCPR8IEX
    6. Member mpowertech's Avatar
      Mar 9th, 2012
      Baltimore
      525
      2004 TR R32T
      06-07-2019 06:36 PM #4
      Quote Originally Posted by TheYoungWookie View Post
      I can’t thank you enough. This is gold. I hadn’t considered the ProMaf set up for no particular reason, but thank you for the great advice!
      BTW your .:R is gorgeous. I tried to do some creative zooming on your stablemate behind you, but no luck. What a garage!!
    7. Junior Member
      Dec 25th, 2016
      Sacramento, CA
      28
      2004 Volkswagen R32
      06-07-2019 06:41 PM #5
      Thanks man but I can’t take credit for it as it is my bosses but I’m thankful I get to keep my car/work on it in here ahaha.
    8. Member mpowertech's Avatar
      Mar 9th, 2012
      Baltimore
      525
      2004 TR R32T
      06-11-2019 09:45 AM #6
      Do you have a build thread? I'd love to see the development of this project. Gorgeous!
    9. Junior Member
      Dec 25th, 2016
      Sacramento, CA
      28
      2004 Volkswagen R32
      06-11-2019 09:49 AM #7
      Quote Originally Posted by mpowertech View Post
      I never got around to making one, never too late to start one I suppose. My Instagram usually has all the posts of my car on there ahah @brysvnvk
    10. Member mpowertech's Avatar
      Mar 9th, 2012
      Baltimore
      525
      2004 TR R32T
      06-12-2019 07:06 AM #8
      Ha! Checking out your Instagram and it looks like we both took our .:R's to the overboost cafe. LOL. I had 204k on the clock when I decided it needed a turbo. Build took all winter 2018, and it lasted maybe a month on all stock internals no HSGasket. I guess I was looking for the easy way to buy Pistons/ARP bolts etc.
      BTW it sounded brutal on your gram vids
    11. Junior Member
      Dec 25th, 2016
      Sacramento, CA
      28
      2004 Volkswagen R32
      06-12-2019 01:48 PM #9
      Yeah I left stock pistons and rings in with 181k and that’s what happened lol
