Fourtitude.com - Revs jump at 4500 then drop back
    Results 1 to 6 of 6
    1. n00b dcfuller79's Avatar
      Jul 21st, 2015
      Ohio
      9
      2016 Golf R; 2000 GTI GLX
      05-23-2019 05:34 PM #1
      Recently my 2016 R has developed an intermittent issue. During hard acceleration, onto the highway for instance, the revs climb steadily to 4500 then suddenly jump to 5000 and then back to 4500 before resuming a normal climb. I'm not lifting the throttle. There is no CEL. It doesn't happen all the time. I'm running Unitrionic Stage 1+ with a 034 intake and upgraded boost pipes. Thinking boost leak at the DV. Anyone seen this behavior before?
      Mar 20th, 2019
      55402
      228
      several, who cares
      05-23-2019 06:40 PM #2
      A boost leak won't cause revs to jump.
      DSG or 6MT? Sounds like a slipping clutch.
    4. n00b dcfuller79's Avatar
      Jul 21st, 2015
      Ohio
      9
      05-23-2019 06:48 PM #3
      It's a manual. I initially thought it was the clutch but afterwards figured that it wouldn't stop slipping so predictably. Especially given I not lifting the throttle. It also isn't consistent. Some days it happens. Others it doesn't.
      Mar 20th, 2019
      55402
      228
      several, who cares
      05-23-2019 06:51 PM #4
      I read somewhere that it'll detect clutch slipping via engine speed vs wheel speed without clutch usage. Not sure what the response is, but I'd expect a notification of some sort at least, and automatic backing off the throttle at most.
    7. n00b dcfuller79's Avatar
      Jul 21st, 2015
      Ohio
      9
      06-01-2019 12:05 PM #5
      Not seeing any stored codes in VAGCom. Of course now I'm not seeing it. Been over a week. Been driving just as hard if not harder. You'd think if it were the clutch it would get worse over time... I guess only time will tell.
    8. Member Diggs24's Avatar
      Sep 24th, 2015
      1,427
      2015 GTI; 2003 Saab 9-3 SS
      06-06-2019 11:53 PM #6
      clutch slip
    Similar Threads
    1. Replies: 1
      Last Post: 09-26-2011, 12:23 PM
    2. 1999 VW Jetta revs to 3k rpm then drops the back to 3k rpm?? HELP!!
      By NoStoDubbin in forum 2.0 Liter Engine Forum
      Last Post: 01-11-2009, 12:02 AM
