Fourtitude.com - SMF swap clutch has pressure but won’t disengage clutch
    Results 1 to 2 of 2
    1. 05-03-2019 11:59 AM #1
      So I swapped in a SMF along with a new slave cylinder (I did bench bleed) , have bled the clutch multiple times and it has a decent amount of pressure but everytime I push the clutch in and start it I’m gear it’s just jumping. I changed the MC out to one I know works , re bled it again still has good pressure again just not disengaging. Any thoughts???
    3. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      18,611
      GMC, SAABs,VW's, MG
      05-26-2019 01:48 PM #2
      Did you remove the cover on the Slave cylinder?
      -Noah
      Corrado| 996 Turbo |997 Turbo |TT|
      "Life is tough, but it's tougher if you're stupid" - John Wayne
    Similar Threads
    1. **HELP** OBD2 Port Has Power But Won't Scan
      By RT134jz in forum Hybrid/Swap Forum
      Last Post: 03-12-2009, 10:25 AM
    2. **HELP** OBD2 Port Has Power But Won't Scan
      Last Post: 03-11-2009, 10:58 AM
    3. i have clutch pedal pressure but no clutch...
      By eliotkb in forum Manual Transmission Forum
      Last Post: 05-05-2008, 11:18 AM
    4. Eric: OZ Racing Novas - Tirerack has them...but won't show them?
      By a_grl_n_her_rado in forum Wheel and Tire Forum
      Last Post: 08-17-2004, 09:25 PM
