Fourtitude.com - Fuel Pressure Codes? Before you start replacing hpfp, modules and sensors check your idle stabilization to verify your chains/guides/sprockets are good
    Results 1 to 4 of 4
    1. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      15,387
      2010 3.6 4-Motion CC, 1990 G60/TDI/R36 Corrado
      04-30-2019 11:18 AM #1
      I’m sick of seeing people trying to repair their fuel pressure codes by parts swapping the high pressure fuel pump, sensors, fuel pump module and so on when it’s really just a timing wear issue.
      So check vagcom measuring blocks 208 & 209. If out more than +/- 8* you need to pull the engine and or transmission and replace the chains & guides and should change sprockets and even the hpfp sprocket (it suffers wear on the lobe
      Here is what Ross-tech says to check: http://wiki.ross-tech.com/wiki/index...3/P1025/004133
      Now stop going to the junkyard and butchering the 3.6 harnesses to get hpfp and sensors out that won’t fix your timing chains & guides.
    3. 05-10-2019 08:26 AM #2
      If what's out by +/- 8*?
      Had some concerns about this last year. Especially the chain guide wear.
      I removed the valve cover to take a look, the top end looked fine at 90k
    4. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      15,387
      05-14-2019 07:27 AM #3
      Quote Originally Posted by Magnetchief174 View Post
      If you are out you need to replace the chains and guides.
    6. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      15,387
      05-14-2019 07:33 AM #4
    1. Replies: 4
      Last Post: 02-17-2004, 10:28 PM
    2. Replies: 39
      Last Post: 09-01-2002, 05:05 PM
    3. Before you started, MSF class yes/no???
      By master-p in forum Motorcycle and ATV
      Last Post: 07-24-2002, 02:47 AM
