Fourtitude.com - Ben Modified Build Thread - Subaru 360 Kei Van Resto Mod
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 104
    1. 06-01-2019 09:49 PM #1
      I purchased this Van along with the Autobianchi. The goal is to build it in such a way that it will be powerful, handle and brake well and capable of being a daily driver
      Here is a poorly manipulated photo of the general look that I am going for. I am considering a canvas top attached to the full cage along with moving the wheels out to the corners.
      The current plan is Hayabusa power. Here is a chain drive diff which will be coupled with a much narrowed VW bug suspension with 4 wheel disc brakes. The diff is finished with the exception of a flexplate to utilize an electric reverse.
      The body is off the frame now
      The frame is actually a lot better than the body
      No shortage of body filler but at least the floor is good (except for the spare tire well)
      I will be removing all of the stock suspension, brakes and drivetrain. All of which will be used as donor parts for other peoples restorations. The suspension from the bug will be narrowed 11 inches. I am using 944 Turbo PhoneDial wheels and aftermarket 4 wheel disc brakes. I should be able to tuck the tires within the fender wells or at least under a small flare.
      Here is the VW beam going in. The frame rails will be beefed at each contact point with the interior cage.
      The springs packs will be cut down
      The beam will have height adjusters added. The front frame rails have been plated with heavier steel with the beam fitting on the top and bottom of the frame rails
      All of the stock front suspension is out and will go on to its new owner
      VW beam going in.
      Front suspension is nearly done. Just waiting on a 14mm Tap to thread the shortened steering arm
      Sandblasted the rear VW trailing arms. Replacing the bearing and seals also
      Installing studs in the rear rotors
      Starting on the rear suspension
    3. I’m not a loser. I’m a winnah!! patrikman's Avatar
      May 10th, 2008
      44.5 North, 88 West
      37,843
      made in ‘murica truck and wagon
      06-01-2019 09:59 PM #2
      That’s a pretty wild build
      this signature kills fascists.
    4. Member 1x1's Avatar
      Jul 30th, 2016
      Portland, ME
      274
      '96 LX450
      06-01-2019 11:33 PM #3
      Why not run a long tie-rod between the wheels and remove the short tie-rod? This should give you better handling, and help prevent some single wheel bump steer.
    5. Senior Member Lwize's Avatar
      Dec 4th, 2000
      Los Angeles
      27,261
      15 Rav4
      06-01-2019 11:42 PM #4
      The headroom appears nonexistent.
      How is the driver's seat going to be situated, and are you three feet tall?
      Epstein is alive.
    6. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      41,938
      '66 Beetle (X2) '08 Fit
      06-02-2019 01:13 AM #5
      Quote Originally Posted by 1x1 View Post
      There’s no Ackerman effect with that setup. The inner and outer wheels travel different distances, so when you push it in a corner you’ll have a lot of slip, making it more likely to plow since you’re already slipping. You can convert to center steer with a U-joint shaft, which helps a lot on the short side, though technically makes the long side worse.
    7. 06-02-2019 06:29 AM #6
      Quote Originally Posted by Lwize View Post
      At 6 feet I can still get in it and have a couple of inches of headroom. I checked before I handed over the cash! They were using the back seat cushions from an 80's grand am (very form fitting) directly on the floor. Comfortable enough, but the wheel wells were very much in the way. It was also very difficult to get in the van between the steering wheel and the wheel well. By moving the front wheels (and wheel wells) forward I should be able to get in easier and have sufficient hip room. The van came with an additional roof, so if needed, I could raise the roof back up a bit. I don't think it will come to that.
    8. Member 1x1's Avatar
      Jul 30th, 2016
      Portland, ME
      274
      '96 LX450
      06-02-2019 02:24 PM #7
      Good to know.
    9. 06-03-2019 09:45 PM #8
      Temporarily removed some sheet metal. It will be modified and re-installed later.
      Why does every project car I drag home have frame rails filled with pecans!
      This is just what fell out when I cut the rail
      This is post air nozzle!
      Decided to save the VW torsion housing for a future project. Went with aftermarket irs mounts and heim joints. More details to follow as parts arrive.
      http://www.BenModified.com
      Feb 1st, 2012
      MI
      4,873
      2005 Acura TSX
      06-03-2019 10:46 PM #9
      Quote Originally Posted by Ben Modified View Post
      This has got to be a record for smallest OEM daylight opening.
    11. Member
      Mar 29th, 2018
      Columbus, OH
      368
      2016 Fiesta ST, 1991 Honda Beat
      06-04-2019 10:13 PM #10
      I love threads where I learn things. Thanks
      "Who told you that there is no true, faithful, eternal love in this world?! May the liar's vile tongue be cut out!"
    12. 06-04-2019 10:39 PM #11
      Fabbed some plates to attach to the rear trailing arms and a heim joint to the new crossmember
      My youtube playlist page is here:
    13. Member Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      7,129
      16v I4, Turbocharged V6, Gas drinking V8, High revving V10
      06-05-2019 12:16 AM #12
      This is fantastic.
    14. 06-05-2019 11:06 PM #13
      Quote Originally Posted by Smooremin View Post
      This is fantastic.
      Thanks!
    15. 06-05-2019 11:17 PM #14
      Isnt this the same bodystyle as RUTs subby
    16. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      79,539
      '18 RCSB EB F150
      06-06-2019 12:02 AM #15
      You are making a Subaru 360 van into a Brubaker Box?
    17. 06-06-2019 04:43 AM #16
      Quote Originally Posted by ImpeccableNEW View Post
      yes, same model just with a chopped top and a lot of rust!
    18. Senior Member Lwize's Avatar
      Dec 4th, 2000
      Los Angeles
      27,261
      15 Rav4
      06-07-2019 02:57 AM #18
      OP -
      I caught up on your Subie 360 YouTube videos. Good stuff!
      Why a chain drive, vs a belt drive?
      Epstein is alive.
    19. 06-07-2019 06:27 AM #19
      OP -
      Thanks! Re: the chain, simplicity. With everything in place, the chain can be replaced without disassembly where a belt would require disconnecting a half shaft or removing the diff.
    20. 06-10-2019 07:33 PM #20
      The rear suspension is coming together.
      These coilovers are from the front of a miata. Pick a Part bargain. Perfect fit.
    21. 06-12-2019 07:31 PM #21
      Started an initial fitting of the body on the chassis to determine upper spring mounts and cage mounts
      Cut out the front wheel wells and rear arches to determine new placement of each
    22. 06-19-2019 08:33 PM #23
      Work on the new front wheel wells
    23. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Not in Europe. Boo.
      22,339
      SR71 C30 t53a/b/b
      06-20-2019 10:52 PM #25
      Wow! That's a cool project.
      Buy my couch!
