Fourtitude.com - Help! B5 s4 crank no start no cel
    1. n00b
      Jan 12th, 2013
      7
      MK3 AHU TDI, VR6 RADO, B5 S4
      05-27-2019 12:59 AM #1
      Hey everyone, I own a 2001 S4 with A/T. When I turn the key I do not have a cel light up on my dash and no scanner will connect to the car, the car will crank but will not start. What I have done:
      -checked fuses 10 and 29 (10 was blown, i replaced and still nothing)
      -checked for 12 volts at the back of the ecu adapter pin points, have 12v at 3 and 62)
      -grounds are good
      -relay beside ecu is clicking when key is turning
      -ecu was tested on a friends bench and is 100% fine
      Any help would be greatly appreciated.
      Aug 31st, 2005
      Compton, CA
      221
      2002 TT 225 Quattro, 2001 Allroad 2.7t 6spd manual, 2003 Allroad 2.7t tiptronic
      06-12-2019 11:28 AM #2
      Check the fuse you replaced to see if it blew again then I would say check the engine timing.
    1. Mk2 vr6. Crank no start. No cel.
      By Ryanfontana in forum 2.8l 12v VR6 Engine Forum
      Last Post: 10-10-2018, 03:26 PM
    2. Please Help! Obd2 vr6 cranks no start?
      By 1lowjetta732 in forum 2.8l 12v VR6 Engine Forum
      Last Post: 12-05-2013, 09:44 AM
    3. Please help! Obd2 vr6 cranks no start?
      By 1lowjetta732 in forum VAG-COM Diagnostic Forum
      Last Post: 11-11-2013, 07:35 AM
