Fourtitude.com - Remove fuel injectors
    Results 1 to 5 of 5
    1. Junior Member
      Oct 12th, 2013
      Toronto Canada
      56
      09 Tiguan
      05-12-2019 12:43 PM #1
      Only one of 4 came out when I pulled the manifold. Any tricks to get the other 3 out without special tools?
      Feb 16th, 2015
      298
      2006 A3(Arctic White); 2011 A3(Brilliant Black); 2000 S4 (Nogaro)
      05-13-2019 10:08 AM #2
      Wiggle wiggle, but srsly u can wiggle em out, (at least thats what i did when i was replacing mine) just be careful not to grip the sensor port too hard
      Sent from my SM-G975U using Tapatalk
    4. Member APURPLEKING's Avatar
      May 23rd, 2007
      Emmaus,PA
      3,186
      96' GLX
      05-13-2019 03:56 PM #3
      They can be in there pretty tight. I tried to use a hook tool but ended up getting an injector puller cause it wasn't working with the hook tool.
      Sent from my SM-G920T using Tapatalk
      Pm me for any and all glass questions and inquires, or any VAG-COM needs.
      "ITS A BAD TIME BOB!"
      Sep 12th, 2007
      361
      05-17-2019 09:43 AM #4
      Grab the metal ring with pliers or vice grips and pull. Twisting helps too. Load up with some wd-40 or pb blast to help....
    7. 06-09-2019 08:43 AM #5
      They can be in there pretty tight. I tried to use a hook tool but ended up getting an injector puller cause it wasn't working with the hook tool.Brazzers Youporn Xhamster
    Similar Threads
    1. How do I remove fuel injectors and clean it?
      By 94_Red_Jetta in forum 2.0 Liter Engine Forum
      Last Post: 03-14-2004, 11:57 PM
    2. what is the best way to remove fuel injectors?
      By tonyg in forum 16v Engine Forum
      Last Post: 09-30-2002, 10:10 PM
