Fourtitude.com - Actron CP9670 or OBDEleven?
    Results 1 to 6 of 6
    1. 05-05-2019 03:39 PM #1
      My old OBD II scanner won't work on my wife's 2001 Cabrio and her 2007 Volvo XC90. Trying to decide which way to head. Is there anything I can't do with the Actron CP9670, that I can do with the OBDEleven?
      Feb 25th, 2010
      Wilkes-Barre, PA
      960
      05-05-2019 08:59 PM #2
      How about VCDS sense it's their sponsored forum you posting in.
      Just ask about their competition instead. Bright.
      Good Luck
    4. Member The A1 and A2 German's Avatar
      Nov 17th, 2002
      Tempe, AZ 85281
      14,874
      Sonoma S-15, Mark 3 Caddy, Audi A4, 71 CL175, 71 CB350, 69 Stinger, V-Twin Chopper, A4 SC'd Avant,
      08-18-2019 06:01 PM #3
      Quote Originally Posted by stan067 View Post
      Good Luck
      VCDS doesn't own VAG nor OBDII, being on one sided biased agenda sponsored forum improperly titled to promote a product as it should be a subcategory of: OBD Diagnostics Forum
      Cannondale doesn't own the entirety of all mountain bikes while you provide no mountain forum....only Cannondale Bikes....while on a cycling forum.
      FS:350HP 1.8T 1979 Audi 80 Fox Resto Mod $15k
      https://forums.vwvortex.com/showthre...#post114618511
      Feb 25th, 2010
      Wilkes-Barre, PA
      960
      08-18-2019 09:01 PM #4
      Your opinion.
      I just suggest you go to forum for whatever scanner you use?
      If they don't have one that speaks for itself.
      Out of curiosity how do you get a Mark 3 Caddy?
      Good Luck
    7. Member The A1 and A2 German's Avatar
      Nov 17th, 2002
      Tempe, AZ 85281
      14,874
      08-19-2019 05:45 PM #5
      Facts.
      Ross Tech does not own OBD nor VAG, nor has Vortex provided a diagnostic platform pertaining to diagnostics just as Bilstein doesn't own the suspension forum while only a Bilstein Suspension Forum has been put in place.
      Rockford Fosgate does not own the Car Audio Forums.
      Comp does not own the Forced Induction Forums
      Firestone does not own the Wheels & Tire Forum
      While I need information pertaining to audio inwhich is none of Rockford Fosgates business as don't even make the product I'm enquiring about, while I have questions pertaining to N75's and Tial 50mm wastegate's which isn't Comp business, and need responses to offset to 16" 3 piece... inwhich Firestone does not make.
      You get an Mk3 Caddy by taking an Mk1 Caddy down to the shell and cutting apart and welding an Mk3 GTI in it's place (not a swap, yet welding one car into another), then getting a level III inspection and special title that reflects that as there's no longer any identification markers to identify it as what the original car was as even the 'hidden vins" are scrubbed and missing. I have to bring documents when doing emissions as get flagged immediately and an "important person " comes outta an obscure office to look things over as the general staff hasn't dealt with such a case and I'm guessing they think I'm vin swapping, aka illegal stuff. In turn, it's a car wearing a truck.
      VIN, OBDII scan, door jam sticker, software, all say GTI....appearances with out peaking say Caddy.
      Feb 25th, 2010
      Wilkes-Barre, PA
      960
      08-19-2019 10:16 PM #6
      Thanks for your opinion.
      and thanks for explaining a a mk3 caddy.
      Good Luck
    Similar Threads
    1. Brand new actron OBDII scanner for sale
      By tranjozip in forum A4, S4 and RS4 (B5) Parts
      Last Post: 09-02-2006, 10:32 PM
